Author Topic: What is the correct technique?  (Read 520 times)
Offline thundershild007
« on: January 31, 2014, 01:04:25 AM »
400f Job - When replacing the Oil control orifice valve and it's Oring and the cylinder stud dowel and rubber gasket/oring.
Do you put the orings in first then the components into them or do you place the orings on the orifice valve and on the dowel and then
push them into place.
Offline lucky
Re: What is the correct technique?
« Reply #1 on: January 31, 2014, 01:36:23 PM »
Read the workshop manual, and if it does not say, replace in reverse order of taking it apart.
