Author Topic: what would cause this  (Read 1282 times)
Offline MIKE550/4
« on: January 13, 2014, 01:46:03 PM »
bit of background, bike has not been started in 30 years
Bike was stripped a few years ago and has since had powdercoated frame
on refitting the loom I found this bare patch
splitting the loom I found a green wire ( burned or rubbed not sure ) all I did with bike electrics was hook up the battery and test lights.
I am currently reading about wiring on the bike and been told earth wire fault or rubbing.
Now at rebuild stage of the bike and want to go through the electrics soon .
Total newbie to electrics so please talk in easy language
another pic after I split loom to look further 3-4 inches I think melted
so question is what would have caused this, the section is just before the connections which sit on plastic inner rear fender
« Last Edit: January 13, 2014, 01:55:31 PM by MIKE550/4 »
Re: what would cause this
« Reply #1 on: January 13, 2014, 01:52:32 PM »
it looks as though it was rubbed away....
Offline MIKE550/4
« Reply #2 on: January 13, 2014, 01:56:09 PM »
edited to show 2nd pic
« Reply #3 on: January 13, 2014, 02:07:39 PM »
wonder if it continually grounded itself against the frame, melting the casing back....
Offline KrautKoffin
« Reply #4 on: January 13, 2014, 03:32:00 PM »
Looks melted to me. Recheck the grounds and clean up anything that even slightly looks out of the ordinary.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #5 on: January 13, 2014, 05:34:14 PM »
+1 melted.  Green = ground, that is puzzling.  How's the test of the harness?
Offline tlbranth
« Reply #6 on: January 13, 2014, 08:24:27 PM »
I'm with Flybox. I think it rubbed through and subsequently became a partial, albeit spotty, ground. The heat generated by the bad connection did the rest. If it was purely a meltthrough, I don't think the damage would be so localized. So if you wrap the bare wire or splice in a new piece, rewrap the bundle and make sure your grounds are good, I'd say you'd be good to go.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline bjbuchanan
« Reply #7 on: January 13, 2014, 08:27:57 PM »
I'm with flybox and Tl, rub then burn. It is just too isolated with no other clues/damage
« Reply #8 on: January 14, 2014, 12:10:22 AM »
someones hooked a battery back to front in its past,the earth wire always does that when polarity is reversed.
Offline trueblue
« Reply #9 on: January 14, 2014, 03:00:50 AM »
+1 or there is a power wire rubbed through/pinched to the earth wire and caused a dead short ;D
1979 CB650Z
Offline Bomberman
« Reply #10 on: January 23, 2014, 05:03:35 AM »
hi
so a newbie question, what sort of wire would you replace this with, is there a certain amperage wire i would ask for ?
Offline Bomberman
« Reply #11 on: January 23, 2014, 12:27:56 PM »
so am I right in thinking
http://www.autoelectricsupplies.co.uk/product/66/category/11
28/0.30, 2.0mm2, 17.5A - cable OD 3.3mm would be ok to replace the section of earth wire
Offline trueblue
« Reply #12 on: January 24, 2014, 03:54:37 AM »
I can't remember if these bikes use 2mm2 or 2.5mm2 wire. I was thinking it was 2.5mm2
1979 CB650Z
Black 750K8
« Reply #13 on: January 24, 2014, 06:39:35 AM »
Just get some 14 or 16ga stranded and you will be fine. If it were mine I would open the entire harness and subs.
