Author Topic: Cylinderhead question(updated pictures)  (Read 2167 times)
Offline KirkBurner
« on: February 11, 2014, 02:17:31 PM »
Updated with the last picture
Is this cylinderhead already milled as much as it can be milled?
Is it milled more on one side then the other due to the darker markings?
The damage in the picture below will this disapear with simple milling of the head?
« Last Edit: February 12, 2014, 10:59:38 AM by KirkBurner »
Offline Old Scrambler
Re: Cylinderhead question
« Reply #1 on: February 11, 2014, 02:27:01 PM »
The stains are from the head gasket and may indicate minimal metal has been removed. Glass it or plane it to measure any irregular surfaces.  Is that a scratch or a crack-line leading from the chamber to a stud-hole?  Clean it or blast it before further work is commenced. If that scratch is deep.............its land-fill.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline KirkBurner
« Reply #2 on: February 11, 2014, 02:39:26 PM »
Forgot to say.. it has/had a copper gasket...
its a "scratch" try to use the Micrometer to measure it tomorrow ... and I will talk to the machineshop about the depth of the scratch
Offline KirkBurner
Re: Cylinderhead question(updated pictures)
« Reply #3 on: February 12, 2014, 11:02:12 AM »
TTT
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: February 12, 2014, 11:08:16 AM »
Why not run a weld over the scratch before milling?
« Reply #5 on: February 13, 2014, 03:23:00 PM »
That line looks like more of a dent and it goes across the stud hole. Interesting.
  • 1977 CB550F2
« Reply #6 on: February 13, 2014, 03:45:56 PM »
Is there a matching mark on the cylinder side?
Offline bjbuchanan
« Reply #7 on: February 13, 2014, 09:49:04 PM »
I agree with MRieck, that looks like a dent. Installation or removal, could be from putting it down on a workbench. Surprisingly easy to damage the aluminum, especially with the weight of the head helping downward
Offline KirkBurner
« Reply #8 on: February 14, 2014, 01:06:23 PM »
No markings on hte cylinder side of the fit.
But, will this likely cause a leak if untreated?
Im gonna have the head sent over to the machine shop, for valve seat cutting aswell as milling.
should this be enough to clean up the damage?
  • 1977 CB550F2
« Reply #9 on: February 14, 2014, 01:29:30 PM »
If it's too deep to mill out it's ideal for early gasket failure.
Offline lucky
« Reply #10 on: February 14, 2014, 01:48:49 PM »
You should NOT be milling a motorcycle cylinder head unless you really have to.
IT IS NOT A CAR ENGINE!
A clean up cut to the absolute minimum and then you will have to check piston clearance with the valves etc.,.
Just do not do it.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #11 on: February 14, 2014, 02:27:51 PM »
Yeah this looks like something hard and heavy and sharpedged got dropped on it or vice versa.
I'm with the person who said see about having it filled with weld, then have the head face surfaced to be perfectly flat removing the absolute minimum of material possible to achieve that.
i did one of these engines and didn't have it surfaced - the available head gasket and how that interfaces with the relatively low torque settings for the head nuts meant  - you guessed it - the #$%* leaked.
After that, I have had a great local machinist measure and inspect all the mating surfaces for flatness.  No more problemos.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline KirkBurner
« Reply #12 on: February 15, 2014, 01:10:28 AM »
In regards to piston clearance for the valves,
I have Yoshi´s 812 with indents for the valves in them, I have no idea of how much this will give me of extra clearance.
And using a copper gasket, I understand it will to some degree leak no mater what?
Offline KirkBurner
« Reply #13 on: February 15, 2014, 03:33:18 AM »
When doing some research on the interwebs I came across http://www.aluminumrepair.com
HTS-2000
is worth trying or should I stay away from it ?
Offline KirkBurner
« Reply #14 on: February 15, 2014, 06:39:52 AM »
I am in touch with a shop... Today my stuff fom cyclex arrived so now i just hva to head up to the shop
« Reply #15 on: February 15, 2014, 08:08:44 AM »
If you can repair that dent and clean up the face, consider an MLS head gasket instead of copper. Copper will always weep some but if you have good straight surfaces the MLS should seal better.
