Author Topic: Gauge repair  (Read 676 times)
Offline Paul Lowe
  • If you like then it is good...
Gauge repair
« on: February 19, 2014, 03:47:11 PM »
Could someone tell how difficult it is to pull apart 750 K1 gauges?
Have read a bit but last time I tried on different models it ended in tears!
Paul
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Re: Gauge repair
« Reply #1 on: February 19, 2014, 03:49:40 PM »
the issue for me was starting the clamp ring removal.
once its up and started, the rest is cake.
but if you dont want to do it yourself....http://forums.sohc4.net/index.php?topic=119363.0
« Last Edit: February 19, 2014, 03:53:16 PM by flybox1 »
Offline texianbiker
Re: Gauge repair
« Reply #2 on: February 21, 2014, 09:20:09 AM »
It ain't cheap but Marcel at CB750 Faces is the best of the best when it comes to refurbishing.  If you're restoring that's the route I took with no regrets.  If you putting a rider together probably easier to buy an used one off fleabay.
Offline LesterPiglet
  • 1977 CB550F2
Re: Gauge repair
« Reply #3 on: February 21, 2014, 09:41:35 AM »
Getting the ring off is easy. Putting the clocks together is more difficult...and expensive for that ring.
