Author Topic: The Mikuni VM26 Thread.  (Read 5369 times)
Offline KrautKoffin
« on: January 12, 2014, 02:40:06 PM »
If you've got any info please post it here. I've done a lot of research on running these carbs on a 74 550, and it all seems to be scattered. I hope this thread will pull all of that info together in one thread. I picked up a set of vm26's off of a member here with adapter plates to achieve a true 'straight flow' intake system. It'll be a few weeks before I can get them broken down and cleaned, I was hoping to get some jetting guidance from the mikuni gurus of sohc4.
The build:
600cc cruzin image kit
MotoGPWerks pipe
Ported and polished head
+1 mm over valves
Knife edged crank
Anyone have aome ideas on jetting?
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Re: The Mikuni VM26 Thread.
« Reply #1 on: January 12, 2014, 04:53:03 PM »
I think I will be adding to the confusion. 8)  I just bought a set with adapters for a cb750.  Plus, I need to get used to tuning these things, so I have a clue with the Suzi's and Kawi's.  I am hoping to gain a tuneability advantage with the Mikuni vm26's, as there is no size advantage over stocker cb750 Keihins.  Seems like I read somewhere that Mikuni's venturi design tends to flow more air than a comparably sized Keihin...I post my questions and findings here.
Offline KrautKoffin
« Reply #2 on: January 12, 2014, 07:41:46 PM »
Much appreciated! If all goes well I'll pick up a set for my k7
74 cb550
« Reply #3 on: January 13, 2014, 03:27:56 AM »
Interesting details to read about Mikuni Carbs tuning
http://www.generalfiles.biz/go/154097798300
Offline KrautKoffin
« Reply #4 on: January 19, 2014, 11:32:38 AM »
Here's some pictures of the carbs I picked up off a member here and his adapter plates for the 550 platform:
The carbs weigh a metric ton and I'm surprised that there's no choke!
I need to read a lot more before trying to tune these.
74 cb550
« Reply #5 on: January 19, 2014, 12:34:39 PM »
Yeah those carbs do weigh a lot. There is no choke persay but an enrichening circuit!
« Reply #6 on: January 19, 2014, 12:47:40 PM »
They look like my VM29. I call it for choke. Give much richer and higher idle. Very effective!
Offline turboguzzi
« Reply #7 on: January 19, 2014, 02:16:37 PM »
indeed, chokes dont have to really choke... :)
BTW, the guy selling the RC cyl block on feebay has a VM26 set for  150$
« Reply #8 on: January 23, 2014, 10:06:05 AM »
I found a note from Kayaker43 when I was considering these carbs early on. He was using them on a 592 race engine.
mainjet 127.5-132.5
needle #5J9 raised 1-2 notches (stock needle 5DL31)
needle jet #08 (stock 04)
slide 2.5
pilot?
TG told me he ran a 140-145 mainjet in his 500cc, with the needle clip in the middle.
It surely doesn't pinpoint a baseline for you but before I tossed the note.... ;)  I can check what jets are in the set I have to compare. They were off a latter stock Z1.
Offline KrautKoffin
« Reply #9 on: January 23, 2014, 01:02:24 PM »
mainjet 127.5-132.5
slide 2.5
pilot?
Very much appreciated! I'm in PA till Sunday then I'm going to dig into my set. I noticed the carbs don't have any part numbers on them, how do I know that I have 26's and not 28's?
Turbo, I saw! There was also a set that went for $81 a few days ago.
74 cb550
« Reply #10 on: January 23, 2014, 01:56:30 PM »
Measure the throat. The 26's are actually a little larger than 26mm.
« Reply #11 on: January 28, 2014, 05:57:56 PM »
I got around to mocking up my vm26's on a cb750k4 parts bike.  Everything fits pretty good.  Managed to get the stock pull throttle cable to work with some fairly radical re-routing.  The stock push cable won't work at all.
Bwaller pmed me the Motion Pro part numbers of the cables he used successfully on a 550 racebike with low bars.  He was also using a non stock throttle assembly but he thinks a stocker would work with the same cables.  Actually, I think I will just cut and paste his whole pm, 'cuz it has some good info...
Good morning,
Looks like you're in the "cold zone" again...been an old time cold winter.
I read on Rons thread your question about cables. My original plan was to use the VM26's on my racebike so I went through the cable deal. I ended up with a set of VM29's but cables are likely similar. I found that MotionPro cables (pull-#01-0233 & push #01-234) are made for Mikunis. At least they work perfectly with the smoothbores. I use a Motionpro throttle housing and re-work an R1 throttle sleeve for 1/4 turn but I bet these will work for the stock Honda throttle as well. These cables are very good quality.
I'm not sure what you'll find with the VM26's (closer to 27mm) on a 750. If it's disappointing consider WiredGeorge.com. He has given up paying crazy money for 29 smoothbores in favour of oval boring the 26's. He claims he has worked out any issues & they flow very well.
Brent
« Last Edit: January 28, 2014, 06:01:01 PM by seanbarney41 »
Offline KrautKoffin
« Reply #12 on: January 28, 2014, 06:13:57 PM »
Awesome, thanks! I'll end up with those cable and low bars for sure
74 cb550
Offline Drummer
« Reply #13 on: December 05, 2014, 06:57:25 PM »
What boots did you use to mount those VM 26's on the 750 ? I got a set and am trying to figure out whether there is a way to get it done without a lot of money.
« Reply #14 on: December 05, 2014, 07:20:33 PM »
I think they are aftermarket adapter boots.  That is all I know as I bought the carbs with the boots used.  You could try pming member 23tbucket, as that is who I bought these from.  I have not seen him around here in quite some time though.  Also, there are a few other members running vm29's on 750's, PeWe comes to mind, and they may know a source for boots.
« Reply #15 on: December 05, 2014, 08:37:19 PM »
Sudco has boots, check with Z1 Enterprises too. Jeff is a member here. Also maybe Dynoman.
Offline Lostboy Steve
« Reply #16 on: December 13, 2014, 10:58:27 AM »
Are those adapters mass produced?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #17 on: December 13, 2014, 11:58:51 AM »
I doubt they are. They look suspiciously simular to the adapters I made for CR26 carbs.
Offline 750cafe
« Reply #18 on: December 15, 2014, 09:55:31 AM »
15 or possibly 17.5 pilot jets, needle jet set on the center clip, 105 to 110 main jets depending on altitude and exhaust system back pressure.
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
