Author Topic: Classic Bonneville Racer  (Read 119604 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Classic Bonneville Racer
« Reply #700 on: April 22, 2022, 05:21:07 PM »
Can't wait for August!
Offline Old Scrambler
« Reply #701 on: May 12, 2022, 07:06:14 AM »
Now I know where the HP went.....BENT VALVES :(
Following the dyno-run with Scott I pulled the head and slowly began examining EVERYTHING ;) Yes, the motor was down on compression partially due to a total of 8-thou lost to slightly thicker base and head-gaskets. BUT, the real loss was very slightly bent valves and one very egged-out valve guide. That puff of smoke at the end of the last dyno-run was likely caused by cylinder pressure escaping resulting in a very high level of oil-pressure. Its the only time that notable oil was found in the catch-can :o
All of the intake valves will need to be replaced along with guides & seals. The beehive springs are well within spec. The valve seats will also need some work. How soon this will take place is not known because I may have to send the head to Wisconsin. No locals are equipped to work with 5.5mm valve-stems and guides.........unless Salt Lake City is affordable.
We just bought a newer RV and have travel plans for the summer and fall. More later...........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bear
  • Leeton in Australia
« Reply #702 on: May 12, 2022, 07:26:18 AM »
Well it's always good to nail down a problem but once again we find the god's of speed are cruel god's. :(
« Reply #703 on: May 12, 2022, 11:48:25 AM »
Well #$%*!!
What's your diagnosis of the cause? Running too many rpm with the beehives? Too tight clearance? Missed shifts on the throttle? All of the above? But with a thicker base gasket? Only 1 guide?! Was that the one that lost the adjuster nut?
Lot of time before Bonneville. Getrdun.
« Reply #704 on: May 12, 2022, 01:53:16 PM »
All of the above were contributors..........but the loose adjuster and lost lash-cap on #1 caused the most damage. #1 is about 7-thou out of shape at the outer edge...........the others are between 2 and 3-thou which IF they were from a Chevy would be within factory spec :D
#1 seat is well dished but will likely clean-up.
New Farrea valves and related items are still available for the 2.2L Prelude motor that I adapted to this build.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #705 on: May 12, 2022, 07:54:48 PM »
Pistons still good?
« Reply #706 on: May 13, 2022, 08:46:52 AM »
No evidence of piston to valve contact. Pistons and rings will get closer inspection, but at first look with a 'spy-glass' in my hand they appear to be good. The high-lift cam puts extra side-force on the valves which causes the guides to wear so the valves don't seat exactly as when new. Although the lash-caps are a snug-fit, each valve stem has a witness mark at the edge of the cap with #1 showing a shallow grove. The exhaust valves are good but have slight witness-marks at the caps. All 8 valve components will be exchanged for new units. Because the original stems were shortened, the tips were not hardened. I will try to solve that by having Ferrea do the machining and use their lash-cap & collar interlocking design. Their Super-Alloy valves are $42.55 each and for a little more I could get hollow-stem & or Ti units for an additional 40-percent weight reduction ;) ;)
Part of the decision on which units to get will be influenced by another AHRMA racer and rather famous motorcycle restoration guru (Retro-Speed) who wishes to build a new race-motor using a 410 head. Anyone else???
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #707 on: May 13, 2022, 08:54:28 AM »
Dennis, you do not have an extra head to use while repairing the faulty one?
A spare head good to have.
I had a head swapping day today. As I thought, IN seats not cut deep enough for 10 mm lift. Valve keepers groove in valve stems start 9.5mm over the valve stem seal. Should be at least 10.5mm.
Will check EX too, valve lift 9.4 so 10mm a must.
I should have checked that last year, twice after first huge oil drinking episode when I blamed head torque only.
Another head went on today, not much used MLS looked as new and reused. This head have seats cut deep enough.
Good to work from home ;)
I understand the feeling when something recently modified goes bad.
Good reason to repair and do better than before!! ;D
I have lost the count of head, cylinder lifting and  swapping plus various cams in my blue K6 the last 2 years. More before that. ;D
It just run better and better.
I got a late lunch with a good french red wine (Chateauneuf-du-Pape) after head was torqued.
Now on my 2nd Gin Tonic. Fresh oil smell still around me despite a hot shower.
