well, bit the bullet and gave the barrels and head to the local machine shop.
They will check if honing is necessary and they'll deck the barrels and head, check the valves guides en replace if needed and build the head back up (valves)
in the meantime took some time to follow up on some threads on this awesome board and did some updates to my engine.
drilled the clutch basket with some extra holes
oilpump out, and installed the oil stopper kit I ordered:
no to bad to install, just messy to fill the oilpump back up
also replaced the small O-ring right here, but wen doing that (don't ask me why) I turned the wheel on the left (the one with the gap in it). But now I can't get it to turn back so I can reassemble. Any idea how I can turn in back?
as a last go the cilinder studs out. What a job
two of them snapped, and had to weld a nut on them in the end, got them off with the impact wrench.
others were with double nut and the help of a pipe wrench at the bottom.
thx for the help!
