The non PD carbs do not have a master carb, so you get to assign one. Pick a carb, any carb, back out the idle knob so that it can't hold any slides open. Adjust the individual slider for the "master" carb so that the slide can rest on the bottom of the carb throat floor. Lock down its adjuster and never move it again thereafter. Now adjust all the other carbs to the master slides position for a mechanical sync of all carbs. I use light (light bulb) so they all rest on the floor blocking light. You could even use a drill bit if you must. Use the idle knob to position the master slide open just enough for the bit to slide under it tightly. Then just all the others so the drill bit has the same slip fit as the master.
You will still need to vacuum sync after the engine tappets are properly set and the engine is running. Just don't mess with the master carbs' slider adjust. Match the other carbs vacuum to whatever the master has.
