SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Oil Leak Cylinder Head
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Oil Leak Cylinder Head (Read 2388 times)
felicious
Full Member
on:
February 24, 2014, 12:01:10 PM »
Hi,
I've had an oil leak for a while and decided to clean my bike this weekend to find the source.
Took me 4h and it felt like I cleaned 35 years of grime off but it was worth it to finally see the engine in its original color.
Here are the pictures of the leak. Can anyone take an educated guess how much trouble that is to fix?
The bike ran maybe 3-4 minutes at this point. I rode it home and had some oil all over the fins but couldn't see anymore oil at the cylinder head cover.
Thank you,
Felix
Logged
flybox1
My wife thinks I'm a
Really Old Timer ...
Re: Oil Leak Cylinder Head
Reply #1 on:
February 24, 2014, 12:08:17 PM »
looks like a valve cover leak.
if thats a 500/550, i think you can replace it without pulling the engine.
the 500/550 guys will be long shortly...
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
felicious
Full Member
Reply #2 on:
February 24, 2014, 12:17:28 PM »
Yeah I forgot the most important info. CB550 '78
Logged
Untold
Enthusiast
Reply #3 on:
February 24, 2014, 12:22:46 PM »
Pretty easy fix. I recently did it myself. Just get a new valve cover gasket, and do a search for the procedure. Most importantly, make sure to back out your tappets and use the elastic trick to keep them out of the way, lest you bend a valve.
Logged
1976 CB550K
goldarrow
one day, i'll be an
Old Timer
Reply #4 on:
February 24, 2014, 12:29:05 PM »
Valve cover seal is no longer available from honda. Since you're going to open it up, might as we'll check the rubber picks and replace them. $5 a piece from honda and will need 6 pieces. Get a tube of hondabond also.
Logged
CB550 K0
750k5
http://forums.sohc4.net/index.php?topic=114817.0
felicious
Full Member
Reply #5 on:
February 24, 2014, 01:06:15 PM »
That's great news.
How much time would you guys estimate for this job (including the rubber pucks)?
Logged
goldarrow
one day, i'll be an
Old Timer
Reply #6 on:
February 24, 2014, 01:10:53 PM »
If have everything on hand, i would say few hours, but plan it for a day, or a weekend job. You don't want to rush it.
Logged
CB550 K0
750k5
felicious
Full Member
Reply #7 on:
February 24, 2014, 01:33:38 PM »
I found this video that seems to show the rubber pucks and the gasket installation.
SocoMoto: 1976 Honda cb550 Cam Cover Installation (part 4).m4v
You put the Hondabond on the gasket for better sealing?
This looks like an OEM gasket? Does this work?
http://www.ebay.com/itm/1971-1978-Honda-CB-500-Four-CB-550-K-CB550F-Top-End-Gasket-Set-Kit-A-OEM-NOS-/310856728523?_trksid=p2054897.l4275
Sorry for the noob questions.
Logged
goldarrow
one day, i'll be an
Old Timer
Reply #8 on:
February 24, 2014, 01:41:13 PM »
the gasket set is overkill, search feebay for cylinder head cover gasket part number 12391-323-000, use hondabond on the rubber pucks, not on the cover head cover gasket.
Logged
CB550 K0
750k5
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
