So the RH control and battery were replaced on my 72 CB500 Four. Starter works fine. Turn signals work, albeit reaaaaaaly slow, especially the left side. When I turn on the headlight (high or lo beam) the turn signals will light up, but will not flash. It seems the draw from the headlight is causing problems for the blinker somehow.
Any ideas?
Some background: Bike sat for a long time, but the wiring is pretty good visually. I had almost no spark until I cleaned all the contacts on the coils with sandpaper, reset the points and applied dielectric grease to the wiring connections related to the ignition system.
Thanks.
Sam
