Author Topic: Plug Wire and plug combo for digital tach.  (Read 1139 times)
Offline wiskey
« on: March 18, 2014, 05:57:59 am »
I have been using  Dyna 3ohm coils, to dyna copper core wires, into Iridium plugs.
The plugs (as far as I know) are only offered with a resistor.
I will be using a motogadget tach/speedo and it says that suppression wires must be used or the unit can be damaged.
I like the Iridium but I cant use them with the suppression wires correct? Any good options?
Thanks!
Offline Tintop
Re: Plug Wire and plug combo for digital tach.
« Reply #1 on: March 18, 2014, 06:29:45 am »
I couldn't find anything that says you can't use suppression wire with Iridium plugs.  You do however want to use a quality wire.  The best would seem to be the latest 'spiral' wound.
« Last Edit: March 18, 2014, 10:27:25 am by Tintop »
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Bill/BentON Racing
    • BentON Racing
« Reply #2 on: March 18, 2014, 06:43:14 am »
I agree, Taylor makes some we use on Samauto. Using NGK racing wires on Calendar Girl, both hi po 750's.Bill
BentON Racing Website
BentON Racing Facebook
Offline wiskey
« Reply #3 on: March 18, 2014, 08:59:30 am »
Do suppression wires hold any resistance? i know the DR8EIX that I use do, and thus i went with a copper core wire. I know the resistance should be in one place.
IF the suppression wires do hold resistance what are my plug choices?
thanks
« Reply #4 on: March 18, 2014, 09:05:25 am »
I seem to recall the short length of suppresion wire we need will not add much resistance, less than the plug so you're fine. I was using resistor caps & Iridiums.
« Last Edit: March 18, 2014, 01:34:49 pm by bwaller »
Offline wiskey
« Reply #5 on: March 18, 2014, 09:40:24 am »
The NGK caps have a 5ohm cap correct?  what plugs were ran with them?
Downside of running a 5ohm cap and resistor plug? I don't have to run iridium plugs, i just want to :)
Offline wiskey
« Reply #6 on: March 20, 2014, 06:44:58 am »
anyone?
Offline Tintop
« Reply #7 on: March 20, 2014, 10:21:04 am »
I run NGK caps, supression wires with NGK BPR8EIX plugs on the sidecar with a Boyer ignition, no issues.
77 CB550 Cafe build
