Author Topic: Gl1000 upside down rear caliper  (Read 2165 times)
Offline fdbrat
« on: February 28, 2014, 06:30:16 PM »
I've found that Gl1000 rear calipers are relatively the same as a 75-76 cb750f rear caliper.
Except they mount on the left side.
They are a lot cheaper on eBay than the CB750f calipers. Would there be any problem mounting it on the right side upside down on my 75 CB750f?
Reason is because the stay for it is on the left vs the right side.
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
DH
Re: Gl1000 upside down rear caliper
« Reply #1 on: February 28, 2014, 07:06:37 PM »
Not sure if there will be fitment issue, but if the bleeder is upside down (points down)
it won't bleed out.    just an fyi....
Offline fdbrat
« Reply #2 on: February 28, 2014, 07:21:48 PM »
When I bleed brakes I connect a rubber tube and insert it into a glass of brake fluid.
So that won't be a problem.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Geeto67
  • A grumpy
« Reply #3 on: February 28, 2014, 08:36:31 PM »
<Smacks forehead> no he means air bubbles don't travel downward. So if you are doing the pump and crack method, the air bubbles won't come out. You would need to either reverse bleed or vacuum bleed.
Maintenance Matters Most
Offline fdbrat
« Reply #4 on: February 28, 2014, 11:37:45 PM »
Ah ha. True. I could bleed it up right detached from the axle. When bled then slide the axle in and bolt it together.
Other than that do you fore see any problem with it upside down or side ways?
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline dusterdude
« Reply #5 on: March 01, 2014, 04:41:58 AM »
Turn it right side up to bleed it,then mount it upside down.thats how the read caliper is mounted on my panhead,works just fine
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline fdbrat
« Reply #6 on: March 01, 2014, 02:29:11 PM »
I dig the advice. I think ll plunge into the cheaper route and let every one know ho it turns out.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Hon3ybadger
  • Someday it will run...
« Reply #7 on: March 03, 2014, 03:17:32 AM »
Please do. I'm quite interested in a replacement for my roached out rear caliper.
Offline fdbrat
« Reply #8 on: May 05, 2014, 12:09:24 AM »
Sorry I haven't gotten to this.
Some one pointed out that the Caliper upside down would now have force pulling the caliper stay bar, instead of the force pushing into it.
Does anyone have any opinions in regards to a gl1000 Caliper being up side down?
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline andrewk
  • doin' it.
« Reply #9 on: May 05, 2014, 07:17:51 AM »
I think it would work fine, even with pulling on the stay bar.  But I also think it will be a gigantic headache every time you have to deal with service back there.
You could probably source F2/3 parts a little cheaper, like this one.  You would need both caliper and bracket, maybe a new brake line.  http://www.ebay.com/itm/1977-78-Honda-CB750F-CB900F-SS-SOHC-Rear-brake-Caliper-assy-Brat-Tracker-/111263122227?pt=Motorcycles_Parts_Accessories&hash=item19e7cc8333&vxp=mtr
Although, there's an early F caliper on the 'bay right now for 50, but looks like it needs a full re-work.  Probably another 100 in parts if it needs pistons.  http://www.ebay.com/itm/78-Honda-CB750-CB-750-Rear-Brake-Caliper-/310896831010?pt=Motorcycles_Parts_Accessories&hash=item4862e52a22&vxp=mtr
Offline dusterdude
« Reply #10 on: May 05, 2014, 05:00:43 PM »
Works good,the caliper on my panhead has been upside down for 25 years,no issues
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline fdbrat
« Reply #11 on: May 07, 2014, 10:17:51 AM »
Andrewk, 75-76 only fit. The late Fs are way off in size. There's no way I'm ditch I'm my Lester's haha.
Aye DusterDude, could you post a pic of your rear set up. I won't tell anyone you post a HD pic.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline andrewk
  • doin' it.
« Reply #12 on: May 07, 2014, 12:43:28 PM »
You use the bracket too, it fits.  Late F and early F use the same rear rotor, and despite the difference in the drive side with late model bikes, the brake side remains the same.
I know they fit cause I've done it. :D
Upside down works too, just giving you options, if you care to believe me. :)
Offline fdbrat
« Reply #13 on: May 07, 2014, 12:50:20 PM »
Andrewk. Really?  :) the rotor swaps over too?!!!
Well #$%*. That wors for me man. I've asked around regarding late F's and got a bunch of this and that.
How the spacing?
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline dusterdude
« Reply #14 on: May 07, 2014, 01:53:00 PM »
Here ya go fd,if you need bleeding instructions,let me know
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline andrewk
  • doin' it.
« Reply #15 on: May 08, 2014, 08:39:29 AM »
How the spacing?
You were probably getting fed information about the front brakes, which are different.  I see a lot of confusion about it.
The late F comstar rear wheel uses the exact same rotor as the early F spoked wheel.  Same part number.
The difference between the early and late rear brakes is that the early one was a non-floating design, and used two pistons.   The late model uses a floating design (so caliper can be removed from bracket) and a single piston, but the caliper bracket is the same dimension at the wheel axle spacer portion as the early caliper, so spacing is on.
Only change you might have to make is the rear brake line, which I'm sure is on your radar if you're thinking about flipping one.
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #16 on: May 08, 2014, 12:41:53 PM »
I didn't think about it until I saw the pics, but having the brake line hang down towards the ground like it is would worry the crap out of me.  I would be worried that something would hit and cut it.  It is completely exposed with nothing to shield it from road debris.
Offline dusterdude
« Reply #17 on: May 08, 2014, 06:02:11 PM »
You could fashion some sort of guard for it,shouldnt be a big problem
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
