Author Topic: Thanks & recent CB650 build  (Read 1238 times)
Offline tstanden
« on: March 20, 2014, 07:17:06 AM »
I've been lurking for awhile & have gathered lots of tips/info on the CB while in-build.  Thanks to all who have posted their experience with the beast.....here is the outcome
« Last Edit: March 20, 2014, 07:20:08 AM by tstanden »
Offline UK350F
Re: Thanks & recent CB650 build
« Reply #1 on: March 20, 2014, 07:20:38 AM »
Looks great, good job
Offline curemode2002
« Reply #2 on: March 20, 2014, 03:39:54 PM »
Looks awesome. What kind of rear shocks are you running?
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline andrewk
  • doin' it.
« Reply #3 on: March 20, 2014, 03:53:57 PM »
Lots of nice touches there, looks like pretty good ergonomics too!
Must be a total hoot to lay over in a corner. :D
Is the engine stock?
Offline tstanden
« Reply #4 on: March 20, 2014, 05:08:35 PM »
It's definitely a Frankenbike....CB650 frame (highly molested) & engine (stock), GSXR front end, chrome spoke 17" wheels w/ the typical 160R/120F tires ( I had Buchanon lace the front out of different hub & rim), header from 3 separate junk yard donors, Monster rear caliper, all electrics under seat hump (I built a mold for the seat & had it upholstered), rearsets from some ebay seller (forgot what from), shocks are RFY's until I can get the real deal, frame is powdercoated anodized-red....looks cool in the sun
The carbs were a total PITA....but they're good now that I've replaced the usual suspects (main jets, press-in pilots, acc pump, gaskets, fuel screw assy's, float jet, ....)
Stuff like that......
Thanks for looking
Offline cb650
« Reply #5 on: March 21, 2014, 05:07:34 AM »
Looks good.  Are those the shocks off amazon?  http://www.amazon.com/dp/B00DT082VM/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=9GDNJDUMKUJ5&coliid=IRATC2NGLC50
Dont show a brand name.   Do you like them?
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #6 on: March 21, 2014, 07:06:24 AM »
How much work was it to adapt a GSXR fork to the CB650 frame?  I've seen a lot about grafting modern forks onto CB550 and CB750 frames, but little about doing so for a CB650.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #7 on: March 21, 2014, 07:30:27 AM »
Great looking bike.  I love that exhaust header set up!
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline tstanden
« Reply #8 on: March 21, 2014, 08:08:19 AM »
The forks were a breeze....All Balls sells upper & lower bearings/races that work perfectly and I just had to get 25mm bearings for the Harley hub.  The tricky part was the math for the rotor/hub/caliper assy....
Fitting a 5.5"wheel and 160 tire on the rear was similar; I used the 1" Harley axle, .125" sprocket spacer and moved the drive sprocket out .250
When done, bikes look simple, but the dependencies are amazing......this was my first build and I learned a lot
Offline JimJamerino
  • Yay! I'm a
« Reply #9 on: March 21, 2014, 08:33:22 AM »
All Balls makes a conversion kit for this?  I read somewhere that you can tell them what frame you're using and what fork you're using and they'll hook you up with the right diameters.
Were there any issues with the triple tree stem?  Length and diameter of the stem would be the main thing, I'd think.  Did you run into any issues with the offset, meaning how far the tubes are away from the stem?  Do the triples hit the tank?
~ Jim
Offline tstanden
« Reply #10 on: March 21, 2014, 09:31:57 AM »
For mine, I used:
99-3541-5  Upper
99-3512-5  Lower
Freeze the races and they tap right in.....
Length, ID/OD & offset are great; no issues, no modifications needed
Tree's don't hit as I fab'd in stops on the steering tube when I welded in the mount for the GSXR steering stabilizer
Offline tstanden
« Reply #11 on: March 21, 2014, 09:44:35 AM »
Here it is when I brought it home...
Rear Shocks - Yes, those are RFY's you posted from Amazon.....I don't think they're very good, but there are issues with sprocket clearance given the larger rear sprocket I used, so I went with them almost as a mockup.
Offline JimJamerino
  • Yay! I'm a
« Reply #12 on: March 21, 2014, 10:33:42 AM »
So basically the GSXR front end was a direct swap with the correct bearings?  That's cool to know.  Thanks for the input.  Nice work, too.
~ Jim
