Author Topic: New rim time?  (Read 2371 times)
Offline heyitsrama
New rim time?
« on: January 24, 2014, 04:46:29 PM »
Howdy,
Got early off work today and started working on my time to hopefully get the tires fixed and ready to go ASAP. I wanted to run it by some of you guys how the rim looks and weather it would be worth attempting to derust/powder coat them, or just get new ones all together.
The front is almost the same. The hub looks fine.
Unless someone has black rims for a 500 they wanna get off their hands  ::)
Thanks for the help!
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline tlbranth
Re: New rim time?
« Reply #1 on: January 24, 2014, 05:02:50 PM »
Had the same thing after my bike sat for 25 years. I wasn't planning on coating them so I got a new front rim and used my original rear which had been swapped out for a 16" (mistake) in the 70's. Never relaced wheels before but it's really not that hard. Just takes time and patience. One thing I do to preserve the wheels is wire-brush the insides and paint them with primer. Most recently, my neighbor painted them with 2-part epoxy automotive primer. That should keep rust away for a while. In the old days I just used spray primer and re-wire brushed and painted as necessary at tire changes.
To answer your question, I'd put on new rims.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline heyitsrama
Re: New rim time?
« Reply #2 on: January 24, 2014, 05:15:33 PM »
19 front and 18 back? God this is gonna be so expensive after getting spokes and new tires too :(
72' cb500
Offline LesterPiglet
  • 1977 CB550F2
Re: New rim time?
« Reply #3 on: January 24, 2014, 05:18:38 PM »
I would derust with a brush and paint with something. I used Smoothrite on mine.
http://www.lawson-his.co.uk/hammerite-smooth-finish-paint-c1074
I believe you have a similar product across the pond.
Offline heyitsrama
Re: New rim time?
« Reply #4 on: January 24, 2014, 07:00:41 PM »
about to pull the trigger on new rims.
19- 1.85" front
18 - 1.85" rear
but theres one issue, that is that the older wheels that i have are
19-2.75" front
18 - 2.75" rear
what gives? am i measuring from the wrong spot?
oh good god tires and spokes are going to kill me.
 8)
72' cb500
Offline heyitsrama
Re: New rim time?
« Reply #5 on: January 24, 2014, 07:28:44 PM »
I've been slowing doing it with a soda blaster imma take it to a shop and see how much they gonna charge, for both. Blasting and powder coating, could you see of you have those rims still?
72' cb500
Offline 750cafe
Re: New rim time?
« Reply #6 on: January 26, 2014, 08:35:45 AM »
19- 1.85" front
18 - 1.85" rear
19-2.75" front
18 - 2.75" rear
 8)
Are you measuring at the bead or the out side edge. BIG difference.
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
  • 1977 CB550F2
Re: New rim time?
« Reply #7 on: January 26, 2014, 09:28:18 AM »
Front and rear rims are two different widths.
Offline Mini Mo
Re: New rim time?
« Reply #8 on: January 26, 2014, 10:27:48 AM »
You can save those rims if the chrome on top is decent. The rims off of my K1 were much worse than yours.
Go to the hardware store, buy some phosphoric acid from the paint section and a pint or quart of rustoleum primer. Pick up some cheap dollar brushes and rubber gloves. Next go to the dollar store and get a plastic tray, something at least 2"-3" inches deep. The deeper the better. You shouldn't have to spend much more than $30
You want about a 60/40 mix of acid and water in the tray. Dip your rim in there and just let a section sit for several hours, rotating it just enough to get the next section wet. The longer the better if you have the time. Eventually the rust will start dissolving. As you start seeing less and less rust take your wire brush and start brushing the rest of the rust off while it's wet. Once all the rust is gone brush on the rustoleum.
This will take some time, probably days but it works and it's a lot less hassle the sandblasting, grinding etc. I have been de-rusting parts like this for years. Right now I have some badly rusted pipes soaking in a small 10 ga. trash can. This photo shows the difference after soaking half the pipe for 1 day. This will not harm the chrome in any way and as a bonus if you have rust on the tops it will eat that up also.
