Author Topic: Reasons for a GL1000 front end conversion.  (Read 9053 times)
Offline canoscan
Re: Reasons for a GL1000 front end conversion.
« Reply #25 on: March 09, 2014, 05:01:11 PM »
I don't mind at all.  Unfortunately, it could be several months before I get to ride this thing as it is involved in several expensive and time consuming  modifications.  There are several others here who have done the GL swap and I am surprised more of them are not chiming in.  Have you tried a search of the projects forum?
Yea I've viewed many, except for I can't find any before and after opinions, except for with regards to improved braking.
Offline IBleedHondaRed
    • OEM Parts diagrams from my shop
« Reply #26 on: March 10, 2014, 09:15:59 AM »
DMB reference? everyday?
OEM DIAGRAMS http://www.shopstarcitypowersports.com/OEMpartfinder.htm
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
1989 Hawk GT 647 (Adventure)
1989 Hawk GT 696 (Barely street legal track bike)
2007 XT225
2008 650 Gladius
2012 CB1000R
2012 VT750 Phantom   SER #000105
2013 F6B Goldwing      SER #000082
2013 KTM 300 XC-W
2014 CTX 700             SER #000043
Offline canoscan
« Reply #27 on: March 10, 2014, 11:51:16 AM »
Can you elaborate I have no idea what this means..
Offline Geeto67
  • A grumpy
« Reply #28 on: March 10, 2014, 01:15:19 PM »
have you looked at Mike's XS?
https://www.mikesxs.net/
A US based supplier they do have neat upgrade parts for the XS disc front end, esp to convert to dual disc.
FWIW, upgrading to a later xs650 front end and converting to dual disc is probably the way to go for you. All the other methods you are talking about are not a bolt on, they all will require some sort of fabrication. If you search around here you will see guys who have used the later xs650 35mm forks on cb750s just to get better caliper setup.
The GL1000 forks are long, they will need to be shortened if you plan to use them. Not by much but it is extra work.
Maintenance Matters Most
Offline canoscan
« Reply #29 on: March 10, 2014, 01:26:49 PM »
Yes I know mikesxs have bought several things from them, although their shipping is hell expensive.
The '72 year XS650 (and all the early 34mm fork XS650s) actually have a shorter steering neck than the rest of the models that came later, I know of no steering stem that will swap around easily, in all cases I will need to swap out the steering spindle, so whether I go 37mm or 35mm same thing really with regards to steering stem.
Thanks for the heads up on the GL1000 length will take that into consideration. The XS650 35mm front end would be more work than a CB750/4 fork as they don't have the lower fender mounts which I'd have to weld and then machine to get right.
Really just want to know if the GL1000 forks are a significant improvement if not then maybe 35mm CB750/4 forks will be just fine.
Offline Geeto67
  • A grumpy
« Reply #30 on: March 10, 2014, 02:08:34 PM »
I think they are for a cb750. I can't say for an XS. But then again I run 38mm forks (FZR 600) on a kawasaki h1 triple as well. you are right about the frame bracing and leverage transfer but that really becomes an issue with big USD forks off of modern sport bikes. Right now I would be more concerned about tree rake and overall rake and trail.
« Reply #31 on: March 10, 2014, 02:47:26 PM »
Can you not slide GL tubes upat least 1.5 inches or more.
Stem. Swap should be around 100 bux.
