Author Topic: '78 CB750K rear drum working "backward"?  (Read 610 times)
Offline Buster68
« on: January 31, 2014, 01:33:32 PM »
So I disassembled my rear brake drum to clean it up and polish the cover, but just noticed something very strange - it now seems that the brake is working in reverse; i.e. the brake is stuck on when it is just sitting, but comes off when I press the brake pedal.
Before I remove the wheel again, is there a logical explanation for this? Did I put something in backwards, or overtighten the rear brake rod?
I can honestly say this is a new one for me (of course, it is also my first bike with a rear drum)
1978 CB750K - in process of cafe conversion
1953 Harley Panhead chopper
1993 Harley FXR
Previous:
1978 Yamaha XS650 cafe
1977 CB750F cafe
1997 KTM 950 Adventure
1998 Honda VTR1000
1986 Harley-Davidson 1200 cafe
1990 Harley Evo rigid chopper
1998 Suzuki TL1000R
Offline LesterPiglet
  • 1977 CB550F2
Re: '78 CB750K rear drum working "backward"?
« Reply #1 on: January 31, 2014, 01:39:41 PM »
Give us a picture of the brake assembly. You may have the brake arm installed upside down or something.
« Reply #2 on: January 31, 2014, 01:49:47 PM »
spring between the shoes hold the pads OFF the drum faces when the brake is not in use.
the lobes of the brake cam #7, press the pads against the drum when the brake lever is depressed.
I think you have your brake set up so that this cam is engaged at rest.... and when you depress the brake lever, it rolls the cam out of the way allowing the pads to retract from the drum.
get your bike on the center stand.
remove the brake linkage rod (connects your brake pedal to the drum) at #10, but leave #10 to connected to #7
does your wheel spin freely now?
applying fore and aft pressure to #10, does your brake engage?
« Last Edit: February 03, 2014, 02:54:42 PM by flybox1 »
Offline Buster68
« Reply #3 on: January 31, 2014, 01:54:27 PM »
flybox - thanks. I will go down tonight and give that a try.
1993 Harley FXR
Previous:
1977 CB750F cafe
1998 Honda VTR1000
1998 Suzuki TL1000R