Will assemble, time cam and all the rest tomorrow. Synch carbs on Sunday.
Call a bike shop and beg for dyno time on Monday.
I hope you'll find inspiration to fix your engine, look forward and forget the repairs. I'm sure it will run better next time.
There are trophies waiting for you! ;D
//Per
« Reply #708 on: May 13, 2022, 08:54:41 AM »
"for a little more"  and........ key word is little. 150 mph?!
« Reply #709 on: May 13, 2022, 10:42:27 AM »
Thanks for the encouragement..............its my flat wallet that's holding me back. I do have a spare 410 head.......actually 3 of them ;)  But they are not ported at time.
For reference: the little more is going from $19 for stainless to $42.55 for super-alloy to $180 per valve for Ti
As long as I run gasoline the stainless are good, but actual fuel should have higher-heat components........especially on the exhaust side ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #710 on: June 01, 2022, 08:08:19 PM »
Go with the stainless. ;) BTW, not sure what you mean by "fuel", but I thought alcohol fuels ran cooler, due to some sort of "latent heat" scientifical stuff? ???
« Last Edit: June 01, 2022, 08:10:13 PM by scottly »
« Reply #711 on: June 02, 2022, 08:18:38 AM »
Anything other than gasoline is FUEL. Yes, alcohol burns cooler, but you need a lot of it.  A few cars are set up for E85. Maybe I need to build another motor?
I may have found a shop in Idaho Falls that will do the work.
Scott.......regarding your dyno..........you should consider parking it on the pavement at the truck-stop or the 'boat-ramp', or at the old army airport hanger..........talk to Delvine or the Mayor.  I plan to be a volunteer or spectator this year.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #712 on: June 02, 2022, 10:22:59 AM »
"I plan to be a volunteer or spectator this year"
hello??????????
« Reply #713 on: June 02, 2022, 08:59:37 PM »
   What kind of valve guide material?
« Reply #714 on: June 03, 2022, 12:06:41 PM »
Copper/Bronz from Ferrea............I said badly egged-out relative to a race-spec engine...........I've seen much worse in a street-bike tear-down.
Jerry......our plan was to be in Alaska for the entire summer.......now it looks like more local RV trips but no SPEED-RUNS this year.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #715 on: June 03, 2022, 01:12:41 PM »
Yes, plans change as do valves. Good to know.
Did you get the new RV?
« Reply #716 on: June 04, 2022, 08:35:48 AM »
The 2017 Class C is getting stocked as I make myself familiar with its modern features and air-bags on the rear suspension. Selling the old unit is a bit of a pain...........3 ebay buyers backed out.........the last one told me to keep the deposit for my trouble ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Online RAFster122s
« Reply #717 on: June 05, 2022, 12:22:53 AM »
So, PM me about your old one and what it’s issues are and what you are asking or sellers have won the bid with. Too many scammers on FB marketplace these days and all the craiglister tire kickers and low ballers have found it as well…
  • Moderator
« Reply #718 on: June 30, 2022, 02:18:55 AM »
Hi Dennis, sorry if this is a bit off track but last night in the pub, someone asked me if it was true that people pee on a tree before getting on the salt.
I told them it was but couldn't for the life of me remember what sort of tree it was and do people still do it ?
Sam.  ;)
« Reply #719 on: June 30, 2022, 03:26:36 AM »
I could not resist to Google it.
Lemon tree.
That's why lemons are yellow?
  • Moderator
« Reply #720 on: June 30, 2022, 03:43:08 AM »
Lemon tree.
Like, don't eat yellow snow. lol. I thought it might be but couldn't find anything on Google, what did you put in Google ?
« Reply #721 on: June 30, 2022, 09:47:27 AM »
Lemon tree.
Bonneville salt flats + pee tree
« Reply #722 on: July 11, 2022, 12:33:59 PM »
Just returned from a few weeks in the bush........There are no trees at the salt flats ;D ;D
Burt Monroe asked has neighbor kid (Tommy?) to pee on the small lemon tree in Burt's backyard while he was on his trips to Bonneville.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
  • Holy Cow! I'm a
« Reply #723 on: July 12, 2022, 12:47:31 PM »
Scotts bringing a dyno to wendover?
« Reply #724 on: July 21, 2022, 03:05:10 PM »
That's the plan...........but confirm directly with Scott ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
