Author Topic: Classic Bonneville Racer  (Read 119542 times)
Offline Old Scrambler
Re: Classic Bonneville Racer
« Reply #625 on: July 12, 2021, 07:54:52 PM »
Jerry has copy of graph from Dyno-Jet Drum..........Its OK to post it...........
I am told that 13.3 A/F is ideal..........so with effective altitude at Bonneville of 5200-ft and higher........I'm thinking of going smaller by a half-step on the main jets.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online scottly
« Reply #626 on: July 12, 2021, 08:02:36 PM »
NO! 12.8-13.2 is considered optimum for full power, and 800 feet of elevation won't make that much difference. If I had to re-jet for an elevation change of that much, I would have to re-jet two or three times within 25 miles, no matter which direction I went. ;)
« Reply #627 on: July 12, 2021, 08:17:06 PM »
Run #3 was with a hot motor and A/F was near 14...............so down one step on the jets should get to 13.2 as I tend to run with a hot motor..............2-mile run-up ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online scottly
« Reply #628 on: July 12, 2021, 08:38:21 PM »
14:1 is lean; you need to go UP on the jet size to get to a richer 13.2:1, not down.
« Reply #629 on: July 13, 2021, 08:43:24 AM »
OK............I got it ;)
Minor changes to the fairing and seat gets me a little more narrow and 2 inches lower for a smaller hole in the air. More air will flow THROUGH the fairing rather than pushed around it which should reduce forward pressure and reduce drag at the edges of the fairing.
I will also be lower and narrow without the fairing for reduced forward pressure on the open (naked) bike. Jerry and others may have to help me get into my new leathers. Although I have lost a few pounds, the leathers should be a snug fit..........expected to arrive any day now ;D
I will be away for a few days...........going on a dual-sport ride along the Magruder Corridor in Idaho.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #630 on: July 13, 2021, 10:01:10 AM »
Yeah, well....... Photobucket put a crimp in my abilities. It's in a text on my phone. Trying to get it here is a major issue for me LOL
Online scottly
« Reply #631 on: July 13, 2021, 07:34:50 PM »
Jerry, can you email it to me from your phone? Seems like we have done that before.. I'll PM my email address.
Online scottly
« Reply #632 on: July 14, 2021, 10:48:43 PM »
That is one messed up dyno chart!! The rear tire must still have been slipping on the drum to give such jagged traces. The 70.98 HP was at 16440 RPM??!! I hope you didn't have to pay much for the dyno runs...
Online scottly
« Reply #633 on: August 13, 2021, 08:13:05 PM »
Dennis, how are the preparations going? I found your last dyno chart, which at least shows some useful RPM/HP data. ;D
« Reply #634 on: August 14, 2021, 08:19:03 AM »
Thanks Scottly.....................Paid too much for little to nothing :(
I watched my tach go to 14,000 while the tech was operating the throttle. New tire likely had slippage.
I have 2 projects to complete; extend the front fender covers from the forks to the rear of the wheel for the partial-streamlined classes, and cut a hole in the front of the fairing to allow the air that meets the fairing at the highest pressure point to pass through and eliminate vacuum behind the screen...........if that does not work I can just put some tape over the hole.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline Tintop
« Reply #635 on: August 14, 2021, 10:03:41 AM »
I've always wondered if the trick they tried at Lotus (a 3"(?) wide strip attached to the perimeter in the windscreen frame) would work on a bike fairing.  It worked to smooth the airflow to the extent the driver's tie was blowing straight back.  Legal issues prevented it from seeing the light of day in production.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #636 on: August 15, 2021, 08:58:03 AM »
TinTop............For many years I have curiously placed my hand behind a bike's windscreen and slowly raised one, then two fingers above the edge to see and feel the change in air-movement toward or over my helmet. Two or three years ago HONDA claimed a few added mph to the Fireblade attributed to the small slots in the new windscreen. I have watched numerous videos of Bonneville riders and wind-tunnel tests that show vacuum or forward-moving tape-ends or yarn-tufts behind the windscreen. My thought is to allow the air at the point-of-contact with my fairing to pass-through rather than expend the energy (hp) to push it around the bike. In a small way it would be similar to the new electric bike with the flow-through tunnel.
My new leathers are a good fit ;D........especially after I removed the internal knee and shoulder pads.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online scottly
« Reply #637 on: August 17, 2021, 07:56:09 PM »
If your onboard tach showed 14K, something is wrong. Your previous dyno test showed the engine made it's peak HP at around 9.5K. Also, regarding the tire, I have over 100 runs on the same tire that I had previously logged nearly 2000 relay miles alone on, and it has survived. Was the shop owner the person that ran the dyno test, or was it an employee? If it was an employee, the owner may be more agreeable than if he was responsible for such a piss poor chart? I would request a re-test by a competent operator, and if that is not possible, request a refund.
« Reply #638 on: August 17, 2021, 08:21:19 PM »
Young tech operating the dyno............owner and chief-tech was on the phone giving him instructions. I plan to have a serious talk.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online scottly
« Reply #639 on: August 17, 2021, 08:36:35 PM »
What is the horizontal scale, RPM or MPH? Can't see in the pic.. For the dyno tach, I've had the best luck using two secondary pick-ups, one on the #1 plug wire and the other on #4 wire. Set the dyno for 360* This gave a stable reading, even with the Gerex multi spark ignition. (Jerry has a brand-new-in-the-box Gerex under his bed, which I think he should donate to the cause. ;) ;))
« Reply #640 on: August 25, 2021, 08:35:59 AM »
Scottly.........its RPM............Been busy getting things ready to GO FAST ;)
I leave tomorrow for the salt................Jerry and 3 others will make up the pit-crew. We are staying at the '6' :).....it has great showers and plenty of ICE ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online scottly
« Reply #641 on: August 25, 2021, 08:48:08 AM »
Good luck!!!! Keep us posted... ;D ;D
« Reply #642 on: August 25, 2021, 08:54:20 AM »
I will have my lap-top...........will try for a few pics. I appreciate the Crew-in-Absentia ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #643 on: August 26, 2021, 12:20:58 PM »
Good luck Dennis.. wish were on my way down there,, but it is not to be.,
« Last Edit: August 27, 2021, 07:47:04 AM by 754 »
Offline gschuld
« Reply #644 on: August 26, 2021, 05:32:21 PM »
Good luck Dennis….👍
George
« Reply #645 on: August 27, 2021, 06:43:03 PM »
Thanks, guys.............Pics will be posted on my private facebook page..........you do not have to be a facebook member to view.
https://www.facebook.com/dennis.weinhold.5/?v=info&edit_info=all#!/
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online scottly
« Reply #646 on: August 27, 2021, 08:23:18 PM »
Fake book says I need to log in??
« Reply #647 on: August 30, 2021, 08:48:32 PM »
1st run today was 138 in 4th at 9,200 rpms with 18 x 40 on 120s...........2nd run was 137 in 5th gear at 8,100 rpms.
3rd run was 136 with 17 x 40 in 5th at 8,300 rpms.
Slower than 2018 so-far.........will go back to 17 x 44 and try for speed with more rpms.......
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online scottly
« Reply #648 on: August 30, 2021, 09:01:01 PM »
The great white dyno says your peak HP is at 9200 RPM. ;D
What gearing were you running last time? 17x44? IIRC, your tach was suspect that time?
Offline johno
« Reply #649 on: August 31, 2021, 06:02:55 AM »
Den's last meet he ran 17:45 for 143mph,  then 17:44 ran 140mph
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