Hope this helps
750 K1 (Just finished)
750 K4 (In Process of resto)
2) 750 K6's (Restored and sold)
750 K5 (Restored and sold)
'75 850 Norton Commando (Restored and sold)
'99 Triumph Tiger (Daily rider)
Offline tlbranth
Re: New rim time?
« Reply #9 on: January 26, 2014, 05:27:32 PM »
Mini - looks like you replaced the spokes though
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline skidooextreme
Re: New rim time?
« Reply #10 on: January 26, 2014, 05:41:35 PM »
Pinsol does the same.....obviously more expensive for the quantity but Costco sells it cheap
Offline Stoli
Re: New rim time?
« Reply #11 on: January 26, 2014, 05:46:13 PM »
Getting a rim (without spokes) blasted and powder coated should cost less than $75. Maybe around $125 if you have them do the entire wheel (hub, spokes and rim). If that is your plan, don't waste your time with the rust removal since the blasting will take care of that and the pc will cover the inside as well as out, so no need for primers, etc.
The question is, how much metal has been eaten away by the rust. Can't tell from the pics. If the spoke holes are solid and you still have some meat on the rim where the worst rust spots were, then you should be fine. If the outside of the rims are pitted, the pc surface won't be perfect but I've had some pretty bad rims powder coated and they came out looking good to me.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Mini Mo
Re: New rim time?
« Reply #12 on: January 26, 2014, 11:43:15 PM »
I did rebuild both wheels and replaced all of the spokes so yes, I stripped them down first. Just to clarify, do not lay the rims down, put them in the upright position
Or... Just go to the Z1 site and order 2 new DID rims for less than $200 and 2 sets of spokes for less then $100. The spokes they sell are made in Japan and are great quality. Have used them on several bikes
Re: New rim time?
« Reply #13 on: January 26, 2014, 11:58:54 PM »
i think your rims look plenty solid?ive seen and used worse,new rims and spokes are always nice though?
Offline heyitsrama
Re: New rim time?
« Reply #14 on: February 05, 2014, 12:32:19 AM »
doh! i wish i came back to this thread before i ordered new rims.  :( i still need to get spokes, was thinking of going with buchanan's but for some reason they only have 750's? nothing for 500?
The rim is two different widths?!
whats going on here? the bottom one is the rear
for the new rims i got the DID ones with 19 for front. 18 for rear. just waiting on the rear one to come in.
Ill try to finish refurbing the hubs this weekend
anyone know which spokes from buchanan to order? also thinking about new bearings for the tires... any recommendations?
thanks y'all. almost done with the bike hopefully by end of march.
72' cb500
Re: New rim time?
« Reply #15 on: February 05, 2014, 12:37:37 AM »
Sure they do, look here...
http://www.buchananspokes.net/products/spoke_kits_honda_cb.asp
I would call them to confirm you are ordering the correct spokes.  I just received a set for a wheel I am rebuilding on my K4.
Offline heyitsrama
Re: New rim time?
« Reply #16 on: February 05, 2014, 12:44:03 AM »
for the rear it says "Spoke kits for CB 750 REAR DRUM or DISC hubs - 40 count"
do all the cb series have interchangeable rear rims?
Ah now i have to measure the nipple size..... need ruler...
Deep Drop vs Shallow Drop?
72' cb500
Offline lucky
Re: New rim time?
« Reply #17 on: February 05, 2014, 04:38:48 PM »
Howdy,
Sand blast the rim and get it powder coated, then get new stainless spokes.
Or just send your hub to Buchanans.
Offline 78 k550
Re: New rim time?
« Reply #18 on: February 05, 2014, 04:52:17 PM »
or try Woody's Wheel Works in Denver.
I think a new rim last time I checked was 100.00
I think I have a front rim looks like new pm me.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
