Author Topic: CB750 F Word 3  (Read 10682 times)
Online seanbarney41
Re: CB750 F Word 3
« Reply #25 on: January 29, 2014, 06:38:14 PM »
I've never used one like that, Steve-O.   I did bust out the vacuum pump for a while and it didn't seem to help.  It seems like, with your link, unless you got a pretty bulletproof conection to the caliper, that thing could get real messy.  Let me know how it works.
Offline MoMo
  • Ride like you're invisible
Re: CB750 F Word 3
« Reply #26 on: January 29, 2014, 06:52:47 PM »
Have you used the strap the brake lever a finger length from the grip trick?  When I have trouble getting the last bit of air out that trick never fails me...LARRY
Online seanbarney41
Re: CB750 F Word 3
« Reply #27 on: January 29, 2014, 07:21:38 PM »
yea, that's really the only thing that has worked significantly at all
Offline SOHC Digger
  • I'm not an
Re: CB750 F Word 3
« Reply #28 on: January 29, 2014, 08:12:21 PM »
The master on the F has a different piston diameter than the K's.
That's what I figured on the master, but what diameter piston should I be using?
Piston diameter should be 11/16"
Online seanbarney41
Re: CB750 F Word 3
« Reply #29 on: February 16, 2014, 03:54:01 PM »
Fixed the headlight dimmer switch.  It turned out that the problem was this little metal bracket that holds the switch in and clamps it all together wasn't clamping tightly enough.
So I slightly modified the bend in it so it would clamp everything together tightly, achieving good contact.
Checked with the multi-meter before re-assembling and re-installing.
Online seanbarney41
Re: CB750 F Word 3
« Reply #30 on: February 16, 2014, 04:07:05 PM »
Cleaned up the lh switch as best I could.  I was just too lazy to paint or polish the faded anodizing.
had to dig up a good hoodlight.  I had two sealed beams laying around in which the low beam was burned out.  Dug up this h4 conversion.  Pretty nice piece that I bought here on the forum a while back.
This one works!
Did some cleaning on the mounting and trim rings.  This stuff all cleaned up pretty nice.
« Last Edit: February 16, 2014, 04:12:26 PM by seanbarney41 »
Online seanbarney41
Re: CB750 F Word 3
« Reply #31 on: February 16, 2014, 04:26:19 PM »
Started working my way to the back...fiddled the rear brake pedal adjustment just to make sure all was well using the gl1000 rear master.  Everything seems to be working good back here.
Pulled off the crusty rear shocks.  They look like they might clean up ok if I pull 'em apart, and if they do, I might try them on my 550.
 Decided to try these old S&W rear shocks.  Kinda hate the blue though, so eventually, the blue will get painted black.
Re: CB750 F Word 3
« Reply #32 on: February 16, 2014, 08:54:39 PM »
Good progress. Agree, shocks would look better black.
Online seanbarney41
Re: CB750 F Word 3
« Reply #33 on: March 27, 2014, 09:30:12 PM »
A lot more struggling, and a little progress...Put some more work into the pd42's.  The choke would not close.  Thought the shaft might be bent, so I swapped the one from from some 41a's I had.
 It didn't help much, but in the process discovered that the throttle slide was sticking above half throttle on carb #4.  Turns out, carb body #4 was warped or bent.  Replaced it with #4 from the 41a's.
Here is my trick little tool for fishing the washer and o-rings out of mixture screw hole.
 Got it all back together and the accelerator pump was no longer working.  Fixed that with the actuator spring from the 41a's.  I am not allowed to tell you how that #$%*ed up spring got in there and it wasn't me who put it there.
Here is the #$%*ed up spring...
and what it is supposed to look like on the 41a's...
Online seanbarney41
Re: CB750 F Word 3
« Reply #34 on: March 27, 2014, 09:48:29 PM »
So I mount up the pd42's once again...and...absolutely no improvement.  Still only runs on full choke, won't take any throttle, and won't idle below 2500rpm.  The only thing I can figure now is the boots and clamps are shot.
They are pretty hard but I have never had problems with hard boots on the older style carbs.  Maybe someday I will fork out $90 for the vintage cb750 repros, but for now these "pumper" carbs can suck my dick.  They sure are not any good at sucking air and fuel.  Cleaned up the airbox, even bought oem airbox boots and clamps(anybody want 'em? my originals are fine now that I found them again).
