Author Topic: Clear tube method. The EASY way and CHEAP  (Read 21491 times)
Offline goldarrow
  • one day, i'll be an
« on: March 21, 2014, 05:49:56 PM »
I've seen and read many of you guys have come up with all sort of ways to do this, but here's my way.  Hope pictures are self explanatory.  If not, questions are welcome.
Is my float level good? 76 Cb550k
CB550 K0
Re: Clear tube method. The EASY way and CHEAP
« Reply #1 on: March 21, 2014, 06:16:40 PM »
that's about right, now make sure the bike is standing up level and check all four against that level to make sure they are close to the same
« Reply #2 on: March 21, 2014, 07:23:06 PM »
And accurate! No guessing how the float is floating or how soft the spring has become.
Offline Nick0
« Reply #3 on: March 21, 2014, 07:32:52 PM »
Can someone explain what this does to me
Offline goldarrow
« Reply #4 on: March 21, 2014, 07:37:27 PM »
That is for double check, triple check the fuel level in carbs bowls
CB550 K0
« Reply #5 on: March 21, 2014, 07:46:40 PM »
With aftermarket replacement parts, different fuel formulations, and general wear and ageing, setting floats to factory specs no longer necessarily results in the correct fuel level inside the bowl.  This lets you see inside the bowl.
Offline brandEn
« Reply #6 on: March 21, 2014, 09:33:41 PM »
So that tee fits snug enough to not drip fuel?
Offline goldarrow
« Reply #7 on: March 21, 2014, 09:45:51 PM »
Yes
CB550 K0
« Reply #8 on: March 21, 2014, 10:58:16 PM »
Yes
Too complicated ::)
I only need the tube.....and a screwdriver to open the drain screw ;) ;D
Just ribbing Ya  :P  You set your floats well. Nice work  ;)
« Reply #9 on: March 21, 2014, 11:14:38 PM »
I have Mikuni Smoothbores VM29 that really needed this method when it flooded fuel, not very much but enough to foul plugs and engine ran bad .
Possible to order "Fuel Level Gauge Tool for VM29 smoothbore carbs'"
http://www.z1enterprises.com/ItemDetails.aspx?item=ZSM-VM29FT
This method is a must when tuning carbs.
EDIT: Photos make everything more interesting, carb 3 might be a little bit low. I'll see what happen after 200km/h :)
« Last Edit: March 22, 2014, 02:00:29 AM by PeWe »
Offline 750K
« Reply #10 on: March 21, 2014, 11:27:42 PM »
Yes
Too complicated ::)
One more reason to love pd's lol
77 Cb750, 78 Kz1000
« Reply #11 on: March 22, 2014, 07:56:53 AM »
I am not sure your question was answered.  Since liquids seek there own level. The level in the clear tube will be at the same level in the float bowl. It is a quick way to see if all of the float bowls have enough fuel in them. I had some popping on deceleration and using this method I found one bowl was low. Rather than take all the bowls down and measure, I could simply drop that bowl and adjust the float. Quick job.
« Reply #12 on: March 22, 2014, 10:04:28 PM »
Not all carbs drain from their overflow tube, on these you need to convert an extra bowl by cutting the overflow tube off inside.
Offline brandEn
« Reply #13 on: March 23, 2014, 05:26:07 AM »
That's a great idea! So simple and obvious. I never would of thought of doing it this way. Glad I saved the bowl with a broken drain screw. Sweet!
Offline SohRon
« Reply #14 on: March 23, 2014, 09:13:19 AM »
Another method is to get a spare bowl drain plug and drill it out to accept a tube that the hose fits over. Works great for carbs that do not use the overflow tube as a drain; and moving the plug from carb to carb might be a little easier than swapping the bowl as suggested above. Both are good ideas.
« Last Edit: March 23, 2014, 09:20:53 AM by SohRon »
« Reply #15 on: March 23, 2014, 09:30:55 AM »
Another reason why I love this forum. A great exchange of ideas.
Offline lucky
« Reply #16 on: March 23, 2014, 04:23:34 PM »
NO... this method is not correct, and it will not run right.
You must measure the float height.
You can only use the "clear tube method AFTER you have set the float height by measuring.
Think about this:
If you used the "clear tube method" and the float level is ABOVE the overflow drain tube in the float bowl,fuel will constantly be running out of the overflow drain tube.
Save yourself hours of anguish, Do it by the book. It is not that hard.
I worked in Honda dealerships and we NEVER used the "clear tube method to check float levels. We just did it by the book. It always worked perfectly as long as the float needle was in good shape or new.
Offline FuZZie
« Reply #17 on: March 23, 2014, 05:02:58 PM »
I don't see any harm in double checking with a water level, been used in construction for thousands of years?
You think they are rebuilding and trying to set the floats after closing with the level?
« Reply #18 on: March 23, 2014, 05:11:46 PM »
Lucky, the goal is FUEL LEVEL, right? Too much or too little the bike will not run correctly.  I know we can agree on this.
By setting the float height, by the book, you are assuming you set them correct AND the floats are operating correctly. Nothing wrong with this method, but, once you put the bowls back on, the clear tube method is the only way to ensure the fuel level is correct.
We are just double checking our work here, nothing more.
Black 750K8
« Reply #19 on: March 23, 2014, 05:14:59 PM »
Someone is off there meds again ::)
Offline FuZZie
« Reply #20 on: March 23, 2014, 05:19:54 PM »
He may have a valid point, not everyone reading the site may understand it's for double checking.
« Reply #21 on: March 23, 2014, 05:46:58 PM »
True, only if there is no drain screw or plug at all.  Which carbs are those?
Otherwise, you just fit a tube (tapered is good) or something into the drain screw hole.
There was a thread a ways back the used a rigid plastic tube, heated it and stretched it to a point.  Then cut the tapered tube so it would jam into the drain plug threads.
You don't need to do this on a PD carbs.  Bowl drain plug empties into the bottom nipple.
Despite Lucky's religious fervor, the clear tube method is MORE accurate than mechanical measurement.  Many of the replacement float valve pins have springs in them stiffer than the originals.   This results in the wrong fuel level even though the mechanical measurement is to book spec.
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #22 on: March 23, 2014, 06:21:26 PM »
[/quote]
[/quote]
TT is spot on on that.  After meticulously checking my K5 carbs over and over again and then double checking my checking to make sure I had the levels set right mechanically they checked differently using the clear tube method.  I made myself one out of an old drain plug that had been screwdrivered to death by drilling it out and soldering a fitting in it for the tube.  I reset them as required using the tube.  A little time consuming and aggravating to take the bowl back off and adjust but you get good at it after several go arounds.   Works fine, fails safe and drains to the bilges!
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
« Reply #23 on: March 23, 2014, 07:14:34 PM »
The float bowl fuel in the picture is right on the money. The fule should be just under the gaslet. It may be the camera angle, but the carb looks a little tilted. You really want the carb as lavel as possible.
Lucky is a purist and a zealot. That does not mean he is wrong, it also doesn't mean he has the best procedures either.
Offline vames
« Reply #24 on: March 25, 2014, 09:24:50 AM »
I think some confusion is because not all carbs drain through the overflow.
I know mine don't, so if I were to even get any gas a tube hooked to my overflows, it would just be an indication that the float valves aren't working and it's overflowing (don't need a tube to tell me that!).
For those types of carbs that don't drain through the overflow, it seems that somehow jamming the clear tube into the actual drain hole (or creating a special plug with a tube attached) is the way to go.
