Author Topic: Quick Grip Question  (Read 3275 times)
Uncleben89
Quick Grip Question
« on: March 21, 2007, 01:03:11 PM »
Replacing handlebars and all attached components on the '76 550K.
Do you guys use 1" grips to fit over the throttle tube?
The 7/8" grips I bought could not even be forced over it.
Offline Gordon
  • 750K1, 550K2
Re: Quick Grip Question
« Reply #1 on: March 21, 2007, 03:37:52 PM »
Every set of grips I've bought has one with a slightly larger diameter opening for the throttle grip.  Never measured it before, but it's probably about 1".  Did you possibly buy grips that were made for a snowmobile or ATV that use a thumb throttle?
Uncleben89
« Reply #2 on: March 21, 2007, 04:38:13 PM »
Marketed as cruiser grips. "Will fit most bikes and scooters with 1" or 7/8" bars."
http://store.azmusa.com/gadegr.html
Don't buy these.  I measured, same ID.  These do not come with the throttle tube inside as they are shown.
Offline medic09
« Reply #3 on: March 21, 2007, 05:21:40 PM »
Did you contact the seller?  Sounds like there's a mistake somewhere...
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline mkramer1121
« Reply #4 on: March 21, 2007, 05:55:34 PM »
Get some baby powder and go to work.  Coat the inside of the grip and work it on.  The rubber will stretch.  It took awhile before the set of grips I bought would fit over the throttle tube, but eventually it did, and now it won't come off.
« Reply #5 on: March 21, 2007, 06:08:40 PM »
I used soap and a touch of water and was able to muscle mine on.
Offline c_kyle
« Reply #6 on: March 21, 2007, 06:44:06 PM »
7/8" grips.  I looked at like 20 pair at the dealership and they all had the larger inner diameter for the throttle tube.  I ended up buying a set of Pro Grips; they're all right I guess.  My damn right hand still aches after just a few minutes.
Izanami, my 1979 CB650Z:  Clicky
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #7 on: March 21, 2007, 07:11:34 PM »
I was about to say "heat them up" until I looked at the link and realised they have chrome rings on them.  Is it the chrome ring binding or the rubber grip hanging up?
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #8 on: March 21, 2007, 09:34:26 PM »
I think hair spray works too.  Slip then on when wet easily and when they dry, they are on there ;D
Uncleben89
« Reply #9 on: March 21, 2007, 10:08:18 PM »
Initially, I thought lubing the inside of the handlebars was a poor idea because I needed friction (or glue) to bind them together.  So I started working them together dry.  After about half an hour I was halfway in and absolutely stuck.  (man, this really sounds suggestive)
The problem was the incredible friction between the dry rubber and the dry plastic.  For an hour I tried to get them apart by any means.  Tried to use light and heavy lubes, but they could never reach the middle where the binding occurred.  I just bought the NOS throttle tube, and I'm not about to break it, so I tried to slip a screwdriver in between them to release part of the binding/pour in lube.
Screwdriver ripped through the rubber side.
That's the story, and I think force might have succeeded if there was lube present.  Also, being as tight as it is, there would be no problems with the grip slipping around the slide during operation.
I like the hairspray idea, but worry that it would set before I could get it in... then the same old problem would come up.
Two possible scenarios:
Manufacturer shipped two clutch-side handlebars
or
I'm an idiot.
I'm not sure which I prefer.  Thanks for the advice, I was about to punch myself in the face out of frustration before posting.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #10 on: March 21, 2007, 10:35:50 PM »
I've done the hair spray bit a couple of times. It's actually really slippery for quite long enough to slide them on. Sets in about 10 Min's.
Works great.
« Reply #11 on: March 21, 2007, 11:53:39 PM »
I've always put grips on with plain water.   ???
Offline medic09
« Reply #12 on: March 22, 2007, 05:20:21 AM »
Sorry for your frustration.  We've all been there, and will be going back... :D.  Isn't that what we're doing here?
Some folks use WD-40 with success.  There was a post about this.  I'd still contact the vendor.
Mordechai
'78 CB750K
Santa Fe, NM
Offline c_kyle
« Reply #13 on: March 22, 2007, 07:04:10 AM »
Rubbing Alcohol works like a champ.  Pour some in a spray bottle, spray a little in the grip and it slides right on.  It dries in a few hours and you're ready to go.
kettlesd
« Reply #14 on: March 22, 2007, 12:04:38 PM »
Works great.
Yup, hairspray works like magic.
« Reply #15 on: March 22, 2007, 01:47:44 PM »
How is it to remove grips installed with hairspray?  Are such grips installed in this manner the ones I have had to cut off?
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #16 on: March 22, 2007, 02:39:52 PM »
I installed my grips with grip glue.  A small dab inside the grips, twist them on, make sure they are straight and let them dry.  Perfect and easy and they won't roll or pull off.  My grips are the Pro Grip sportbike grip with open ends.  The throttle grip was just a bit bigger (inside diam.) than the left side.  At $6 it was a steal.
Sparty
« Last Edit: March 22, 2007, 02:42:17 PM by sparty »
1972 CB750 K2 Cafe' Style
Offline Gordon
  • 750K1, 550K2
« Reply #17 on: March 22, 2007, 03:11:01 PM »
Hairspray is not superglue. ;D  Once you break the seal they come off the same as they would with no adhesive.  I normally use the air compressor to slightly inflate the grip and release it from the handlebar.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #18 on: March 23, 2007, 08:02:38 PM »
Yup.  ;D
Offline mrbreeze
  • Not your average
« Reply #19 on: March 23, 2007, 08:43:29 PM »
Sparty
Those look like the same grips I got. I like them although I was looking for a set of the old donkey dicks. I guess they don't make them anymore. I used to have those on my Z bike and they were by far the ones I liked best.
MEMBER # 257
jsaab2748
« Reply #20 on: March 24, 2007, 06:34:14 AM »
O.E. grips actually have different part numbers from side to side. I muscled mine on dry and they worked out good. The aftermarket ones must have kind of a "generic" sizing to them.
