Author Topic: Tapered steering bearing installation q  (Read 1572 times)
Offline Dimitri13
  • 1974 CB550K
« on: March 06, 2014, 08:31:50 AM »
I got the tapered kit from DCC. Not sure if it's allballz or not, but it is tapered.
I have the races pressed in already, but I'm confused about the bottom washer on the stem. The instructions on the box say to tap the washer on to the stem then the bottom bearing.
Is the washer supposed to fit very tight? It feels a lot tighter than one would think. And does the bearing need to be pressed on as well?
No pictures right now because I'm at work, but if needed, I can provide tonight.
Re: Tapered steering bearing installation q
« Reply #1 on: March 06, 2014, 08:36:33 AM »
The stack is typically washer, dust seal, bearings, and yes, the washer and bearings will need to be pressed on.
PVC tube over the stem is usually a good tool.   All you need to know is right here...
http://forums.sohc4.net/index.php?topic=1516.0
Offline mcswny
« Reply #2 on: March 06, 2014, 09:11:26 AM »
I put my stem in the freezer over night to "shrink" it. Everything slide on with a couple whacks of a rubber mallet on a cut PVC (3/4") as stated above.
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: March 07, 2014, 12:13:16 PM »
Dust seal?
#$%*. Didn't even think about it and it didn't come in the kit. How screwed am I without it?
« Reply #4 on: March 07, 2014, 12:19:55 PM »
dust in grease, grinding bearings?  you decide  ;D
can you reuse the original one?
Offline Dimitri13
  • 1974 CB550K
« Reply #5 on: March 07, 2014, 12:44:16 PM »
If I can find it I'll see. But it has to go between the bearing and washer?
« Reply #6 on: March 07, 2014, 12:55:07 PM »
correct.
washer on first, then seal.  bearing on top.
Offline Powderman
« Reply #7 on: March 07, 2014, 03:17:07 PM »
The tapered bearing races are usually shorter than the stock ball bearing cups. The washer is to space the lower tree back down so it doesn't scrub against the neck. Same issue with my CB400f allBalls conversion.
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #8 on: March 07, 2014, 03:21:57 PM »
I put my washer under the bearing race in the steering head.  There were multiple choices in thickness and I chose wrong the first time.  Putting it under the race in the head made it easier to change.  I just tapped the race out from the top and swapped washers.  That way I didn't have to worry about screwing up the cage by taking it on and off.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
