One of the bike mags reviewed I think the Ballistic. They were very impressed. They said that the bike could sit for long periods of time without a tender on it and still have ample starting power. As prices come down it becomes hard to come up with a good reason not to make the change if you need a battery anyway. It's probably the simplest way there is to shave 5 or 6 pounds off your bike.
+1 I have had a Ballistic battery on my bike (550) for about 3 years now. I go on super long rides at a stretch (4000+) and then don't jump back on poor Dash for months and months. I never keep him on a tender and he always starts right up (well not with a kickstart-I would pass out first--but never more than 2 tries on the electric starter). I love this battery--far better than the acid cell one which drove me crazy with having to add distilled water while I was riding across Nevada and Utah. Got rid of that the minute I returned from that ride.
Did you change out any parts of your charging system? I think as advised in this thread I might order up a rick's regulator. I don't know my system seems to charge well, I can't imagine what would happen if by accident you left your key on or something. I mean, IT NEVER HAPPENS, until that ONE day that it does. I'll be honest, I'm somewhat regretting this now. Btw apparently using this battery for a snowmobile is a bad idea as well.
Anyway, As Per The Instruction manual.
USAGE
a) There are a couple of damaging conditions for any Lithium starter battery,
they include prolong storage in high temperatures and allowing the battery
to be deeply discharged.
b) Compared to lead-acid batteries, the Battery Tender® Lithium battery has
less than 5% the average self-discharge rate and can be stored for much
longer periods without maintenance.
c) If there is no current draw from your vehicle when your ignition is off the
Battery Tender® Lithium battery can be stored for one year without
damage.
d) For long term storage the ideal temperature is 1ºC (34ºF).
e) The battery should be stored in a minimum charge state of 70%.
f) DO NOT use the battery in temperatures below -10ºC (14ºF).
CHARGING
a) Do not use a desulphation or pulse charger, doing so will damage the
battery and void the warranty.
b) Standard lead-acid chargers may be used, as long as they do not exceed
14.8Volts during charging.
c) Maximum charge rate is 10Amps.
d) It is strongly recommended the use of a lithium specific charger such as
the units in the Battery Tender® Lithium Charger series.
e) Do not allow the lithium battery to discharge below 8Volts as this will
damage the battery and void the warranty.
f) Do not charge the battery in temperatures below -10ºC (14ºF).
