Author Topic: Rebuilding the "rat racer"...  (Read 3922 times)
Offline KirkBurner
« on: January 18, 2014, 06:54:17 AM »
So.. here we are...
today I ripped out the engine with some help from a friend
As you all can see its winter..
so.. as the bacholer I am.. Im taking this to the 8th floor apartment I live in.
My plan is to do a top-end rebuild
polish things down, and get rid of a few major leaks
I am a Novice at best... so hopefully I can get some educated feedback from you guys on how to fix this within 1st of may
« Last Edit: January 18, 2014, 06:59:00 AM by KirkBurner »
Re: Rebuilding the "rat racer"...
« Reply #1 on: January 18, 2014, 07:03:39 AM »
When is it not winter in Norway? ;)
That seat could use a new cover too.
Offline KirkBurner
« Reply #2 on: January 18, 2014, 07:42:57 AM »
True true... But we should get bare roads in May I hope.
as for the seat.. Yeah I know, but thats part of the rat look.
But I have a plan for that aswell...getting a sewingmachine and use the same threadcolor as the frame... and use black marine vinly for the rest of it...
« Reply #3 on: January 18, 2014, 08:48:53 AM »
Good idea.  The seat has a good shape -- it just needs to be re-upholstered.
MAY!!?? It's 80 degrees today here.  That's 26.6 Celsius.
Offline iron_worker
« Reply #4 on: January 18, 2014, 08:55:00 AM »
Is that an elevator? That would make things easy. I had to carry my bike up the stairs to my 3rd floor condo. ha
IW
Offline Ewan 500K1
    • Adams Bros Probe 2001
« Reply #5 on: January 18, 2014, 09:11:57 AM »
that's a fancy toolbox for a novice  :o ;D ;D
jings, crivens, help ma boab
500 four K1 cafe racer build thread at :
http://forums.sohc4.net/index.php?topic=100883.0
Offline kerryb
  • Not a very
« Reply #6 on: January 18, 2014, 07:21:00 PM »
Remember...he's a bachelor, that's his dresser!
Offline KirkBurner
« Reply #7 on: January 19, 2014, 06:33:57 AM »
So I took off the cam cover
The camshaft has the markings "norris RX2 AJ #56" I tried googleing it and it didnt give much of a result..
anyone know what it is... or what a PO has done with it?
Offline KirkBurner
« Reply #8 on: January 23, 2014, 02:21:51 PM »
So as it is I was very lucky today... I have been searching the net to find specs on that carb..
Went and found some Norwegian Cafe guys...
and one of them he had a book he got way back in the days... He really made my day...
and there its was listed as a Hot Street/Roadrace cam ideal for 836 bigbore.
with a lift of .381"/.357" and a duration of 290/280 degrees...
so I ripped out the camshaft..
That last picture.... that where I spot the most wear.. is that considered alot?
Offline KirkBurner
« Reply #9 on: January 24, 2014, 02:42:23 PM »
teardown continues...
Finding only copper gaskets...
Boresize is 63,6...
