Author Topic: Vintage Speed Part Mashup - 1976 CB750F  (Read 84334 times)
Re: Vintage Speed Part Mashup - 1976 CB750F
« Reply #100 on: January 09, 2015, 04:17:11 PM »
Here's a shot from a different angle. You can see the damage at the top of the body; I'll probably have to take a hacksaw to it to get the adjuster off.
Offline slikwilli420
  • Master of Disaster
« Reply #101 on: January 09, 2015, 04:21:41 PM »
Good eyes on the difference. Damn that thing is roached. I'll keep this one on the back burner to see if another one pops up or I can get mine repaired as Tintop suggested.
« Reply #102 on: January 09, 2015, 04:54:29 PM »
You can have it, including shipping, for a $10 donation to the forum, and I'll include the upper "C" spring retainer. ;D
« Reply #103 on: January 09, 2015, 04:56:09 PM »
I'll take you up on that just for the sake of spare parts. Thanks! !
Offline Godffery
  • Godffery's Garage
« Reply #104 on: January 28, 2015, 07:18:06 PM »
I'm interested in the damping rod if it's not badly pitted.
« Reply #105 on: January 28, 2015, 08:02:33 PM »
The rod appears to be in decent condition, but I haven't inspected it closely or checked for bending. I have no clue how the damage to the body happened... :o
Offline Godffery
  • Godffery's Garage
« Reply #106 on: January 30, 2015, 11:17:11 AM »
Hard to say, but my bet would be on "User Error".
LMK when you get a chance to give it a good look over and how much you want for it shipper to the address below:
Thank you,  Godffery
Godffery’s Garage
http://tinyurl.com/yfrw4fc
8010 Gateway Drive,
Burlington WI. 53105
Jstephens7@wi.rr.com
262-210-9269
« Reply #107 on: February 01, 2015, 03:24:31 PM »
Finally had some time to come up with a unique way to mount the gauges. Still needs a bit more work but this is the basic idea.
Also got to work mounting the tail light seanbarney41 was gracious enough to donate to the project. I wanted a recessed look so it didn't stick out quite so far. The edges of the cutout in the tail will get some neoprene rubber trim to make it look more finished and frame in the light nicely.
Also, thanks to Jim F for the great laser welding work he did on the shock adjusting collars for my Marzocchi shocks. His work will give them a new lease on life.
Offline Godffery
  • Godffery's Garage
« Reply #108 on: February 11, 2015, 08:54:28 AM »
 slikwilli420; WOW, Nice job with the Gauge mount!
scottly; Got the Damping rod, Tanks!  I'll LYK when I have the Phenolic piston blanks.
« Reply #109 on: February 11, 2015, 09:04:52 AM »
Thanks Godffrey! I wanted to do something simple but different from other versions. I think it also lends itself to the vintage feel I am shooting for.
Offline Godffery
  • Godffery's Garage
« Reply #110 on: February 11, 2015, 10:57:58 AM »
  I'd say you nailed it.
« Reply #111 on: June 12, 2015, 08:15:09 AM »
Well, I have been on hiatus for the last few months, due to my newest project, our first child. Anyone with kids will remember their first and knows that it takes a ton of work the first few months but is well worth every second.
Now that I am sleeping through decent chunks of the night and my life has settled some, I am back at it.
I received the tastiest of packages from our friend and JMR Porting, which includes a stage IV head that shines like a jewel, as well as a Wiseco 836 kit and some Cycle X rods. It was a big cash layout but I know it will be well worth it in the end. The upsides is that the largest single outlays of cash should be behind me as I work from the top down on this engine build.
As I get going on the build again, I have turned focus to a few nagging items. First is getting all the aluminum parts that I have made ready for hardcoat anodizing. I am sold on hardcoat simply because it is not a decorative finish like regular anodizing, and since most parts would be black anyway, it seems like a no brainer to go with hardcoat, enhanced with black dye. Parts that will be black hardcoat include the rear caliper mount, rear master cylinder mount, all front brake mounting brackets, the Weber intake, rearset brackets, and engine mounts both front and rear.
I had to pull the engine to do a leaky head gasket which is now done, so its time to finish up the frame by getting all the gusseting/bracing finished up and mounting the AP Racing rear master. Once I get some paint on to cover the exposed areas, I can continue my mock up build. My plan is to get this thing vetted over the next year before I go to final paint/powder. I hear of too many guys who build their dream bike in one go then remember that one bracket that costs them days of downtime and new powder on the frame.
For the front end, which is shaping up to be my favorite part of the bike, the only thing left is axle spacers. Those too will be black hardcoat anodized. Beyond that I will need to figure out what to do with brake lines. I can either do two full-length lines from the master to each caliper, or do one short one to a splitter and a line to each caliper from there. Finding a place to mount the splitter that doesn't clutter things up is my main concern. Probably going with two full-length lines.
On the rear, I have powder on the Marzocchi shocks, and the rebuilds are ready to go in with fresh oil. All that is holding that up is getting a few pieces refinished, like the adjuster collars and top spring retaining collars. This damn hardcoat anodizing is causing quite the bottleneck in my project!
Other things to button up are getting some upholstery on my seatpan and getting the tank cover, seat in at least the same color of primer so I don't look like a complete idiot.
