Author Topic: New guy, first build  (Read 57364 times)
Offline P.abrera
Re: New guy, first build
« Reply #100 on: August 18, 2014, 06:15:54 AM »
If your tank is down to bare metal, then use a torch over the tank to cook it off. Just don't get nuts with prolonged heating or too hot a temp. If it is epoxy primer, it will bubble loose. Or use a high quality chemical paint stripper.
good idea!
Offline P.abrera
« Reply #101 on: August 18, 2014, 06:17:18 AM »
MEK works very well at removing crap in the tank.
Wish i could find that stuff here
Offline P.abrera
« Reply #102 on: August 23, 2014, 02:58:45 AM »
Finished off some repairs and some fab work on the rear hoop, full weld on the side stand mount and rearset brackets while figuring out how to deal with the tank issues.
Offline P.abrera
« Reply #103 on: August 24, 2014, 06:23:26 AM »
Decided im too cool for practical things like a centerstand and a chainguard. Hacked off a bit more before goin to paint.
...ill probably regret that the next time i need to pull the rear wheel or oil the chain
« Reply #104 on: August 24, 2014, 08:41:19 AM »
Just get yourself a rear wheel stand.  You can mount some spools on the swingarm.
Offline P.abrera
« Reply #105 on: August 30, 2014, 05:18:50 AM »
Continued trimming a bit more fat off the frame. Reassembled valves and tappets.
Rims off to powder coat. Bearings and brake rotor bolts succumbed to a BFH have to source a kawi bolt-pattern sprocket
Offline P.abrera
« Reply #106 on: August 31, 2014, 12:45:51 AM »
Replacement oil pressure switch. Knockin some small nighly fixed off the list.
Offline P.abrera
« Reply #107 on: September 11, 2014, 10:04:03 PM »
Only way to get it clean inside.
Offline P.abrera
« Reply #108 on: September 21, 2014, 05:40:08 AM »
Forks are rebuilt with new tubes, new seals and crush washers. also cleaned up and gave the bottom end a coat of primer and hi-temp universal aluminum
« Reply #109 on: September 21, 2014, 09:45:11 AM »
The engine paint came out nice on the crankcase.  Any internal engine upgrades in the works?
Offline P.abrera
« Reply #110 on: September 21, 2014, 02:46:54 PM »
thanks, its starting to look a bit more presentable now. No engine "upgrades" other than a 601 big bore kit and and an oil cooler (temps and traffic here demand it) . I just wanna get this thing running and on the road at this point
« Reply #111 on: September 21, 2014, 08:17:57 PM »
601 sounds like the Wiseco. No replacement for displacement.
Offline P.abrera
« Reply #112 on: September 22, 2014, 12:34:22 AM »
this is just the cruzinimage kit from ebay. 3mm over.
« Reply #113 on: September 22, 2014, 06:29:36 AM »
That's right. The Wiseco is sub 600 but higher compression.
« Last Edit: September 22, 2014, 06:31:27 AM by CB750 Cafe Racer Fan »
Offline P.abrera
« Reply #114 on: September 22, 2014, 07:45:31 AM »
if i had the coin (and a better idea of what im doing ) id be on the wisecos. Almost a shame to hide such s pretty piston inside the engine next project maybe...if i ever finish this one, that is. Haha
« Reply #115 on: September 22, 2014, 09:28:45 AM »
I think the cruzinimage kit will work just fine.  There are many members who have used it.  To get the best out of a bore kit, and while you have the engine apart, a port job is a great upgrade to improve A/F flow.  Also, this is a good opportunity to check the condition of your valves -- you can lap them -- and valve seals.
Offline P.abrera
« Reply #116 on: September 22, 2014, 03:28:45 PM »
yup did a lap job when i changed out the valve seals. Figured porting might have to wait till i have a bit more experience, id hate to screw it up with some over-eager grinding.
« Reply #117 on: September 22, 2014, 03:45:52 PM »
That's a prudent choice. I'm told that removing too much material can also decrease performance.
Offline P.abrera
« Reply #118 on: October 13, 2014, 11:23:47 AM »
Forks are rebuilt. Couldnt save the old fork tubes. Went with cyclex replacements and kept the front end stock to avoid further "upgrade fever" spreading to the triples, brakes, etc...for now, anyway
Offline P.abrera
« Reply #119 on: October 15, 2014, 11:27:17 AM »
Rehab'ed the wheels the bike came with. KZ cast wheels. Touch of straightening and sandblas to clean off the oxidation. Going to powder in pewter or bronze and slapping on sum new bearings.
Nice and clean and straight.
Offline Trad
« Reply #120 on: October 15, 2014, 01:10:09 PM »
Looking great so far. Keep it up.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #121 on: October 15, 2014, 09:11:54 PM »
What size wheels are those?  18"?  Front and rear?
Offline P.abrera
« Reply #122 on: October 16, 2014, 12:41:19 AM »
19 front 18 rear
Offline P.abrera
« Reply #123 on: October 16, 2014, 12:41:33 AM »
thanks!
Offline P.abrera
« Reply #124 on: October 18, 2014, 09:09:49 PM »
Gotta love sundays. Made some progress today. Overhauled the clutch.
Got my pistons ringed and back on the rods.
And slapped on an 18-tooth front sprocket and a refurbished oil pump.
Coupla questions: should i have somehow primed the pump full with oil before reassembly? And a bit of play on the front sprocket is normal right?
