Author Topic: CB550 K0 project  (Read 9966 times)
Offline RSTLESS
    • Smyth Innovations
Re: CB550 K0 project
« Reply #25 on: February 21, 2014, 11:00:57 AM »
Remove the top cap and position the new clamp against the bearing dust shield. This should still prevent the underside from rubbing the steering head collar.
Fo your rearsets, you can use an offset from shift arm. Check out fastfromthepast.clm to order one up. They also have offset brake rods should you need.
When I remove the cap the bearings are exposed. Should there be a separate dust shield?
1974 CB550 K0 - Silverback
and too many more to list...
Offline RSTLESS
    • Smyth Innovations
« Reply #26 on: February 21, 2014, 11:04:14 AM »
Who did the acid dip on the tank? I was thinking about blasting mine, polishing it and throwing clear on top but yours came out awesome.
I took the tank to a place here in town that acid dips everything from industrial components, to classic cars. Make sure where ever you go, they neutralize the acid and coat the tank inside and out with oil right after otherwise it will 'flash' rust and you'll be back where you started.
Offline RSTLESS
    • Smyth Innovations
« Reply #27 on: February 27, 2014, 08:41:38 AM »
I was not sure what you meant about your last post on fork tubes.  If you are set on colored tubes, they you can consider TNK Titanium Nitride coating (http://racetech.com/page/title/FTNK%20Fork%20Tubes) or other anodizing.  If you want black, you can also look into black chrome plating.  Powdercoating will be too thick and will not work.
I am pretty set on brass/gold tubes for this bike but TNK doesn't offer 35mm replacement tubes for a CB550, so I emailed them asking a few questions about having them coat my tubes and I haven't heard anything back.
I figured out the problem with the top triple, the supplier sent me one that still needed some machine work so he's sending me another one that will fit. Made some 1/2" aluminium spacers for the rear sets and cut some aluminium tube to cover the threaded rods from collecting dirt. The outside of the tube is now 1/2" and its looking a little bulky. I'm thinking of picking up some 5/16 tube and threading the ends for heim joints.
I received my bearing and seals kits from All Balls. I decided to go with the All Balls because they make all the bearings and seals I need and I've heard good things about their tapered roller bearing kit (once installed properly). I also got one of Franken's clear points covers, can't wait to get this baby painted up and on the bike.
I am looking into either making my own belly pan/lower faring or using one off a sport bike. I also found these guys: http://www.airtech-streamlining.com/vintage/vintagebellypan.htm has anyone here used these on their bikes? post pictures of your bike if you have.
Offline RSTLESS
    • Smyth Innovations
« Reply #28 on: May 06, 2014, 01:00:29 PM »
I am rewiring the handle bar controls and headlight for my 1974 CB550 K0 and I'm running into a few electrical issues and after reading through the Electrical section in FAQs (which if I understand correctly I am just a few splices away from having a fully working bike) and looking over a few wiring diagrams I am a little uncertain of my wiring.
I rebuilt the front and rear end over the winter and I have switched over to clip-ons, with all new parts. I am replacing the old stock honda switches with two K&S switches that I purchased from Dime City Cycles and I am no longer running gauges, gauge lights, clutch switch, or turn signals. On the left clip-on I am using http://www.kandstech.com/pimages/12-0050.html (picture 1) this is used as my headlight/tail light on/off, high beam, and low beam, and the kill button is now my horn. On the right I am using http://www.kandstech.com/pimages/12-0203.html (picture 2) this is my electric start and kill switch. I have the horn and electric start working but I don't have power to the headlight or headlight fuse and I can still turn the engine over even with the kill switch in the off position. I tested the headlight and bulb outside of the wiring harness, Hi and Lo Beam work.
To make matters more confusing the PO had the fuses mixed up or he was an electrical genius. On my bike the fuse panel from left to right reads 5A (Tail Light) 7A(Headlight) 15A(Main) on the fuse block. the PO had a 7A fuse in the 5A (Tail Light) and 14A in the 7A(Headlight) and some screwy wiring on the ignition switch (picture 3) but I ran the bike like this all last season with all stock honda parts and I had no problems. Started right up, all lights and switches worked not one problem. While wiring this time I noticed the 7A fuse in the 5A (Tail Light) location was blown (my guess is a short somewhere) I have checked the battery, the fuse panel, the grounds, no disconnected wires, no signs of a short or any other problems found yet other than the screwy ignition wiring.
To make things easy I referenced the Haynes electrical diagram and made my own as I wired.
K&S Switches ----------------> CB550 Harness
LEFT SWITCH
HORN
WHITE----------------------------------LIGHT GREEN
BLACK----------------------------------GREEN
HEADLIGHT - no power to headlight or to headlight fuse
YELLOW (Hi Beam)--------------------BLUE (Hi Beam)
GREEN (Lo Beam)---------------------WHITE (Lo Beam)
RED (Power)---------------------------BROWN/RED (Headlight to fuse)
BLUE (Tail Light)-----------------------BROWN/WHITE (to IGNITION and to Headlight Fuse)
RIGHT SWITCH
ELECTRIC START
BLUE/WHITE---------------------------YELLOW/RED
BLACK----------------------------------GREEN/RED
RUN/KILL
RED/BLACK----------------------------BLACK
RED/WHITE----------------------------BLACK/WHITE
« Reply #29 on: May 06, 2014, 01:20:27 PM »
Air-Tech is a pretty established company.  They make tons of fiberglass reproduction parts, including gas tanks and body work.  The quality is very good, but many of their parts require you to fabricate your own mounts/brackets.
Offline RSTLESS
    • Smyth Innovations
« Reply #30 on: May 07, 2014, 08:08:43 AM »
I don't mind making my own brackets. I tend to make my own anyway.
I'm still not sure why the headlight system isn't getting any power but I know it has something to do with this new switch and the lack of wires/connections to the 550 harness. I bypassed the switch completely and hooked the headlight system into the black wire from the ignition just to put power to the system but I still want to use the switch to control power on/ off as well any ideas how?
