The SOHC/4 World Tour is in under way.
Paolo,WOW DUDE!!!!! You are doing an incredible job! I cannot believe this is the same engine!Can't wait for more progress!Gersh
Outstanding work, man. You're really turning that into a beautiful bike.
Nice success story,can't wait to see the powder coated rims.
Looks pretty good. Maybe a little less height.
Paolo,Your skills are SO far above mine, its enlightening.I bow to your skills.I am watching, and hopefully LEARNING!!!Dagersh
You're moving right along, great job
Goin with a semi-stock/semi mod'ed setup on the airbox and filter like others have done. Sent from my iPhone using Tapatalk
Quote from: P.abrera on December 20, 2014, 07:43:54 PMGoin with a semi-stock/semi mod'ed setup on the airbox and filter like others have done. Sent from my iPhone using TapatalkBuild is looking great! I like that filter mod, what K&N did you go with? Do you know the name of the steel adapter you used, I'm guessing it's some sort of plumbing fitting or something similar?
Great, thanks for the info. If you want to renew the plastic airbox & other parts, a coating of peanut oil works quite well.