Though the list is long I am shooting to get a rideable bike before the sun sets on summer here in Michigan.
More to come (pics too!) as I get moving on this again.
« Reply #112 on: June 12, 2015, 09:10:11 AM »
Hard anodizing, I had done tends to look a bit frosty or textured..may not always be the case.
...but..if so..I would lean toward soft anodize for wheel spacers that turn inside a seal.
 Brake lines..I think the dual lines, or the stock splitter, look low end on a custom bike.. And the worst one.. Is single line to first caliper, then a U shaped line going over to second caliper.
Spend a few bucks and use a tee and forged fittings, or build a junction block out of aluminum and drill/tap to use NPT- AN3 fittings. And I think AN fittings to hose look way better than banjo fittings.
I ran my line thru the triple tree, then Had a tee below it, and forged 45 degree fittings, from the tee to the calipers.
 Will try to make a diagram.
« Last Edit: June 12, 2015, 10:47:13 AM by 754 »
Offline Godffery
  • Godffery's Garage
« Reply #113 on: June 12, 2015, 10:03:24 PM »
 Good to see the project is back on the move!
Some get to the "Kids Stage" and never get back to there old buddy, Mr' Motorcycle.   = ]
« Reply #114 on: June 18, 2015, 11:39:14 AM »
Yes, its definitely good to be back!
Frank, after looking at your drawing I was at a bike show this weekend and saw a setup that was quite impressive, as seen in the first two pictures. I am contemplating this approach or one that uses an aftermarket splitter, like the one here:
https://www.denniskirk.com/goodridge/universal-front-brake-tee-pmchd-024bk.p271527.prd/271527.sku
I do like the idea of minimizing banjo bolts. Goodridge also sells the 3/8-24 to -3AN adapter that will be necessary for both the front and rear master cylinders and calipers. The tee up front may end up with banjo fittings but that remains to be seen.
I finally got the rear master mounted on its bracket and the tab welded to the frame. I have a parts order in at Fast From the Past for some linkage parts to complete the assembly.
I will also be picking up the front wheel spacers from the machine shop today, which should complete fabrication on the front end. I will also be dropping off the stainless rod for the engine mounting bolts, which will be threaded and fitted with 12pt ARP nuts. One end will be welded like a bolt head to its less of a cumbersome assembly.
The last pic is the rear motor mount. It is a riff on the one Doctor D has on his bike. I am still working on the design and may have another one water jetted before it goes out for machining.
« Reply #115 on: June 18, 2015, 11:55:31 AM »
Joker Machine's triple trees have a similar set up with the brake line fittings.  There's a pdf of the tree dimensions.
Every once in a while, you poke this thread up again and I realize how much l like it again!
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #116 on: June 18, 2015, 12:18:35 PM »
i used the lower tree as the brake - t as well on my digger build
...Save a tree, eat a beaver...
« Last Edit: June 18, 2015, 12:22:06 PM by Medyo Bastos »
« Reply #117 on: June 18, 2015, 08:29:57 PM »
Have fun with the motormount, they are quite a bit of work...I made the one for Doctor D..
The Tee in the tree is nice and clean,  but going thru the stem is even cleaner.
You can still do it with the tree.. Driil small hole thus stem, and machine a gloves on the press fit part of the lower stem. Then drill and tap the tree with the holes intersecting to meet the groove..a wet stem......
« Reply #118 on: June 18, 2015, 09:47:48 PM »
Yep, Frank is The Man who made those killer mounts for Doctor D and a set for me!
  • Gusto mo titi ko?
    • project
« Reply #119 on: June 19, 2015, 06:14:28 AM »
that is how mine is. single short cable on top of lower tree to m/c, and 2 short cables underneath straight shot to both calipers
« Reply #120 on: June 19, 2015, 06:52:45 AM »
Cal/Medyo, would something like this work for the top like Cal suggested?
http://www.jegs.com/i/JEGS+Performance+Products/555/63042/10002/-1
I don't know a lot about fitting for hard lines. What type of fitting does this need to thread into? My master cylinder up front is a vintage AP Lockheed that has a 3/8-24 threaded hole. Since these aren't NPT threads I would think that a copper washer was needed. I still really like the idea of the integrated brake tee on the bottom triple tree. I will see what I can do to have as clean a look as possible.
My initial thought is to use -3AN to 3/8-24 fittings mated to soft lines to eliminate all the banjo fittings/bolts.
My other question is about adapting brake light switches to the front and the back. I don't care for the brake switch banjo bolts since they look unfinished.
« Reply #121 on: June 19, 2015, 08:24:10 AM »
It won't work unlesd you have a seat at proper depth like stock caliper..
And you can't run a washer unless the hex portion is bigger, to form an even surface to bear hard enough. On the washer to seal.
 Just search for 3/8-24 to AN-3........straight adaptor.
« Reply #122 on: June 19, 2015, 09:02:56 AM »
Frank, I found the adapter which I plan to use, but I like Cal's idea of a hard line from the master to the lower tree. How would I make that work?
« Reply #123 on: June 19, 2015, 09:15:18 AM »
What's wrong with. Braided top and bottom?
« Reply #124 on: June 19, 2015, 10:44:11 AM »
Nothing wrong at all. It's probably the way I will go but always looking at other options. A hard line sounds different and interesting.