Online seanbarney41
Re: CB750 F Word 3
« Reply #35 on: March 27, 2014, 09:53:36 PM »
So hosed down the roundtops a little and put them back on.  I figured out a fuel line routing that works decent with the roundtops and f tank.
Online seanbarney41
Re: CB750 F Word 3
« Reply #36 on: March 27, 2014, 10:02:35 PM »
Crusty back end...
better...
crusty back wheel...
quite a bit better...
Online seanbarney41
Re: CB750 F Word 3
« Reply #37 on: March 27, 2014, 10:14:11 PM »
decided I better take a peep at the front sprocket and got in a tangle with one of the cover screws...impact driver won
even after getting the cover off the sucker was still stuck in there.  Pulled it out with vice grips and found myself a new old one.
I am probably crazy but I am gonna use this chain and sprockets for at least the first couple rides.  The chain is not as bad as it looks and will be cleaned and lubed.
Online seanbarney41
Re: CB750 F Word 3
« Reply #38 on: March 27, 2014, 10:23:41 PM »
crusty footpeg bracket...
not much photographic evidence of improvement...ideally they go in the bin anyway and I get rearsets, but not until this thing proves it self worthy of the money and time
dingy sidecovers...
shiny sidecovers...
Online seanbarney41
Re: CB750 F Word 3
« Reply #39 on: March 27, 2014, 10:27:49 PM »
New tires are here.  Should get them mounted tomorrow.  All I need now is some barely acceptable riding weather...that might be too much to ask
Re: CB750 F Word 3
« Reply #40 on: March 28, 2014, 03:49:11 AM »
Good progress on the effen F. What tires you get?
Re: CB750 F Word 3
« Reply #41 on: March 28, 2014, 04:44:05 AM »
Get em' on by Sunday and Monday. Supposed to maybe hit 60----Whoooo-Heeeeeee
Online seanbarney41
Re: CB750 F Word 3
« Reply #42 on: March 28, 2014, 05:13:51 AM »
...and I don't have to work Monday!----Whoooo-Haaaaaa.  Steve-O, I bought cheap ass Shinko 712's 'cuz I still don't really trust this thing.
Re: CB750 F Word 3
« Reply #43 on: March 28, 2014, 05:20:17 AM »
My eFing comstars for K3F have old Dunlops 404 I am going to start with but I got a Shinko for the sidecar wheel.
But this page scares me, I just put on all the brakes, all lines are empty and if it's gonna be a major effort to bleed it I will not be happy camper :(
Online seanbarney41
Re: CB750 F Word 3
« Reply #44 on: March 28, 2014, 05:23:52 AM »
I am hoping all my brake bleeding troubles are due to the non-original master cylinder, so if you have a good one, it might not be so bad.
Online seanbarney41
Re: CB750 F Word 3
« Reply #45 on: March 30, 2014, 07:53:53 PM »
...#$%* this thing, mounted brand new rubber friday, took it out for a spin, ran like a beast for about ten minutes, and then it ate it's camshaft. >:( >:( >:( >:( :'(
...I got a line on a 77k motor
...or someone show up at my shop with a love for eff's, an aptitude for engine rebuilding, and some cash :-\
Re: CB750 F Word 3
« Reply #46 on: March 30, 2014, 10:38:25 PM »
That seriously blows.  Sorry to hear about the camshaft fail.
Re: CB750 F Word 3
« Reply #47 on: March 31, 2014, 05:37:12 AM »
Effin F's.  Glad I sold mine.
Offline SOHC Digger
  • I'm not an
Re: CB750 F Word 3
« Reply #48 on: March 31, 2014, 03:43:32 PM »
Mine ate it's camshaft too. Must be an appetizer for them. I replaced my camshaft and cam towers and it's been good since.
« Last Edit: April 01, 2014, 04:12:51 AM by SOHC Digger »
Re: CB750 F Word 3
« Reply #49 on: March 31, 2014, 04:08:08 PM »
Is the head toast, too or just the camshaft up?  If it's just the camshaft, why replace the entire motor?
