Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 154042 times)
Re: 1975 CB550K1 - Stock-ish Restomod
« Reply #75 on: May 07, 2014, 04:02:12 PM »
I purchased a pair of stock length fork tubes from Forking by Frank (great quality) but for now I'm running the originals and save the newbies for a rainy day.  They have some oxidation under the fork ears but no pitting on the lower travel portion (the gaitors did their job!).
Right now, I'm just waiting on my brake package from Godffrey (arriving tomorrow!) with dual, drilled rotors!  Once I have the dual brake set up sorted, I think this bike will be left alone to ride.
Offline flatlander
« Reply #76 on: May 08, 2014, 12:57:12 AM »
sounds good. that's what they're made for  :)
« Reply #77 on: May 09, 2014, 12:10:24 AM »
Holy moly!  I just got my dual brake goodies from Godffrey today.  All I can say is:  WOW!!  The rotors have been drilled, thinned and (the mounting holes) counterbored so that the standard mounting bolts can be used;  I won't need to source longer mounting bolts!  I also got a pair of completely reconditioned, rebuilt and repainted calipers.  They look better than new and I also got phenolic pistons (lighter and corrosion proof).  Godffrey also supplied me with a modified speedo drive mount plate.
I'm also planning to replace the wheel bearings (front and rear) and swingarm bushings.
« Reply #78 on: May 09, 2014, 12:14:29 AM »
I might have to consider some new shocks, too.  The stockers are pretty shot, and the front suspension has been upgraded with Race Tech springs and emulators.  Maybe I'll go with Hagons or Works as replacements.
« Reply #79 on: May 09, 2014, 06:54:57 PM »
What about Devin's new Fox units?
I'll save my nickels for Fox or Works units for my builds incorporating modern front ends.  For this build, I want to keep it looking more period authentic.  The engine is stock and this is a lazy cruiser.
« Reply #80 on: May 09, 2014, 07:08:48 PM »
Look how clean these newly refurbished brakes are from Godffrey!
image_zps9efaaafb by Donald Leonhardt, on Flickr
image_zpsac093c9b by Donald Leonhardt, on Flickr
Phenolic pistons
image_zps766c7e63 by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 10:26:52 AM by SOHC4 Cafe Racer Fan »
« Reply #81 on: May 09, 2014, 07:10:33 PM »
New badges and new paint!
image_zps54897be9 by Donald Leonhardt, on Flickr
image_zps51babac0 by Donald Leonhardt, on Flickr
New keyless gas cap latch (Joker Machine part replacing the keyed latch)
image_zpsca6cc9bd by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 10:25:21 AM by SOHC4 Cafe Racer Fan »
« Reply #82 on: May 09, 2014, 07:26:20 PM »
My lame iPhone photos don't do it justice.  The paint is purty!
« Reply #83 on: May 10, 2014, 10:17:24 AM »
Just got an update from Rob aka Voxonda. My preload adjusters are almost done. The caps are finished and he just needs to turn the adjusters.
image_zps4f715a5b by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 10:26:18 AM by SOHC4 Cafe Racer Fan »
« Reply #84 on: May 10, 2014, 04:28:43 PM »
Main jets changed and that seemed to be the culprit (was running rough at about 5800 rpm).  The bike is now running great and sounds more civilized with the baffle in place.  I'll need to film a new video.
One of the stinkin' repro badges mounting stems snapped off!  It was likely a forging air bubble because it was ultra fragile.  Stem repaired and now both side covers are mounted.
Offline snowman
« Reply #85 on: May 16, 2014, 05:32:11 PM »
Don, looking great just don't know how you find the time with all your builds. Still working on my one build. LOL
Sent from my iPad using Tapatalk
« Reply #86 on: May 16, 2014, 08:04:47 PM »
I'm not sure if this bike qualifies as a true build.  More like performance upgrades (brakes, suspension, carbs, exhaust) and a cosmetic refresh.
The bike is running like a champ.  The combination of the new Avon tires, Race Tech fork internals, Hagon shocks, swingarm bushings and wheel bearings has made a quantum leap improvement in ride quality and handling. The bike used to wobbly like Jello at 75 mph.  Now it seems much more sure-footed.
Snowman, I get lots of professional wrench help.  Admittedly, my strongest suit with these bikes is design and knowing what I want.  Carb tuning is still an utter mystery to me.
I'm planning on checking out the VVMC 3rd Sunday Ride and the "Sunday Mass" at Deus Ex Machina.  Hope to see fellow SOHC4 members there.
