Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 150725 times)
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #675 on: June 10, 2018, 08:59:59 AM »
Since I am going with a conventional handlebar, Beringer is going to swap my MC with the tilted reservoir for an integrated model.
Better send that old unit along to me for further testing  ;)
The MotoScope uses breakout boxes, increasing the required real estate for a wiring install. Just an FYI.
LOL. I think Philippe has someone lined up for my “used” MC. The wider bar just made more sense ergonomically with the standard foot pegs.
The Motoscope was an open box but new with the breakout box and mounting plate for less than $300 so it was a good deal.
« Reply #676 on: June 10, 2018, 09:03:13 AM »
You still loving the Beringer brakes? Would it be something you would do if you had to spend the money?  Or would a fork swap be a preferred route, although a more expensive one?
You running a led headlight yet or HID or halogen in h4 housing?
As always, pics or it didn't happen...the moto or mantra of much of this site...guess that makes us a visually stimulated crowd...
I do love the Beringers but I got a sweet deal because I know the distributor.
If money IS a consideration, I would opt for an older R6 conventional fork and brakes.
« Last Edit: June 10, 2018, 12:43:26 PM by SOHC4 Cafe Racer Fan »
« Reply #677 on: June 11, 2018, 03:40:19 PM »
A few upgrades percolating:
My speedo cable broke because my speedo driver has been rotating (because of a mod to its housing to accommodate the second disc).  I've decided that since the bike has been converted to motogadget wiring to simply integrate a motogadget electronic gauge.
Godfrey makes a nice spacer if you want to remove the speedo drive.
I installed one on the Park Racer since it has no speedo.
« Reply #678 on: June 11, 2018, 03:52:47 PM »
I looked for his site, but could not find a working link.  How does it compare to the J. Webster spacer?  http://jwebsterdesigns.com/shop/speedometer-gear-drive-delete/
I might just mod my stock one further.
Offline riverfever
« Reply #679 on: June 11, 2018, 08:31:02 PM »
I like that gauge Don.
« Reply #680 on: June 11, 2018, 09:47:41 PM »
Thanks, Chris. It is smaller than I expected but I like it.
« Reply #681 on: June 13, 2018, 06:17:10 PM »
Godfreys is a smaller diameter, both look to be very nice and priced about the same.
I dont have a pic but can shoot one if you are interested.
Offline Godffery
  • Godffery's Garage
« Reply #682 on: June 16, 2018, 10:06:22 PM »
Here is a link to the *NEW* web site: https://godfferysgarage.com/
(Disclaimer; the site is still a work in progress)
« Reply #683 on: April 13, 2019, 09:44:21 PM »
Did some clean up work this week on the Blue.
I vapor blasted my engine covers, had my buddy blast my carburetors and cleaned up my rear fender. Still to come, new from fender.
« Reply #684 on: May 20, 2019, 07:15:51 PM »
My neutral light sensor was getting fussy, so I removed it and vaporblasted the neutral switch rotor and stator so that the metal contact surfaces were bright and shiny again, and aligned them.  Now the bike can find neutral easier.
« Reply #685 on: May 20, 2019, 07:16:20 PM »
Also swapped out all of my turn indicators for LED flashers.
« Reply #686 on: May 25, 2019, 01:09:34 PM »
Seat stripped, re-foamed with a thinner profile (and new firmer foam) and re-covered.
IMG_5624 by Donald Leonhardt, on Flickr
New LED signals and brake light.
IMG_5627 by Donald Leonhardt, on Flickr
IMG_5626 by Donald Leonhardt, on Flickr
IMG_5628 by Donald Leonhardt, on Flickr
« Reply #687 on: May 25, 2019, 01:14:04 PM »
My buddy Dave does vapor blasting (like Nils) here in Long Beach and San Diego.  My carburetors were originally painted black but the paint started flaking after a few ultrasonic baths, so they've been disassembled and vapor blasted.  Next, Dave is cerakoting them black so I won't have to worry about the finish again.
« Reply #688 on: June 03, 2019, 04:16:49 PM »
Mounted 10 mm rear and 8 mm front stand spools this last weekend.  This is a great mod, especially if you've deleted the center stand.
For the rear, you will need some patience with the tap to run threads through the steel.
For the front, you just hog the rear bottom hole on the fork lower and tap for 8 mm.
IMG_5812 by Donald Leonhardt, on Flickr
IMG_5810 by Donald Leonhardt, on Flickr
IMG_5809 by Donald Leonhardt, on Flickr
IMG_5808 by Donald Leonhardt, on Flickr
« Last Edit: June 03, 2019, 04:19:39 PM by SOHC4 Cafe Racer Fan »
Offline SF
  • I burn gas very well
« Reply #689 on: June 03, 2019, 05:40:58 PM »
Very nice mods.....well done
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #690 on: June 03, 2019, 06:16:26 PM »
Thanks!
Offline calj737
  • I refuse...
« Reply #691 on: June 04, 2019, 04:02:27 AM »
It looks like your front axle cap is installed backwards. The small "dot" goes to the front which will create a small gap oriented to the rear of the shock leg.
Offline LastChancer88
  • “We’re gonna have to order that”
« Reply #692 on: June 04, 2019, 11:31:37 AM »
What foam did you use?  This is something I am very interested in doing as well.
1973 Honda CB500 Four
1973 Suzuki TC125
« Reply #693 on: June 04, 2019, 11:43:54 AM »
I did not do the re-upholstery work.
It was done by:
Revs Customs Upholstery in Garden Grove, CA (automotive and motorcycle upholstery)
714-548-2792
@revs_customs on Instagram
I'm not sure what specific type of foam he uses, but I'm sure you could ask.
« Reply #694 on: June 04, 2019, 12:44:16 PM »
It was done by:
714-548-2792
Oh for sure.  Thanks!  My seat is just looking a little saggy
1973 Suzuki TC125
« Reply #695 on: June 04, 2019, 01:38:42 PM »
It was done by:
714-548-2792
That’s why I didn’t want to just trim down the 40-year old foam and opted for new foam.
Check out river’ thread. He just refoamed his seat. http://forums.sohc4.net/index.php/topic,176846.0.html
« Last Edit: June 04, 2019, 01:41:18 PM by SOHC4 Cafe Racer Fan »
« Reply #696 on: June 04, 2019, 02:53:47 PM »
Nice upgrades Don!  It's easy to get addicted to vapor blasting, even the kids are "Vaping" now!
« Reply #697 on: June 04, 2019, 03:27:37 PM »
 ;D
« Reply #698 on: June 15, 2019, 05:51:02 PM »
Carburetors were vapor blasted and then cerakoted satin black. Cerakote (not ceramic powder coating) is as durable than powder coating and thinner.
If you like the vapor blasting, hit up Nils at Restocycle (https://www.restocycle.com/) or Dave Hargreaves in Signal Hill, CA (619) 980-0089.  Dave also does cerakote.
Offline river
« Reply #699 on: June 15, 2019, 06:38:21 PM »
Don, the blasted engine covers turned out really nice. Seat profile looks super. Are you happy with it now?
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
