Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 153021 times)
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #750 on: May 24, 2022, 05:34:42 AM »
The hydraulic clutch appears to work great.  Unfortunately, the re-wire of the bike (and absence of timely warranty replacement support from Motogadget) has delayed ride testing.
Have you got any photos of the bike with the hydraulic lines installed?
Bummer about the electrical delays.  =/
I was waiting to take some photos after I had everything buttoned up and I had the bike detailed.  Right now, its all shiny and clean, has the clutch plumbed, but the wiring is amiss.
Motogadjet needs to Do You right Don;send you the replacement along with a few $ for the aggravation they put you through.
Boy what a fantasy world you live in...
Start making some noise and bug them weekly and then daily talking to them until they do it to make things right...
« Reply #751 on: May 24, 2022, 08:18:47 AM »
Motogadjet needs to do You Right Don;send you the replacement along with a few $ for the aggravation they put you through.  >:(   Sorry won't do when you want to ride.
No kidding.  I still haven't received my repaired or replacement m-unit sent back to them over a year ago!
« Reply #752 on: June 26, 2022, 12:41:12 PM »
I finally received my original M-Unit back from Motogadget.  It looks like my Motoscope gauge, however, may have been damaged with a short.  When I hook it up to power I get nothing.
On better news, the hydraulic clutch feels buttery smooth and very light.
« Reply #753 on: June 26, 2022, 12:53:05 PM »
What does the Motoscope gauge do,read the engine ?
« Reply #754 on: June 26, 2022, 01:10:39 PM »
It’s an LED electronic gauge - RPM, Speed, warning lights, signals, odometer, etc.
« Reply #755 on: June 26, 2022, 01:23:55 PM »
How does it differ from your M-unit ?
« Reply #756 on: June 26, 2022, 02:02:15 PM »
The M-Unit is a solid-state electronic control unit that replaces the fuse-block.  It also controls other functions, such as signal (momentary signal (3 flashes), sustained signals, tachometer, warning lights, etc.)  The Motoscope is the electronic gauge that replaces your analog speedometer and tach.  It is the visual instrument/dash.
So here's the m-unit:
Untitled by Donald Leonhardt, on Flickr
This is a Motoscope instrument
motoscope by Donald Leonhardt, on Flickr
« Reply #757 on: June 26, 2022, 02:54:13 PM »
Oh dude,I thought that the M-unit 'was' your scope !   :o and that it's what you had been waiting for;the Motoscope is Also uber important and I hope you can get that 'readout' gauge replaced without too much hassle Don.  :)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #758 on: June 26, 2022, 05:34:09 PM »
Looking at the M unit... It is essentially just a PLC but for our bike correct?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
« Reply #759 on: June 26, 2022, 06:40:08 PM »
Is it a real “Programable Logic Controller” or are you restricted to preset parameters.
Does it have assignable and programmable I/O or must you follow a predetermined wiring diagram…?
Thanks 🤔
« Reply #760 on: June 26, 2022, 06:52:54 PM »
It is programmable but to a limited degree.  Feel free to check out the manual:
https://motogadget.com/shop/media/downloads/manual/munit_blue_manual_en_2.0.pdf
« Reply #761 on: June 26, 2022, 09:06:59 PM »
Yeh, I searched it after I queried.
Looks like only 2+2 are assignable and your restricted to preset ranges within the preprogrammed I/O..
Still probably would benefit from ssr, scr, triac type relays instead of mechanical.   I’ll read on…👍
