Author Topic: Just toasted my 350T engine  (Read 5059 times)
Offline zeech
« on: January 09, 2014, 10:39:20 AM »
Had to replace the alternator gasket and forgot to fill back with oil to replace what came out, 1.5QT or so? Engine seized up within a few blocks. Kicker is stuck but budges sometimes, got the pistons to move an inch or so. Tips, help, laugh and point at me?
FML
Offline Roach Carver
Re: Just toasted my 350T engine
« Reply #1 on: January 09, 2014, 11:03:36 AM »
let it cool completely. probably boned though.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #2 on: January 09, 2014, 12:46:55 PM »
Shoot some oil in the spark plug holes and give it some time to work down in. It just might come back to life.....it is a New Year and good stuff sometimes happens early in the year... ::)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline K_Kalynuik
« Reply #3 on: January 09, 2014, 12:49:41 PM »
Ouch! Sorry to hear man. Stay off the Ganja and you'll remember to put oil in next time.
That said, ive seen car motors run with no oil, make a terrible sound on the verge of ceasing and some time and oil soak somewhat fixed it. I say somewhat cause the car was never the same. Id pull the entire thing apart to inspect if it were me. Just my opinion tho.
78' CB592 - http://forums.sohc4.net/index.php?topic=121580.0
1996 Ducati 900ss
1983 Kawasaki GPz750 Track bike
Offline zeech
« Reply #4 on: January 09, 2014, 12:52:51 PM »
Soaking it with PB Blaster, will keep an eye on it but I suspect a full rebuild will be in order. Got a spare engine so I'll probably swap them out for now.
Offline ADW
« Reply #5 on: January 09, 2014, 03:02:24 PM »
FML
Too late for you, but may help somebody else: I take a tag that says OIL on it and put it on the handlebars with it's tie-wire whenever I'm starting an oil change on any of my bikes. I've got another for COOLANT too. I came reaaaaaly close once to doing what you did; now the tag is part of the oil change ritual. Heck, just stick a piece of masking tape on the tank or gauges. When you get on the bike to fire it up you'll say "what is that tape........F&*!@#(k! I didn't put the oil back in!!" and save yourself from this fate.
Offline zeech
« Reply #6 on: January 09, 2014, 03:06:39 PM »
FML
So simple it hurts. Thanks for the tip. And yea, lesson learned and hopefully an avoidance to others!
Offline KrautKoffin
« Reply #7 on: January 09, 2014, 03:35:19 PM »
Damn dude! Once you get one up and running you dry another one!
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline zeech
« Reply #8 on: January 09, 2014, 03:37:32 PM »
Hahah! Catastrophic oil leak in the first, little oil in the second. I guess that's what I get for wanting to rebuild them anyway. Luckily both engines were in crap shape and leaking all over from previous owners, but definitely annoying.
At least I'll have perfectly fresh, rebuilt 550 and 350 engines while I'm still riding both of them.
Offline calj737
  • I refuse...
« Reply #9 on: January 09, 2014, 03:38:27 PM »
Z - you need to use oil, not just PB Blaster. Your engine may free up some once it fully cools, but oil from the top down (remove the plugs and squirt oil in, do the same at the tapper covers) is needed to help lubricate the metal parts.
PB is good, but oil is required. You may escape without tremendous damage, but certainly you've taken a few years of the engine. It happens to lots of people, so don't feel too stupid.
Offline zeech
« Reply #10 on: January 09, 2014, 03:39:50 PM »
Thanks, will do that as well calj! Yea oh well, live and learn.
Offline calj737
  • I refuse...
« Reply #11 on: January 09, 2014, 03:56:57 PM »
Can't be toast IF there was some oil in it, it seized quickly, but still moved "some". Probably locked up temporarily due to overheating and friction. Pamper it, whisper to it, use lots of oil, and see if it will come back.
Go easy on it too if starts. It's going to smoke, don't panic. It might clear up after a few minutes. But if it's REALLY clacking, shut it down quickly! Probably have damaged rod bearings or piston bearings. Save further damage and commence tear down. :-(
Offline fmctm1sw
« Reply #12 on: January 09, 2014, 04:37:59 PM »
There's no oil light on those old twins?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline zeech
« Reply #13 on: January 09, 2014, 04:40:03 PM »
Previous owner stripped the bike way down to pretty much nothing, which is fine, just dumb forgetfulness on my part, though I suppose that would have helped haha. Did too many things inbetween the gasket change and prepping to ride.
The tape trick or anything is a great idea as mentioned to prevent.
Offline 78 k550
« Reply #14 on: January 09, 2014, 05:04:41 PM »
You know for a fact? What a stupid comment.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline zeech
« Reply #15 on: January 09, 2014, 05:17:06 PM »
Definitely no ganja here. Was probably meant as a joke.
Offline 78 k550
« Reply #16 on: January 09, 2014, 05:28:02 PM »
Ya I know, but I don't like people using it in that manner. It gets me toasted.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline zeech
« Reply #17 on: January 09, 2014, 05:28:19 PM »
Agreed
Offline 78 k550
« Reply #18 on: January 09, 2014, 05:29:56 PM »
So have you found more out?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline cb650
« Reply #19 on: January 09, 2014, 05:44:12 PM »
[/quote]
 It gets me toasted.
Paul
[/quote]
 ;D
I got a nice 84 that way from someone at work.    FUBARED the rods/crank  though.
Offline fmctm1sw
« Reply #20 on: January 09, 2014, 05:56:01 PM »
WTH is ganja?
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
fendersrule
« Reply #21 on: January 09, 2014, 05:58:20 PM »
Paul
If anything, it can make you pay more attention to things. :) I'm with you Paul. Statements like that show ignorance.
Offline 78 k550
« Reply #22 on: January 09, 2014, 06:18:41 PM »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #23 on: January 10, 2014, 06:25:03 AM »
First thing that siezes on those is the cam bearings not the pistons unfortunately
« Reply #24 on: January 11, 2014, 09:32:43 AM »
I agree,have a look to see if you have a spare set of cam tower/bearings,camshaft & possibly a new cam chain.
The pistons/cyls. may still be ok...
