Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 148846 times)
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #575 on: December 30, 2016, 05:55:17 PM »
Fuel injection will spoil you (in a good way).
No kidding.  The throttle response with fuel injection is just so immediate!
Don, have you ever considered swapping one of your vintage Honda's over to fuel injection system?  I've kicked around the thought of that with the 550 but I would imagine that would involve some pretty pricey parts.
There have been a couple of members that have taken on the task.  It involves some pricey parts and brain damage -- plus a more robust charging system to power the fuel pump, etc.  I don't believe you gain any significant engine performance gains from it though.
« Reply #576 on: December 30, 2016, 06:07:42 PM »
Have you seen the 450 build where they are putting a cb500r motor in the frame?
It is an interesting build for a bike/roller that was without its motor.  Buying a wrecked 500R without damage to front end and motor...
David
No, David, I haven't seen it.  Link?
This sounds like a fun swap.  Reminiscent of my buddy Ian Halcott stuffing a punched out Kawasaki 500ex motor (to 600cc) and mounting it into a CB550 frame.  It's a very fun bike to ride.  http://www.returnofthecaferacers.com/2013/08/the-thorn-by-twinline-motorcycles.html
Unfortunately, the CB500R motor (471cc parallel with EFI) only puts out 47 bhp at the crank; its engineered primarily for entry level in stepped licensed countries, so it's a little under-powered and the juice isn't worth the squeeze to me.  You also get to hide an airbox and lots of wiring harness components.
Online RAFster122s
« Reply #577 on: December 30, 2016, 08:44:39 PM »
http://forums.sohc4.net/index.php/topic,161536.0.html
The Amalmagm build of the 450 frame with cbr500r motor is in above link...
Sure, it is not a screamer, but it will be a light entertaining bike. Anyone who knows old Hondas will do a double take.  There have been one or two modern 175 dirt bike motors dropped into a CA95 frame.  Not as fun a setup, a CB92 or CB95 would be ideal for that retro mod would be a platform with more performance potential.
David
« Reply #578 on: December 30, 2016, 09:39:06 PM »
David
David,
Very cool build thread. I get what he's trying to accomplish -- going for modern, EFI reliability.  By going on a 80 lb. diet he might have a pretty quick little bike indeed.  Smart to keep all of the stock electronics.  He could probably flash tune the ECU to squeeze out some additional performance from the stock 47 hp.
Online RAFster122s
« Reply #579 on: December 31, 2016, 12:31:30 AM »
Isn't he going with a Microsquirt system to tweek the power curve even more than stock.  It will be entertaining.  So, the 98-105 hp at rear wheel on the cbr600rr would be a bit too much for the 550 chassis even strengthened.  Detuning it could make itvpalatable enough to yield a fun transplant and remain a safe one.  You overpower a chassis too much and it just gets dangerous.
Offline Restoration Fan
  • My wife will never call me
« Reply #580 on: December 31, 2016, 03:21:33 AM »
No, he said he was using all stock Honda parts on the motor so I don't think he's going with the MicroSquirt.  He's going for the speed-through-lightening approach and essentially just wants the low-hassle of a fuel-injected modern engine in a vintage chassis that has all the non-essential pieces removed and a Suzuki modern front end.
It is a cool build.
« Reply #581 on: December 31, 2016, 08:39:38 AM »
Agreed. If you up the ante that far, I think you have to rethink the project with a custom chromoly frame.
« Reply #582 on: December 31, 2016, 08:41:46 AM »
It is a cool build.
After reading the thread, I get his approach.  Personally, I'd want to squeeze a little more power out of the CB500R engine.  I bet he could get a little more uuumph with a re-flash of the ECU, header, and maybe cams.
« Reply #583 on: February 13, 2017, 01:58:36 PM »
For those of you wanting more information and photos of Devin at Cognitomoto's new rear disc hub that Cal and I (and others) are using on our builds:
Here's a link to the one for CB550's
https://cognitomoto.com/collections/hubs-wheelgoods/products/cb500-cb550-rear-hub-disc-brake-conversion
And for CB750's
https://cognitomoto.com/collections/hubs-wheelgoods/products/cb750-69-78-rear-hub-disc-brake-conversion
« Reply #584 on: February 14, 2017, 02:30:22 PM »
Official member of the billet Cognitomoto disc-rotor conversion hub club:
16463670_1315198071837058_6422229687994640332_o_zpsqkfqymiv by Donald Leonhardt, on Flickr
IMG_0883_zpszolcgai3 by Donald Leonhardt, on Flickr
IMG_0884_zps2kftquq3 by Donald Leonhardt, on Flickr
IMG_0885_zpsy1ylfq5o by Donald Leonhardt, on Flickr
FYI - the machining looks even better in person, and Devin did a fantastic job of packing the parts (double box method) so they arrived safely.
« Last Edit: July 05, 2017, 05:19:11 PM by SOHC4 Cafe Racer Fan »
Offline timbo750
« Reply #585 on: February 14, 2017, 02:32:13 PM »
Is that the front or rear hub?
