I got the tapered kit from DCC. Not sure if it's allballz or not, but it is tapered.
I have the races pressed in already, but I'm confused about the bottom washer on the stem. The instructions on the box say to tap the washer on to the stem then the bottom bearing.
Is the washer supposed to fit very tight? It feels a lot tighter than one would think. And does the bearing need to be pressed on as well?
No pictures right now because I'm at work, but if needed, I can provide tonight.
