Author Topic: engine gasket  (Read 654 times)
Offline donny
engine gasket
« on: January 24, 2014, 01:01:27 PM »
 I am removing the leaking base gasket,
any tips on how to scrape off the old gasket without  material getting into
the crankcase?
 I stuffed the holes with rags but I can see it would be very possible for crap to still get down below
and I don't want to crack the cases.    :-\
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline calj737
  • I refuse...
Re: engine gasket
« Reply #1 on: January 24, 2014, 02:31:32 PM »
Soak them REALLY well with Permatex gasket remover first. Then, while you work, protect the cylinders and use a shop vac to catch the debris.
If you do get some falling in, drop the oil pan, and flush the engine with Diesel to aide in purging the debris.
Offline bjbuchanan
Re: engine gasket
« Reply #2 on: January 25, 2014, 02:36:06 PM »
the crankcase?
I use an exacto knife with the scraper blade. It is very flexible so it gets under the gasket easy and doesn't really bite the surface.
It doesn't take as long as it would initially seem. It helps to get the material "wet" with some thinner or something
Offline Anton
Re: engine gasket
« Reply #3 on: January 26, 2014, 09:27:03 AM »
why diesel calj?
Offline calj737
  • I refuse...
Re: engine gasket
« Reply #4 on: January 26, 2014, 09:29:35 AM »
Diesel is a solvent and lubricant in one. You can buy it inexpensively and flush the case really well. Whatever residue remains won't damage the seals or bearings as some other solvents may. It's also a bit more viscous than standard solvents.
Offline Anton
Re: engine gasket
« Reply #5 on: January 26, 2014, 09:30:47 AM »
good to know, thanks!
