Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 166537 times)
0 Members and 14 Guests are viewing this topic.
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #525 on: December 30, 2016, 05:55:17 PM »
Fuel injection will spoil you (in a good way).
No kidding.  The throttle response with fuel injection is just so immediate!
Don, have you ever considered swapping one of your vintage Honda's over to fuel injection system?  I've kicked around the thought of that with the 550 but I would imagine that would involve some pretty pricey parts.
There have been a couple of members that have taken on the task.  It involves some pricey parts and brain damage -- plus a more robust charging system to power the fuel pump, etc.  I don't believe you gain any significant engine performance gains from it though.
« Reply #526 on: December 30, 2016, 06:07:42 PM »
Have you seen the 450 build where they are putting a cb500r motor in the frame?
It is an interesting build for a bike/roller that was without its motor.  Buying a wrecked 500R without damage to front end and motor...
David
No, David, I haven't seen it.  Link?
This sounds like a fun swap.  Reminiscent of my buddy Ian Halcott stuffing a punched out Kawasaki 500ex motor (to 600cc) and mounting it into a CB550 frame.  It's a very fun bike to ride.  http://www.returnofthecaferacers.com/2013/08/the-thorn-by-twinline-motorcycles.html
Unfortunately, the CB500R motor (471cc parallel with EFI) only puts out 47 bhp at the crank; its engineered primarily for entry level in stepped licensed countries, so it's a little under-powered and the juice isn't worth the squeeze to me.  You also get to hide an airbox and lots of wiring harness components.
« Reply #527 on: December 30, 2016, 08:44:39 PM »
http://forums.sohc4.net/index.php/topic,161536.0.html
The Amalmagm build of the 450 frame with cbr500r motor is in above link...
Sure, it is not a screamer, but it will be a light entertaining bike. Anyone who knows old Hondas will do a double take.  There have been one or two modern 175 dirt bike motors dropped into a CA95 frame.  Not as fun a setup, a CB92 or CB95 would be ideal for that retro mod would be a platform with more performance potential.
David
« Reply #528 on: December 30, 2016, 09:39:06 PM »
David
David,
Very cool build thread. I get what he's trying to accomplish -- going for modern, EFI reliability.  By going on a 80 lb. diet he might have a pretty quick little bike indeed.  Smart to keep all of the stock electronics.  He could probably flash tune the ECU to squeeze out some additional performance from the stock 47 hp.
« Reply #529 on: December 31, 2016, 12:31:30 AM »
Isn't he going with a Microsquirt system to tweek the power curve even more than stock.  It will be entertaining.  So, the 98-105 hp at rear wheel on the cbr600rr would be a bit too much for the 550 chassis even strengthened.  Detuning it could make itvpalatable enough to yield a fun transplant and remain a safe one.  You overpower a chassis too much and it just gets dangerous.
Offline Restoration Fan
  • My wife will never call me
« Reply #530 on: December 31, 2016, 03:21:33 AM »
No, he said he was using all stock Honda parts on the motor so I don't think he's going with the MicroSquirt.  He's going for the speed-through-lightening approach and essentially just wants the low-hassle of a fuel-injected modern engine in a vintage chassis that has all the non-essential pieces removed and a Suzuki modern front end.
It is a cool build.
« Reply #531 on: December 31, 2016, 08:39:38 AM »
Agreed. If you up the ante that far, I think you have to rethink the project with a custom chromoly frame.
« Reply #532 on: December 31, 2016, 08:41:46 AM »
It is a cool build.
After reading the thread, I get his approach.  Personally, I'd want to squeeze a little more power out of the CB500R engine.  I bet he could get a little more uuumph with a re-flash of the ECU, header, and maybe cams.
« Reply #533 on: February 13, 2017, 01:58:36 PM »
For those of you wanting more information and photos of Devin at Cognitomoto's new rear disc hub that Cal and I (and others) are using on our builds:
Here's a link to the one for CB550's
https://cognitomoto.com/collections/hubs-wheelgoods/products/cb500-cb550-rear-hub-disc-brake-conversion
And for CB750's
https://cognitomoto.com/collections/hubs-wheelgoods/products/cb750-69-78-rear-hub-disc-brake-conversion
« Reply #534 on: February 14, 2017, 02:30:22 PM »
Official member of the billet Cognitomoto disc-rotor conversion hub club:
16463670_1315198071837058_6422229687994640332_o_zpsqkfqymiv by Donald Leonhardt, on Flickr
IMG_0883_zpszolcgai3 by Donald Leonhardt, on Flickr
IMG_0884_zps2kftquq3 by Donald Leonhardt, on Flickr
IMG_0885_zpsy1ylfq5o by Donald Leonhardt, on Flickr
FYI - the machining looks even better in person, and Devin did a fantastic job of packing the parts (double box method) so they arrived safely.
