Author Topic: Self-centering steering?  (Read 3579 times)
Offline raymond10078
  • Just learnin' as I go . . . .
« on: March 09, 2014, 07:06:05 PM »
Tore down the front end to do a number of things (new forks, dual brakes, alls balls tapered bearings) - and found that the existing race/bearing set must be dented up pretty bad.
http://youtu.be/8hAxn7U0g24
The fork ears "snap" to the center position when pushed close to center.  Takes a bit of pressure to move off center.  Surprised that I didn't notice it when riding.
« Last Edit: March 11, 2014, 08:22:53 PM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Re: Self-centering steering?
« Reply #1 on: March 09, 2014, 07:09:19 PM »
that has got to be the worst example of that malady ever seen :o :o :o :o  You actually rode this bike in this condition? :o :o :o :o :o
« Reply #2 on: March 09, 2014, 07:14:51 PM »
There have been many threads on the "dead center detent". This is a classic indication your races are shot.
We can learn to deal with it as it comes on over time. A little more effort to hold true, flip side to side, etc.
Once fixed you should be amazed at how much more true will be your lines thru the curves, etc.
PS: yes that vid is scary. Not only do you have the DCD, but the ease of movement is gone. The fork should glide nearly effortlessly from lock to lock.
« Last Edit: March 09, 2014, 07:17:44 PM by MCRider »
Offline Powderman
« Reply #3 on: March 09, 2014, 08:54:39 PM »
Post pics of the balls and races when you pull them. I'm curious.
« Reply #4 on: March 09, 2014, 09:14:37 PM »
I had one with damaged roller bearings, the flat spots would line up on occasion and it was difficult to not wobble down the street. If I stopped and turned left to right several times the flats would mix up and it rode fine for a while.
Offline bjbuchanan
« Reply #5 on: March 09, 2014, 09:22:09 PM »
My friends kz550 is just like yours. You need to push it thru that center. It is uncomfortable feeling going from my bike to his
« Reply #6 on: March 10, 2014, 05:06:14 AM »
It happens from long distance in a straight line on bumpy roads.. The balls pound themselves into the races, leaving visible dots or detents in the races. They look like they were meant to be there. Not so much to see in the balls. They lose their shininess that's about all.
« Reply #7 on: March 10, 2014, 05:21:20 AM »
Will do.
Offline IBleedHondaRed
    • OEM Parts diagrams from my shop
« Reply #8 on: March 10, 2014, 09:13:36 AM »
dads 500 frame does the same
OEM DIAGRAMS http://www.shopstarcitypowersports.com/OEMpartfinder.htm
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
1989 Hawk GT 647 (Adventure)
1989 Hawk GT 696 (Barely street legal track bike)
2007 XT225
2008 650 Gladius
2012 CB1000R
2012 VT750 Phantom   SER #000105
2013 F6B Goldwing      SER #000082
2013 KTM 300 XC-W
2014 CTX 700             SER #000043
Offline Powderman
« Reply #9 on: March 10, 2014, 09:37:08 AM »
I know what causes it. Just want to see how visibly bad his are.
Offline 74750k4
« Reply #10 on: March 10, 2014, 10:06:27 AM »
Torn down the front end to do a number of things (new forks, dual brakes, alls balls tapered bearings) - and found that the existing race/bearing set must be dented up pretty bad.
Great video.
I'm pretty certain one of my bikes is in similar condition...  probably should not ride it til' it's fixed.
Can you make some more vids as you go along???
« Reply #11 on: March 11, 2014, 07:01:02 PM »
Took pics of the bearing races.  Surprising to find - well, not much.  Thought the gouges would be extreme.  Not really.  Couldn't catch a gouge with a fingernail, either.
Lower Inner Race (only these marks on one side - not all the way around)
Lower Outer Race (only these marks on one side - not all the way around)
Upper Inner Race (marks all around)
Upper Outer Race (marks all around)
« Last Edit: March 11, 2014, 07:02:56 PM by kandrtech »
« Reply #12 on: March 11, 2014, 07:35:23 PM »
My thoughts are the nut that adjusts the bearing preload was extremely over-tightened, causing the audible snap when the balls dropped into the grooves. When the balls aren't in the grooves, the triple has a fair amount of resistance to movement. This was most likely done after the grooves were already worn, possibly in an attempt to correct handling issues.
Offline andrewk
  • doin' it.
« Reply #13 on: March 11, 2014, 07:37:57 PM »
Only because it hasn't been mentioned-  replace those with tapered bearings.  One of the best things you can do.  You might already know this, sorry if it's a dead horse. :)
« Reply #14 on: March 11, 2014, 07:50:26 PM »
He mentioned it in his first post. Part of the plan.  :D
« Reply #15 on: March 11, 2014, 08:07:37 PM »
You are correct.  When I loosened the top nut, the triples turned much easier.  The notch was noticeable - but not nearly so.  The grease had the consistency of dried red clay.  Bike only has 15k on it.
« Reply #16 on: March 11, 2014, 08:24:00 PM »
Any notch feeling is too much BTW.
Another example of how its no longer enough to be low mileage. Sheer age ruins stuff like grease, rubber, tires, plastic, etc.
Offline andrewk
  • doin' it.
« Reply #17 on: March 12, 2014, 02:50:08 AM »
I either can't read or was in before the edit.  Both equally possible. :P
I agree on the low mileage part.  It's almost better to find a well maintained 30k miler than a 10k example that has never been apart.  ~40 years is a long time to use the same grease!
