Author Topic: Original spokes - Cadmium or zinc plating?  (Read 4809 times)
Offline Chaser60
  • 75 CB550
« on: February 06, 2014, 08:18:58 AM »
Greetings.  I have searched a bit on cleaning / polishing.   Have seen some posts that say spokes are cad plated.  Others that say Zinc.   Anyone know what was on 1975 vintage spokes for a CB550?
Re: Original spokes - Cadmium or zinc plating?
« Reply #1 on: February 06, 2014, 08:49:24 AM »
Honda used zinc on everything else, pretty sure spokes too.
Offline lucky
« Reply #2 on: February 06, 2014, 08:53:17 AM »
No they were steel and had chrome plating.
Usually only stamped steel parts had cadnium plating. Like seat lock brackets and choke cable brackets etc.,.
« Reply #3 on: February 06, 2014, 09:15:59 AM »
Honda spkes are not chromed..
Offline DanJ
« Reply #4 on: February 06, 2014, 09:37:35 AM »
If someone has a spare I can throw it in the SEM and tell you exactly whats on them. Or you can wait until I pull one off of my wheel later this winter.
Black 750K8
« Reply #5 on: February 06, 2014, 10:23:57 AM »
What is a SEM?
Offline DanJ
« Reply #6 on: February 06, 2014, 10:56:15 AM »
What is a SEM?
Scanning Electron Microscope
« Reply #7 on: February 06, 2014, 12:06:36 PM »
The British used cadmium, Honda used zinc on most bits. There were a few parts with different coloured plating but still zinc I believe.
Lucky, when did you ever see chrome stock spokes on these older bikes? What's the colour of the sky in your world!  ;)
« Reply #8 on: February 06, 2014, 04:29:03 PM »
+1 zinc ( 'cept in Luckies wild world).  I always replace w/stainless steel when lacing up a rim.
Offline cb
« Reply #9 on: February 06, 2014, 05:33:35 PM »
A post on a different thread recommended "Nevr Dull" to clean spokes; has anyone tried that?
« Reply #10 on: February 08, 2014, 08:23:01 AM »
 On a side note I used CLR on my stainless spokes and plated steel nipples. They are removed so it was easy, and they look like new. i'm attempting to do a hub/rim  swap
Offline Chaser60
  • 75 CB550
« Reply #11 on: February 09, 2014, 05:53:25 PM »
Thanks all.  Sounds like zinc plating it is.   No need to SEM, but thanks for that offer.     My spokes overall are in good shape.   Dirty, yes and some have light surface rust.   I unlaced both front and rear today.    Will spend a bit of time on them with a some of the tips from here.
1) D40 and 0000 steel wool, light pressure
2) Coke (with or without) the aid of lubricants for the worker (me)
3)  CLR or Neverdull
Have a lot of other stuff to do, so spokes will be last.   If I am sick and tired and dirty from hours of other polishing, then SS spokes will be the order of the day.
Offline skidooextreme
« Reply #12 on: February 10, 2014, 05:14:57 AM »
if you are going to give up anyways , try pinsol. Take them out every couple hours and i recommend no longer than 24 hrs.  It will strip the finish completely if left to long but short periods of time they will look brand new again
« Reply #13 on: February 10, 2014, 01:24:20 PM »
Clr can be bought as a paste or a liquid. I used the liquid mostly, the paste worked but seemes to dissapear into the cloth. The liquid cleaned the nipples nicely, there was some rust on them now they look nice a little buffing and I suspect they will look new. Tose spokes were Stainless and look new now.  My stock spokes are not so good and I ordered a new set from z1parts. I haven't decided whether to use stock or new but I have the choice now.
