Author Topic: engines from a cb550 compatibility with a cb500?  (Read 2713 times)
Offline Wnbasac
« on: February 12, 2014, 06:22:13 PM »
i have an opportunity to acquire a CB550 engine for parts almost free but i have a 71 CB500 would this be a great buy?
I'm not sure what is interchangeable between the 550 engine that could be used on my 500 is it a GO a NO go?
tks,Lou
Offline goldarrow
  • one day, i'll be an
Re: engines from a cb550 compatibility with a cb500?
« Reply #1 on: February 12, 2014, 07:37:48 PM »
Is the 550 engine complete? If it is, should just drop right into 500 frame
CB550 K0
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: February 12, 2014, 08:25:19 PM »
Snag it. The 550 engine is much improved.
« Reply #3 on: February 13, 2014, 12:15:26 AM »
As a complete unit all you need to fit it is the RH rear engine mount plate from the 550 as that holds the clutch cable,as parts only the headgasket upwards is compatible
« Reply #4 on: February 13, 2014, 12:52:12 AM »
crankshaft,primary shaft with starter sprag etc,mainshaft needle roller,one or two transmission gears,the kick start mechanism,the sump,oil pump,oil filter housing and bolt,alternator and cover,points/advance unit and cover.
« Last Edit: February 13, 2014, 01:12:41 AM by dave500 »
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #5 on: February 13, 2014, 05:37:14 AM »
^^ Bloody show-off!  ;)  ;D ^^
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #6 on: February 13, 2014, 05:39:32 AM »
Expert!   Ain't showing off if it's true....
« Reply #7 on: February 13, 2014, 11:39:14 AM »
starter motor,con rods.
« Last Edit: February 13, 2014, 11:41:03 AM by dave500 »
Offline jonda500
« Reply #8 on: February 13, 2014, 04:40:58 PM »
...camshaft/sprocket/camchain
A starter clutch thread:
« Reply #9 on: February 13, 2014, 06:57:56 PM »
primary chain,neutral switch.
« Last Edit: February 13, 2014, 07:08:19 PM by dave500 »
Offline goldarrow
« Reply #10 on: February 13, 2014, 07:08:59 PM »
You guys forgetting bunch of nuts and bolts
CB550 K0
« Reply #11 on: February 13, 2014, 07:20:19 PM »
....and washers
« Reply #12 on: February 13, 2014, 11:27:59 PM »
Is that expert as in
Ex----used to be
Spurt---A drip under pressure
« Reply #13 on: February 14, 2014, 01:13:03 AM »
youll have to ask frostyboy about that bryanj,its in his avatar but hes far from that let me tell you!
the sump plug can also be used between the two engines,and the dip stick!along with a multitude of transmission circlips and special slotted spacers,and those set rings that locate the main and countershaft bearings,alignment dowells and gudgeon pins,id be snapping that 550 engine up man,i prefer them over the 500 anyway because of the improved clutch and transmission.
« Last Edit: February 14, 2014, 01:26:05 AM by dave500 »
