Author Topic: Tail lights in frame ends  (Read 6922 times)
Offline RickB
    • Pop Magazine
« on: February 10, 2014, 05:10:35 AM »
Hi all,
I have been doing some work on the bike and have cut the frame ends under the 'hump' like on the CR750 bikes.
Anywho, I want to mount some tail lights in the frame tubes, like DamnitDan wanted to do here:
http://forums.sohc4.net/index.php?topic=27536.5
I have write-up somewhere on the net of someone doing this to a Yamaha or something which was very helpful, but I haven't been able to find it again now that the time for me to do this has come.
I was hoping someone here could give me some recommendations on dual-filament bulbs and/or sockets that work with the stock CB400F 12v wiring that would fit in the internals of my frame, which is about 17.8mm/0.7 inch. I'm assuming LED would be the way to go giving the vibration and small size.
I tried our local auto parts store (JayCar) here in Melbourne, Australia but the kids in the store where useless.
Any thoughts?
Rick.
Offline RickB
    • Pop Magazine
Re: Tail lights in frame ends
« Reply #1 on: February 12, 2014, 05:16:28 AM »
No one has any ideas on small diameter dual filament LED's I could use to do this? DamnitDan's post had a few recommendations, but nothing perfect.
Offline scunny
  • don't call me expert
« Reply #2 on: February 12, 2014, 11:34:45 AM »
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline greddm
    • CB750 Cafe Build
« Reply #3 on: February 12, 2014, 03:28:26 PM »
I did my turn signals this way, not sure about brake lights. Pics below.
1. rounded off a nut to the inside diameter of the tube
2. Used a bolt to drive it in strait (should be snug fit) and epoxied it in place.
3. Center drilled a stainless bolt that would house the LED assembly
4. Pull wires and thread it in.
Hope this helps with ideas.
Offline RickB
    • Pop Magazine
« Reply #4 on: February 12, 2014, 05:29:50 PM »
greddm,
That's fantastic, never thought of doing the bolt thing. Great idea.
What LED is that? Where'd you get it? I've had trouble finding anything small, especially in dual filament.
Thanks,
Rick.
Offline greddm
    • CB750 Cafe Build
« Reply #5 on: February 12, 2014, 08:36:22 PM »
I got them from microlazers.com. They are very bright, but i'm wishing I got the model with the domed lens instead of the inset ones I've got. Since they are only for the turn signals, they are not dual filament. Between these and the bar-end winkers up front, I don't thing anyone will have a problem seeing them.
Offline RickB
    • Pop Magazine
« Reply #6 on: February 12, 2014, 10:43:05 PM »
greddm,
You legend!! I just ordered:
http://www.microlazers.com/servlet/the-83/BLACK-DOME-OPTO--dsh-/Detail
Exactly what I was looking for. Can't thank you enough, I have been searching for days.
Rick.
Offline greddm
    • CB750 Cafe Build
« Reply #7 on: February 15, 2014, 04:50:00 PM »
Hey, glad I was finally able to help someone out! I'm usually the one needed help. Good luck, post some pics when done.
1977 CB750
Offline RickB
    • Pop Magazine
« Reply #8 on: January 22, 2015, 05:25:24 AM »
I posted about this in my project thread but I figured I'd report back here as this post was a tremendous help.
Thanks to greddm, I was able to buy those small dual intensity LED's that are apparently super bright (although I haven't tested them too well yet, they're essentially hidden under my seat...).
I found some 19mm chair leg stoppers at the hardware store, drilled out a hole, drilled a hole in the frame under the seat frame (out of the way/weather there I figure) and wired it up with my vintage connectors.
I'm going to try polishing up the underside of my seat to make these even brighter at night. If that doesn't work, I may have to try mounting these closer to the end of my seat.
Offline greddm
    • CB750 Cafe Build
« Reply #9 on: January 22, 2015, 06:45:59 AM »
Nice solution!
1977 CB750
Offline Lostboy Steve
« Reply #10 on: January 22, 2015, 11:17:52 AM »
Just make sure you can see them from an angle...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #11 on: January 23, 2015, 06:00:00 AM »
Very cool solution!
--Evan
1975 CB750K "Rhonda"
Offline theslayedsaint
« Reply #12 on: January 23, 2015, 09:30:19 AM »
Amazing!
and just a few months to late..... I never thought of the bolt idea was trying for weeks to come up with away for this to work.
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline RickB
    • Pop Magazine
« Reply #13 on: January 27, 2015, 04:19:34 AM »
Yeah so a friend riding behind me said they're not super visible from a high angle. So I might have to try moving them around or something. More photos to come.
Offline greddm
    • CB750 Cafe Build
« Reply #14 on: January 27, 2015, 06:36:40 AM »
I'm noticing the same problem with mine, I'm not sure someone in a truck would see them. I have bar-end signals as well but I might add another set to the sides of the rear cowl.
1977 CB750
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #15 on: January 27, 2015, 07:03:14 AM »
You can find hundreds of Eagle Eye LED lights on eBay for next to nothing. I'm using them as signals on the Cafe Interceptor and love them. Haven't seen dual intensity yet, but keep looking.
« Reply #16 on: January 27, 2015, 07:14:29 AM »
+1
I bought a set of these just to check out.  (18mm or 23mm)  Still haven't decided if i will use them or not.
I saw these first on ttr400's bike.  He had them rigged as driving lights.  Front (white) and rear(red).
Super bright.  NOT dual intensity...but that would be a nice option.
http://www.amazon.com/gp/product/B00NWB21TC/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A3HIK6JK816SCG
« Last Edit: January 27, 2015, 11:26:11 AM by flybox1 »
Offline lrutt
« Reply #17 on: January 27, 2015, 07:35:52 AM »
While very trick, I wonder how much the popo will hassle you for not have lights that are DOT approved. There are a lot of lights out there than aren't DOT approved but at least you can see some semblence of a tail light. These might be pushing it a bit far.
I did see a nice license plate frame that had brake, tail, and turn sigs integrated in an LED bar across the top. Very very low key, very bright, and looked like an option I'd try.
I do like the looks of these frame end units though. Very clean. I guess the worse than can happen is they give you a ticket to fix it.
Offline KeithB
« Reply #18 on: January 27, 2015, 11:14:17 AM »
This, and the fact that LEDs are very directional, made me reconsider doing something similar.
No point having cool lights if some drivers can't see them.
Buddy of mine has the coolest vintage tail light but you can't see the POS in the sunlight!
Nanahan Man
