Yeah, I'm planning to do the same thing this weekend.
Glad to hear it worked for you. I was thinking I should be able to remove the bottom case without removing the jugs and head, but wasn't 100% sure... thanks for posting.
It's going to be a pain to flip the engine over a couple times now that the jugs and head are on. It's also going to be tricky to clean up all the hondabond not being able to remove the crank and transmission. Hopefully it will come off easily since it hasn't gone through a heat cycle.
