Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 233085 times)
0 Members and 27 Guests are viewing this topic.
Offline grcamna2
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #675 on: April 24, 2021, 11:04:38 PM »
That custom clutch cover from Jeff looks good Don,as you say the finish matches-up well with the rest of the engine.
75' CB400F/'bunch o' parts'
« Reply #676 on: April 24, 2021, 11:24:09 PM »
Thanks!
Offline Godffery
  • Godffery's Garage
« Reply #677 on: April 25, 2021, 02:01:37 PM »
 You'll have to let me know if anyone on the street (Non SOHC familiar people), recognizes that as not being a factory item.
I can't tell you how often I spend countless hours designing & fabricating something special, and only those who know, Know how special it is, or have the slightest idea how challenging it was to actually make it work.
 That being said; the real satisfaction is in the performance of a finely tweaked ride.   ;)
« Reply #678 on: March 27, 2022, 12:21:47 PM »
Well, DGR is coming in less than 2 months, so time to get Blue roadworthy.  My Motogadget M-Unit took a dump a little over a year ago.  I sent it to Speigler and STILL over a year later no replacement or repair! :(
I decided to take the one destined for my 650 project and I swapped out the original speedo drive with a magnet pickup for a cleaner Justin Webster speedo-delete.  I'll have to remount the speedo pickup.
Untitled by Donald Leonhardt, on Flickr
Next up: plug back in the wires and see if she fires.  Also need to plumb the hydraulic line from the clutch master the the slave unit.  Flush the fuel and clean the carburetors.
Offline grcamna2
« Reply #679 on: March 27, 2022, 04:10:03 PM »
That bike is nice Don.  8)
« Reply #680 on: March 28, 2022, 10:39:27 AM »
Thanks!  It's in need of a detailing.  It's been sitting collecting dust for the last year (waiting for Motogadget to send me a replacement m-unit >:().
Offline tshrey
« Reply #681 on: May 21, 2022, 11:13:18 AM »
Did you cut and weld in extra rod on the stock clutch actuator or make your own new one?  You happen to have the measurements (length)?  I will be doing this shortly.
« Reply #682 on: May 21, 2022, 11:25:05 AM »
Same rod as I recall.
Offline Godffery
  • Godffery's Garage
« Reply #683 on: May 22, 2022, 06:41:29 AM »
Yes, I was able to designed the 550 clutch conversion kit to use the stock push rod. Although it was rather tricky to do, and the 500 & 750 kits required a special built one.
 https://godfferysgarage.com/project/custom-hydraulic-clutch/
« Last Edit: May 22, 2022, 06:51:54 AM by Godffery »
« Reply #684 on: May 23, 2022, 08:06:36 AM »
The hydraulic clutch appears to work great.  Unfortunately, the re-wire of the bike (and absence of timely warranty replacement support from Motogadget) has delayed ride testing.
Offline Godffery
  • Godffery's Garage
« Reply #685 on: May 23, 2022, 08:41:11 AM »
Have you got any photos of the bike with the hydraulic lines installed?
Bummer about the electrical delays.  =/
« Reply #686 on: May 23, 2022, 10:34:14 AM »
I was waiting to take some photos after I had everything buttoned up and I had the bike detailed.  Right now, its all shiny and clean, has the clutch plumbed, but the wiring is amiss.
« Reply #687 on: May 23, 2022, 10:10:52 PM »
Look forward to seeing the photos...
Interesting project.
Offline grcamna2
« Reply #688 on: May 24, 2022, 12:43:55 AM »
Motogadjet needs to do You Right Don;send you the replacement along with a few $ for the aggravation they put you through.  >:(   Sorry won't do when you want to ride.
« Last Edit: May 24, 2022, 07:36:54 AM by grcamna2 »
« Reply #689 on: May 24, 2022, 05:34:42 AM »
Motogadjet needs to Do You right Don;send you the replacement along with a few $ for the aggravation they put you through.
Boy what a fantasy world you live in...
Start making some noise and bug them weekly and then daily talking to them until they do it to make things right...
« Reply #690 on: May 24, 2022, 08:18:47 AM »
No kidding.  I still haven't received my repaired or replacement m-unit sent back to them over a year ago!
« Reply #691 on: June 26, 2022, 12:41:12 PM »
I finally received my original M-Unit back from Motogadget.  It looks like my Motoscope gauge, however, may have been damaged with a short.  When I hook it up to power I get nothing.
On better news, the hydraulic clutch feels buttery smooth and very light.
Offline grcamna2
« Reply #692 on: June 26, 2022, 12:53:05 PM »
What does the Motoscope gauge do,read the engine ?
« Reply #693 on: June 26, 2022, 01:10:39 PM »
It’s an LED electronic gauge - RPM, Speed, warning lights, signals, odometer, etc.
Offline grcamna2
« Reply #694 on: June 26, 2022, 01:23:55 PM »
How does it differ from your M-unit ?
« Reply #695 on: June 26, 2022, 02:02:15 PM »
The M-Unit is a solid-state electronic control unit that replaces the fuse-block.  It also controls other functions, such as signal (momentary signal (3 flashes), sustained signals, tachometer, warning lights, etc.)  The Motoscope is the electronic gauge that replaces your analog speedometer and tach.  It is the visual instrument/dash.
So here's the m-unit:
This is a Motoscope instrument
motoscope by Donald Leonhardt, on Flickr
Offline grcamna2
« Reply #696 on: June 26, 2022, 02:54:13 PM »
Oh dude,I thought that the M-unit 'was' your scope !   :o and that it's what you had been waiting for;the Motoscope is Also uber important and I hope you can get that 'readout' gauge replaced without too much hassle Don.  :)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #697 on: June 26, 2022, 05:34:09 PM »
Looking at the M unit... It is essentially just a PLC but for our bike correct?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Tracksnblades1
« Reply #698 on: June 26, 2022, 06:40:08 PM »
Is it a real “Programable Logic Controller” or are you restricted to preset parameters.
Does it have assignable and programmable I/O or must you follow a predetermined wiring diagram…?
Thanks 🤔
Age Quod Agis
« Reply #699 on: June 26, 2022, 06:52:54 PM »
It is programmable but to a limited degree.  Feel free to check out the manual:
https://motogadget.com/shop/media/downloads/manual/munit_blue_manual_en_2.0.pdf