« Last Edit: July 05, 2017, 05:19:11 PM by SOHC4 Cafe Racer Fan »
Offline timbo750
« Reply #535 on: February 14, 2017, 02:32:13 PM »
Is that the front or rear hub?
« Reply #536 on: February 14, 2017, 02:37:10 PM »
Rear -- hence, the machining for the cush drive rubber inserts.
« Reply #537 on: February 14, 2017, 02:41:23 PM »
Don, did I read somewhere that they are heavier than stock...?   That would be a deal killer for me...
« Reply #538 on: February 14, 2017, 02:48:38 PM »
Cal weighed them in at 2 lbs. heavier than stock.  I assume that was compared to a stock 550 drum hub.  A stock 750F0/F1 hub with disc and caliper is almost certainly heavier, because the F hub uses a much heavier rotor, caliper and bracket.  By that comparison, I imagine that the Cognitomoto hub set up is lighter.
On top of that, you get modern performance.
Offline Camrector
« Reply #539 on: February 14, 2017, 03:14:26 PM »
Wow am I the only one who got the hub in black? Sahweet!
« Reply #540 on: February 14, 2017, 03:18:37 PM »
I believe Cal's is powdercoated black and Gennaro's is being anodized black.
« Reply #541 on: February 14, 2017, 03:19:06 PM »
I'm not sure about Ron's.
« Reply #542 on: February 14, 2017, 03:51:41 PM »
Mine arrived vapor blasted, getting powder coated in silver.
Nice.  I don't know why, but I thought it was going to be black.  Silver will be a nice distinction.
I forgot about your photobucket of your laced front.  The powdercoat almost makes it look chromed or like polished aluminum.
« Last Edit: February 14, 2017, 03:57:26 PM by CB750 Cafe Racer Fan »
Offline GV1390
  • Express Gratitude.
« Reply #543 on: February 14, 2017, 04:26:18 PM »
Mine won't be black but will be anodized.
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
« Reply #544 on: February 14, 2017, 04:37:46 PM »
Purple?  Tri-colore?
« Reply #545 on: February 14, 2017, 04:40:59 PM »
I still can't work out why he made a heavier hub, have you seen the one CycleX have, it would be less than half this weight, Rear brake performance is low on my scale of mods, I barely use it, I'd be more interested in unsprung weight, hence the question... ;)
Cal, nah, not interested mate, I have no doubt its up to Devins high standards though... ;)
« Reply #546 on: February 14, 2017, 05:10:42 PM »
Although Ken's had the newer lighter model on his wheels page for a year plus, they are not available.
http://www.cyclexchange.net/Wheel%20Page.htm
« Reply #547 on: February 14, 2017, 09:58:20 PM »
FYI - Australian Troy Bayliss (WSBK Champion and MotoGP winner) is also a big fan of the rear brake, in his latest book A Faster Way.  So is WSBK and BSBK Champion Tom Sykes.
I use both but, of course, the front much more.  I'll have to work on drills.
« Reply #548 on: February 15, 2017, 12:06:13 AM »
Each to his own Don, there are racers that don't use it at all, personal, preference as well, some guys only use it to control wheel spin exiting corners, or stability mid corner, I mainly use it when riding slow for balance and stability, sometimes for scrubbing speed mid corner while holding a steady throttle, never with the throttle off {in a corner}, I've had guys tell me I'm mad because I use the front deep into the corner entrance, get to know your bike well and use the brakes as you see fit, Always buy the best tires you can, everyone's different.. The rear brake has probably thrown more riders down the road than any other factors combined....
PS, I'm a lot slower now {self preservation has kicked in}.... ;D
Who told you CycleX weren't selling them any more..{I inquired a little while ago and they could still get them}? As far as I know they never made the hub so its still a part that can be bought, they aren't the only shop selling light hubs either.. ;)
Cal, I wasn't referring to the "adapted" rear hub, I'm sure that's heavy too, its the one they used on their 750/4 race bike.   ;)
Interesting tidbit about rear brakes..
I had been riding bikes for 25 years and thought I knew how to ride? Well, I learned a real lesson about the rear brake. DON'T use it unless you are an "EXTREMELY" skilled rider.  I still use mine when I'm just putting around town but once I hit the curves or open road, I move my toe back to the foot peg so I'm not tempted to use it. Any  time you apply the front brake it takes weight off the rear tire and make it susceptible to locking up. And believe you me, it doesn't take much in certain situations. If you are hard on the front brakes and lock the rear tire, you just barely have time for a quick "Oh #$%*" and you are on the deck. I know, I was there!
When I attended Mike Sullivans Race School in Spokanne Wa. The very first thing he told us was if we couldn't ride like Valentino Rossi, "DON'T USE THE REAR BRAKE"! He said most of the crashes from first time racers was due to using the rear brake.
« Reply #549 on: February 15, 2017, 12:11:12 PM »
Mick,
My self-preservation has also kicked in. I'll leave the stunt riding for the young guys like GV.