« Last Edit: May 16, 2014, 08:19:58 PM by CB750 Cafe Racer Fan »
« Reply #87 on: May 16, 2014, 08:08:54 PM »
I just took my 550 for a ride to go swap it out for my RC51 (I'm going for a ride with some buddies up to Arrowhead and Big Bear tomorrow). I got the shock of my life when I gave the RC51 WOT -- it about yanked my arms off.  I've been so used to riding my 550 and 750 that I forgot how strong a modern V-Twin superbike can pull!
« Reply #88 on: May 17, 2014, 04:50:04 PM »
Went on an epic ride today on my modern bike (RC51) -- through the mountains and past Silverwood Lake, Gregory Lake and Arrowhead Lake, along Rim of the World, past Big Bear Lake and down the back side of the mountains to Redlands.  Amazing views and even more amazing twisties.  Some tight technical hairpins, but even more fun were the high speed sweepers.  I'm tired now, but I just filled up the 550 and wiped her down for a vintage ride tomorrow with the VVMC in Venice.  I'm meeting up with the Lossa crew (Jay and Steve) to ride up from Long Beach.
Here are some shots showing off the new dual rotor brake set up, painted body (with new badges), tires and Hagon shocks.  This little bugger only has a minor fraction of the power of the RC51, but it'll be fun to twist the throttle.  The suspension improvements and tires have made a big difference.
photo2_zps8c360cb6 by Donald Leonhardt, on Flickr
photo4_zps1a52ad2c by Donald Leonhardt, on Flickr
photo5_zpsc8375f0b by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 10:29:17 AM by SOHC4 Cafe Racer Fan »
« Reply #89 on: May 18, 2014, 04:19:20 PM »
Another great ride today.  But this time not many twisties or mountains.  I joined up with Jay and Steve of Lossa Engineering and three shop friends, and took the 550 out for the VVMC's 3rd Sunday Ride from Venice to Malibu (Neptune's Net), and then a return to Deus Ex Machina for the Sunday Mass (live band, free beer and burgers!).  It was an absolutely perfect weather day and a great ride.
« Reply #90 on: May 26, 2014, 06:51:07 PM »
I need to replace the idle jets (go up a size) on my carburetors -- she's prone to stalling at idle.  Yes, I know, it's a pod thing.
« Reply #91 on: May 26, 2014, 08:27:50 PM »
Not sure how I missed this thread? Great job!  I have similar plans for my 550 later this year (paint, brakes, suspension).
Offline riverfever
« Reply #92 on: May 26, 2014, 08:40:40 PM »
Bike looks incredible. The colors really turned out nicely. Very inspirational.
« Reply #93 on: May 26, 2014, 09:04:47 PM »
Thanks, guys!  She's a fun light-weight ride.
Offline Chaser60
  • 75 CB550
« Reply #94 on: May 27, 2014, 06:39:07 AM »
Great paint work.  Love the color.   I now find myself wishing for the dual front discs.   Love that look and I am sure the breaking performance is tight also.    I may need to start hunting for rotor, calipers and mounting gear.   Will back read this build to see how you attacked that.
« Reply #95 on: May 27, 2014, 07:17:50 AM »
Most of the front disc hardware came from Godffrey: calipers and mounts, drilled and thinned rotors and phenolic pistons, and a modified speedo drive plate. The discs were countersunk so longer bolts were not needed. Everything bolted in, but the alignment took some work on the right side caliper.
Braking performance with EBC pads is good. Not doubled but much improved.
« Reply #96 on: May 27, 2014, 08:00:50 AM »
There you go, great looking bike with upgrades but still instantly recognised as a CB550. Nice job.
Offline onetruepunk87
« Reply #97 on: May 27, 2014, 09:54:58 AM »
Love how this turned out, I've got a similar vision for my CB500 build. I have an extra brake rotor for mine already, this makes me want to grab an extra set of brake parts and some 550 forks.
« Reply #98 on: May 27, 2014, 04:28:30 PM »
Thanks, guys.  Onetrue, Godffrey supplies very nice reconditioned parts. My brake calipers looked brand new until some brake fluid took some paint off. One of the reasons I love powdercoating.
« Reply #99 on: June 10, 2014, 04:24:00 PM »
I need to swap out the idle jet, as the 550 is overly prone to stalling at idle.  I also need a new oil sump gasket, as a leak has developed below.   >:(
