Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 151750 times)
Offline Tews19
  • I am no
Re: 1975 CB550K1 - Stock-ish Restomod
« Reply #175 on: September 23, 2014, 02:57:33 PM »
That said, I've notice the nights are getting cold -- down to the low 60s in the middle of the night.  Brrrrrr!!
[/quote]
Oh that's grimey! We hit 60 now and we are happy!
1970 Honda CB750 survivor.
« Reply #176 on: September 23, 2014, 03:05:33 PM »
[/quote]
Yeah, but you have Cycle X, the Packers (STILL no NFL football team in LA), lots of German food, mid-West farmers' daughters and cheese.  All good!  We just have blazingly hot women that have attitude and/or are head cases.  :o  Except for my girlfriend, of course! ;)
Offline Tews19
  • I am no
« Reply #177 on: September 23, 2014, 03:10:08 PM »
[/quote]
 Farm girls???????? Sigh...... Only if you knew.
« Reply #178 on: September 23, 2014, 03:13:09 PM »
[/quote]
What?!  The Beach Boys lied!?   ::)
Offline calj737
  • I refuse...
« Reply #179 on: September 23, 2014, 03:18:35 PM »
They grow farm girls in VT too. Just ask my wife! No make-up, no jewelry, 1 black dress, 1 pair of pumps.
I'll have to tell you the story of the trip to the jewelry store one day...
« Reply #180 on: September 23, 2014, 04:17:23 PM »
I don't know about the no make up, etc. I just thought they were sweet, pretty, down-to-earth girls!
Offline Free Booter
  • My Build: CB750k5
  • Meh.
« Reply #181 on: October 15, 2014, 10:52:41 PM »
Have a TKAT fork brace on my 750. I love it!
« Reply #182 on: October 18, 2014, 04:19:19 PM »
I'm trying to rid the bike of speed wobble that seems to come on at about 80-85 mph.  Very unsettling.
The bike has new roller bearings in the steering head and wheels (front and back), and new bronze swingarm bushings.
The only thing not replaced were the bottom bushings for the shock mounts.
Any other ideas??
« Last Edit: October 20, 2014, 08:30:10 AM by CB750 Cafe Racer Fan »
Offline Tews19
  • I am no
« Reply #183 on: October 18, 2014, 04:23:45 PM »
Is it possible the fork fluid is uneven? Or possibly the tire needs to be trued?
« Reply #184 on: October 18, 2014, 04:26:46 PM »
Fork fluid is even -- checked when the forks were rebuilt with new RaceTech internals.
I'll lift the wheel and spin it to verify for trueness.
It's strange that it only comes on at the "frequency" of that higher speed.
Offline Tews19
  • I am no
« Reply #185 on: October 18, 2014, 04:30:35 PM »
Is it possible maybe the wheel itself moved on the rim?
« Reply #186 on: October 18, 2014, 04:32:28 PM »
Seriously doubt it.  No burn outs or rear lock ups to torque it.
Offline Tews19
  • I am no
« Reply #187 on: October 18, 2014, 04:36:21 PM »
WEAK! Just playing!
« Reply #188 on: October 18, 2014, 04:40:38 PM »
I guess I didn't catch the tire trueness comment and thought you were referring to the wheel.
So does anyone have any real suggestions.
Offline nvr2old
« Reply #189 on: October 18, 2014, 04:58:33 PM »
I had a couple of questions that may stir up a hopeful solution..
I read back through an earlier post that said you took it out for 5-6 hrs. and rode it pretty hard.  Did it display the shake then..?  Does it happen only in a straight line?  You also mentioned it was a little unsettling going into corners.  Is that at slow speeds or fast sweepers?  Could it be something as simple as a slightly over-tightened steering stem nut?  Just throwing things out there.. ;)
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
« Reply #190 on: October 18, 2014, 05:12:52 PM »
Good questions and suggestions.
The hard riding was in twisties and I don't recall having the wobble.  Only on the straights and on the freeway.  The unsettling was a corner or two where the pavement was rough and I lost some traction on the front end.  I am not entirely positive but I think the wobble is coming from the rear.  I'll check the tension on the nut, too.  Thanks!
« Reply #191 on: October 18, 2014, 06:13:25 PM »
Are the wheels aligned? A weave can start from a tight or loose steering stem. After installing often times they will need to be retightened a couple times. Are the shocks longer than stock, front end taller or shorter than stock? Spokes tight, tires seated properly, pressures correct? No fairing of any kind?
Did you have the S/A bushings made or did you buy them from a supplier? Some bushings tend to be slightly oversize. If I may I would suggest a different solution to torqueing the swingarm pivot bolt. With the shocks & wheel removed, and the pivot well greased, lift the arm to full travel top. Tighten the nut until the arm drops slowly (smoothly) under its own weight to the bottom of the travel. Often I found this method takes a bit more torque than Honda recommends.
Good luck, you'll find the cause.
« Reply #192 on: October 19, 2014, 02:39:52 AM »
Brent.
Thanks for all of the ideas.  Now for the process of elimination.  I'll get to checking the pivot.
The bushings were sourced from a legit supplier.  They went in normally -- nuts and washers method.
« Reply #193 on: October 20, 2014, 10:38:32 AM »
So I rode the bike yesterday and notice another distinction.  The wobble/oscillation only seems to occur on grooved freeway pavement, and not on asphalt.  My 750, however, doesn't do this.
« Reply #194 on: October 20, 2014, 03:15:30 PM »
Very likely different tires.
« Reply #195 on: October 20, 2014, 03:32:45 PM »
I agree, some tires track lines and grooves way more than others, thats where those crappy Firestones really fail... ;D ;)
Offline Tews19
  • I am no
« Reply #196 on: October 20, 2014, 03:42:51 PM »
That's normal if I'm thinking of the same road distinction. Lately around here the highway and more driven on roads have these like 1/2-1" creases. You can hear the pitch of the tire humming more as well on these newer roads.
« Reply #197 on: October 20, 2014, 04:24:06 PM »
Interesting.
I run Avon RoadRiders on my 550.  Bridgestone Spitfires on my 750.  I am planning to replace the Spitfires for something stickier.  The Spitfires feel like I'm riding on hard plastic hoops -- lack of feel in the corners, but no wobble.  I was thinking of swapping to the Avons, since they have better feel, but maybe I should try Bridgestone BT45s instead.
I'd be better off oiling up my tires than using Firestones in corners!
« Last Edit: October 20, 2014, 04:25:47 PM by CB750 Cafe Racer Fan »
Offline Tews19
  • I am no
« Reply #198 on: October 20, 2014, 04:27:51 PM »
I've used BT45s on a few CB's. I really like them and will continue to use them. I did however only get 5500 miles out of the rear. The middle is worn bad and I don't do burn outs.
« Reply #199 on: October 20, 2014, 04:38:49 PM »
I don't mind so much about getting a ton of miles out of them, as long as they give decent traction.  I'm not used to getting a huge number of miles on my sportbike tires S20s.
