the choke cable appears to be in good shape. I pull the choke and it just stops moving the plates about 3/4 of the way up. I can push them closed with my fingers but resistance is felt and then it sticks when I let down the choke... I'm guessing theres a spring in there that's worn or rubbing somehow. probably from messing something up the last time I took it apart... I've located the accelerator pump and it's not squirting at all. I need to take it apart and inspect it tonight. it was leaking gas from all four float bowls the last time. When I broke it down i realized that almost every screw was stripped (the threads on the bowl) so I retapped all the screws to the next size up.... wondering if this has somehow caused the problem. Thanks for the input.
that's your fast idle cam engaging poorly.
while your carbs are off, look deep between #2 & 3 carbs and watch as you lift your choke linkage. you'll see a small screw with a set nut on top. the tip of the screw is a rounded post, which will begin to ride up on a cam as you lift the choke linkage.
as the screw post rides up the cam, your slides will lift.
now, step back and look at the big picture....
When you are starting your bike cold, your choke cable pull closes the butterflies, AND, because of the fast idle cam engaging, your slides are lifted.
a quick twist or two of the throttle here, and your working accel pump squirts gas deep into the carb throats. a kick or touch of the starter and you're fired and running.
now, you have areas to adjust idle.
the idle set screw on the R side of the carbs... idle should be set with this once the bike hot, and left alone. wont need to touch it again.
your choke cable actuates the fast idle cam and lifts the slides as described above. this will also increase startup RPM, and can be adjusted at the fast idle cam set screw lock nut. with your choke cable fully pulled, you'll want your idle to jump to 2500rpm or so, and as your bike warms down the road, you can press your choke in all the way, and your bike will settle at idle based on how you set your idle screw....
