Author Topic: Speedometer is s-l-o-w to respond  (Read 7025 times)
Offline gar
  • '75 CB550
« on: September 05, 2006, 08:06:48 PM »
Hello, and on my '75 CB550K the speedometer seems to lag behind--taking its time to move around the dial and point towards indicated speed, and it seems more pronounced under acceleration.   In other words, the needle moves slowly up to speed, and it is quite noticeable after rapid acceleration.  It's like watching a bubble rise in a bottle of honey, its that slow.  Any ideas?
Don't use a big word where a diminutive one will suffice.
Offline MikeDeB
Re: Speedometer is s-l-o-w to respond
« Reply #1 on: September 06, 2006, 03:50:59 AM »
Yep.  It's possible the grease in the grease cup has dried up somewhat.  The grease cup is on the shaft that is connected to the speedometer needle.  In all the speedos and tachs I've taken apart I've, fortunately, found adequate lube on the shaft pivots so I never had to solve the problem of getting new lube into the grease cup.  Sorry I couldn't be more help.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
yzfrider
« Reply #2 on: September 06, 2006, 09:42:49 AM »
You might also check the speedo cable - if it is original - I would replace it.  These are readily available.  When my speedo started to go south, I was getting all kinds of advice to take it apart and lube it.  Before doing all that, I replaced the cable - speedo works great now.  YMMV.
Cheers!
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #3 on: September 06, 2006, 11:02:09 AM »
Ditto to that.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
jhaa_lives
« Reply #4 on: November 05, 2008, 05:16:51 AM »
So this is exactly the problem I'm having.  I'll take my "cup" off and clean it up.  I already installed a new cable.  Does anybody know if this fixed the problem?
Sometimes it's nice to give resolution to these "fixes".  It helps when searching the archives.
Offline gregk
« Reply #5 on: November 05, 2008, 07:54:44 AM »
I had similiar problem with a tach.  Read somewhere on the forum to try rinsing the unit in Isoproponal alchohol 99%.  This worked and the tach wasn't "lazy" after the bath.  Alot easier than taking the unit apart.
Greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
Offline heffay
« Reply #6 on: November 05, 2008, 08:31:55 AM »
when i have this problem... i twist harder.   8)
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #7 on: November 05, 2008, 10:43:29 AM »
Greg
+1 I did that too, to 'wake up' my tach. I used 'denatured alcohol solvent' (basically 100% methanol) from Home Despot, and rinsed the internals a couple of times. Washed all sorts of gunk out and didn't leave any film on the glass or anything.
That solvent is great to have around for a variety of tasks, anyways, like de-greasing stuff.
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
