Author Topic: Considering a 2 into 4 carburetor set up, any suggestions?  (Read 907 times)
Offline bluefly329
« on: January 24, 2014, 06:44:13 PM »
I have found a 2 into 4 carburetor manifold and carb upgrade set up from cycle xchange's website, but it says,"not recommended for stock frames". Has anyone done this and what troubles did you experience?
Offline mrbreeze
  • Not your average
Re: Considering a 2 into 4 carburetor set up, any suggestions?
« Reply #1 on: January 24, 2014, 07:06:23 PM »
I haven't done it but I know you can't fit air cleaners with a stock frame. I knew a guy that had it on his chopper. It ran good but was a bugger when cold. I'm not sure what his state of tune was but it ran good once warmed up.
MEMBER # 257
Offline donny
« Reply #2 on: January 24, 2014, 07:29:38 PM »
  go here;   http://www.hondachopper.com/
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline jamesb
« Reply #3 on: January 24, 2014, 07:38:28 PM »
There was a guy I ran into at a show he had them on his cb750 he had to modify the frame and side cover to have them fit properly. He cut the frame and rewelded it seems like a lot of trouble that has caused a lot of problems for some. Another person I would see at a swap meet was selling his acts the third meet he was down to $150 for the complete setup. That's when I knew they must not be worth a crap.
Offline mrbreeze
  • Not your average
« Reply #4 on: January 24, 2014, 08:41:19 PM »
Thats hella cheap. They go for a bunch more from Cycle-X.
MEMBER # 257
Offline 750K
« Reply #5 on: January 25, 2014, 11:29:24 AM »
Talked to cycle-x about them awhile back, the frame tubes on a stock bike are right over where the throttle cables enter the top of the mikuni carb. Works great on a hard tail though, I know a guy with a set on a chopped cb900. He likes them a lot, that bike is a monster.
77 Cb750, 78 Kz1000
Offline kghost
« Reply #6 on: January 25, 2014, 12:14:01 PM »
I'm not sure its much of an upgrade....
Why do you want them?
Stranger in a strange land
Offline Stoli
« Reply #7 on: January 26, 2014, 04:43:40 PM »
Here is a project thread with good details of how a frame was modded to accommodate the 2 to 4 carb setup.
http://forums.sohc4.net/index.php?topic=90740.0
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline lucky
« Reply #8 on: January 27, 2014, 06:48:48 PM »
That would be a 4 carb (stock), modified into a 2 carb set up.
