I want to have a ignition kill switch on my CB750 build. Can I use a normally open momentary switch wired to ground and the Pos ignition wire to kill the motor when I push it? Is there enough voltage or amperage to warrant a relay? I was planning on using a small micro switch mounted in the Bar Handle Turning.
