Author Topic: Stock 550 front fender clearance  (Read 673 times)
Offline bambuhiphop
« on: February 09, 2014, 08:01:52 PM »
Anyone know the clearance of the stock front fender on a 550 between the forks? Replacing the front wheel with an 18". Wanting to trim down mine to fit the new tire setup.
I know different tires will change measurements but my original tire is long gone...
Offline LesterPiglet
  • 1977 CB550F2
Re: Stock 550 front fender clearance
« Reply #1 on: February 10, 2014, 04:00:42 AM »
100/90x19 tyre.
Offline bambuhiphop
« Reply #2 on: February 10, 2014, 07:39:29 AM »
Thanks Lester. Exactly what I needed  8)
Offline brandEn
« Reply #3 on: February 10, 2014, 09:55:16 AM »
I am curious how you plan on modifying the fender? I was going to do this on my 750 that has an 18" front and couldn't see a way to do it.
Sent from my iPad using Tapatalk
Black 750K8
« Reply #4 on: February 10, 2014, 10:01:49 AM »
Looks like you would have to do away with the factory brace.
  • 1977 CB550F2
« Reply #5 on: February 10, 2014, 10:04:52 AM »
Am I wrong but if you lay a stock fender on a 18 wheel isn't there going to be a large gap fore and aft?
Offline brandEn
« Reply #6 on: February 10, 2014, 10:06:50 AM »
Yes, exactly
Offline bambuhiphop
« Reply #7 on: February 10, 2014, 10:30:50 AM »
Haven't worked it out completely yet but I have a few thoughts...
1. Chop the side brace down and re-weld. (possible strength issues)
2. Cut the brace at the first bend. Use it to model a new side piece that is about 1 1/4" shorter, cnc them out, and weld back on. (possible strength issues)
3. Pop the rivets and model the whole brace about an 1 1/4" shorter and then reattach to the fender.
Offline brandEn
« Reply #8 on: February 10, 2014, 03:39:39 PM »
Thanks for the reply, keep us posted I would love to see how it turns out!
Offline bambuhiphop
« Reply #9 on: February 10, 2014, 03:56:26 PM »
Sure thing. I will do my best to document in my build thread.
« Reply #10 on: February 10, 2014, 07:42:43 PM »
maybe source a fender from cb350k(twin) they have 18" front wheel and th fender could be easily adaptable
Offline bambuhiphop
« Reply #11 on: February 12, 2014, 08:01:02 PM »
Hey BrandEn, any particular reason you didn't go with fenders from Metal 7 West or Motolanna?