« Reply #586 on: February 14, 2017, 02:37:10 PM »
Rear -- hence, the machining for the cush drive rubber inserts.
« Reply #587 on: February 14, 2017, 02:41:23 PM »
Don, did I read somewhere that they are heavier than stock...?   That would be a deal killer for me...
« Reply #588 on: February 14, 2017, 02:48:38 PM »
Cal weighed them in at 2 lbs. heavier than stock.  I assume that was compared to a stock 550 drum hub.  A stock 750F0/F1 hub with disc and caliper is almost certainly heavier, because the F hub uses a much heavier rotor, caliper and bracket.  By that comparison, I imagine that the Cognitomoto hub set up is lighter.
On top of that, you get modern performance.
Offline calj737
  • I refuse...
« Reply #589 on: February 14, 2017, 03:05:13 PM »
Fully outfitted with caliper (Brembo) and modern rotor, the rear hub with cush drive installed was 2# heavier than the stock drum-equipped hub. I haven't considered weighing a 750f hub outfitted and equipped, but if someone does have and can, the Cognito tips the scales at 13# versus 11# stock.
Mick, I seriously doubt you'll ever detect the 2# if you are in the market.
Offline Camrector
« Reply #590 on: February 14, 2017, 03:14:26 PM »
Wow am I the only one who got the hub in black? Sahweet!
« Reply #591 on: February 14, 2017, 03:18:37 PM »
I believe Cal's is powdercoated black and Gennaro's is being anodized black.
« Reply #592 on: February 14, 2017, 03:19:06 PM »
I'm not sure about Ron's.
Offline calj737
  • I refuse...
« Reply #593 on: February 14, 2017, 03:41:48 PM »
Mine arrived vapor blasted, getting powder coated in silver.
« Reply #594 on: February 14, 2017, 03:51:41 PM »
Nice.  I don't know why, but I thought it was going to be black.  Silver will be a nice distinction.
I forgot about your photobucket of your laced front.  The powdercoat almost makes it look chromed or like polished aluminum.
« Last Edit: February 14, 2017, 03:57:26 PM by CB750 Cafe Racer Fan »
Offline GV1390
  • Express Gratitude.
« Reply #595 on: February 14, 2017, 04:26:18 PM »
Mine won't be black but will be anodized.
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
« Reply #596 on: February 14, 2017, 04:37:46 PM »
Purple?  Tri-colore?
« Reply #597 on: February 14, 2017, 04:40:59 PM »
I still can't work out why he made a heavier hub, have you seen the one CycleX have, it would be less than half this weight, Rear brake performance is low on my scale of mods, I barely use it, I'd be more interested in unsprung weight, hence the question... ;)
Cal, nah, not interested mate, I have no doubt its up to Devins high standards though... ;)
« Reply #598 on: February 14, 2017, 05:10:42 PM »
Although Ken's had the newer lighter model on his wheels page for a year plus, they are not available.
http://www.cyclexchange.net/Wheel%20Page.htm
Offline calj737
  • I refuse...
« Reply #599 on: February 14, 2017, 05:17:52 PM »
It's not that he made it heavier, it's that it came out heavier. The stock part is cast and hollow internally to the hub center. His is milled through. Short of live tooling on a CNC lathe, you'll spend an inordinate amount of time milling away the bulk of the material left over to gain what, 2 pounds of weight savings? It's not that critical really.
I can see that many would pass on this setup due to the expense, but given that F hubs, disks and calipers are becoming increasingly more rare, it's a nice solution. Unlike the CycleX, this is not an adapter but an entirely new hub. The unit they had on the market in years past was replacement rotor carrier installed in the drum. I haven't looked Waterhouse they changed that design or not.
But I'm rather happy with the result and it will allow fully modern brakes on my boys bike. And never underestimate the importance of your rear brake Mick  even though it accounts for less than 20% of stopping power, it is critical in many circumstances for safety, control, or emergency stops.  :)
Anecdote now: I rode for probably a good 10 years almost never touching my rear brake. Then I hooked up with a VA State Trooper who rode on their bike unit. I was taking my then girlfriend to her MSF Class. The Trooper and I became friends pretty quickly as both were riding BMWs. Anyway, we were off riding in the Blue a Ridge (70CB will know these roads) and he was flat out eating my lunch up and down the hills. We pulled off for some lunch and I asked, "Okay, what's up with the dust trails?"  He laughed and said, "You need to learn to use your rear brake to ride better, more safely, and faster."
So he gave me some pretty sound instruction, section by section and many pointers. The next class session, I hopped on my bike and did nothing but brake drills, all rear brake. I will tell you, in my opinion, it is quite possibly the single most contributing reason why I've never been on the pavement from riding. Good brake skills (front and rear) matter.
Devin's hub isn't anything special above an F setup, other than perhaps a made-for modern rotor, but I know I could retrofit a modern rotor to an F disc. I am just delighted to have helped span a new, missing product for these vintage bikes.
Anecdote over.  :D
