Author Topic: 550 to 650 cam swap  (Read 12098 times)
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
550 to 650 cam swap
« on: February 11, 2014, 07:35:49 PM »
I have searched for the 550 to 650 cam change, but have not come up with anything helpful. I'm looking for the step by step change. I know this was written up but can't find it.
                                       Thanks, Doug
Offline goldarrow
  • one day, i'll be an
Re: 550 to 650 cam swap
« Reply #1 on: February 11, 2014, 07:46:54 PM »
Manual is your best friend.
CB550 K0
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: February 11, 2014, 07:53:45 PM »
Take one out and put the other in.  ;)
Offline Doggie
« Reply #3 on: February 11, 2014, 07:57:59 PM »
Thank you, that was what I was looking for...Doug
Offline Doggie
« Reply #4 on: February 11, 2014, 08:08:03 PM »
yes, thats the trouble I was having too. Thanks Doug
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: February 11, 2014, 08:22:34 PM »
Have a look at this before re-installing the camshaft and chain.
http://forums.sohc4.net/index.php?topic=369.msg57914#msg57914
Offline Rgconner
« Reply #6 on: February 12, 2014, 07:30:39 AM »
Make sure you get the tach too, the gearing is different ratios, so your RPMs will be off.
I have the 650 cam, the 550 now keeps pulling as hard as it does at 5K all the way to the redline.
1975 CB550K aka "Grease Monkey"
Offline Doggie
« Reply #7 on: February 12, 2014, 09:22:22 PM »
Great help Guys!!
                           Doug
Offline Scott S
« Reply #8 on: February 14, 2014, 02:39:42 AM »
 They're over simplifying it a little bit.
 Some heads require a little bit of clearancing for the cam lobes. Not all do. Some just on one side, some on both. It's best to test fit the cam and spin it slowly. I clearanced my head with a Dremel tool.
 You also need to swap the 550 cam gear over to the 650 cam. After that, just align the timing mark on the end of the cam like you would a 550 cam.
 As noted, if you want to run a tach, you'll need the 650 tach drive gear and a CB650 or CB750 tach. I used a CB750 because I could match the gauge face on my speedometer.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #9 on: February 14, 2014, 03:53:33 AM »
a great post by scott with good photos,we love photos,as scott s said,if you dont trial spin the camshaft in the head and cover you are a novice,with no natural mechanical appitude,destined for destruction.
« Last Edit: February 14, 2014, 03:59:15 AM by dave500 »
Offline CBGhia
« Reply #10 on: February 14, 2014, 04:00:10 AM »
And thank you for the new sig line.   This is why Dave deserves a medal.
  • 1977 CB550F2
« Reply #11 on: February 14, 2014, 05:01:25 AM »
I hope you cleaned that #3 exhaust valve Scott.   ;)
Offline Scott S
« Reply #12 on: February 14, 2014, 05:45:12 AM »
 That's grease. But thanks for looking out!
'71 CB500 K0
'81 Yamaha XS650
