Author Topic: sealed beam replacement on CB750?  (Read 4686 times)
Offline Scott
  • 72 CB750
« on: March 22, 2014, 10:58:45 PM »
Hello
I want to replace the sealed beam on my 1972 CB750.
I have a 2nd hand replacement lens assembly ( the type that take H4 globes) to try and work out how to do it before I go and buy a new one to suit the bike.
The sealed beam currently in the bike has tags on the side of it to mount it into the headlight ring and also a tag used to take the adjuster screw with the spring on it.
Can you buy a lens assembly with H4 globes that has these tags on it or do I have to some how mount a car type lens assembly.
Thanks heaps for any pointers, this has me a bit stuffed
Scott
Re: sealed beam replacement on CB750?
« Reply #1 on: March 23, 2014, 10:39:21 AM »
Hello
Scott
I'm a little confused by your description: can you possibly post a picture of it?
The OEM headlight is a Stanley sealed beam with notches that fit into the chrome ring that attaches to the headlight bucket. The aftermarket H4 rings may or may not have the Honda chrome part attached, but the "lens assembly" will mate up with the Honda chrome ring to make it fit OK. These have the hole in the back for the H4-shaped bulbs.
If you have the latter, it is just a matter of getting the bulb and installing it into the hole, and there should be a spring clip to hold it in place. Be sure to get a 40/45w, 50/55w, or 55/60w bulb in H4 shape, no bigger: more than 60w high beam will cause trouble for the bike's wiring. The H4 bulbs go all the way up to 200 watts, all in the same-size bulb!
« Reply #2 on: March 23, 2014, 11:02:17 AM »
The unit I have is by Candlepower. 7" H4.
Offline bjbuchanan
« Reply #3 on: March 23, 2014, 03:28:18 PM »
Any motorcycle one out there will be plug and play, they make all the HL buckets the same as far as the light mounting. You may be able to transfer the stock Stanley trim over to the h4 you have already
Offline krusty
« Reply #4 on: March 23, 2014, 08:41:05 PM »
HondaMan, it sounds like the light he is describing is has the mounting fittings integral with the light itself. I have a similar unit, from the description, in my F2 which BTW needs replacing too.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Scott
  • 72 CB750
« Reply #5 on: March 23, 2014, 08:47:14 PM »
same as that one Krusty, thanks mate.
I think I found something on ebay that may work.  It looks like 3 rings (plus screws,spring)  that may adapt my "new" headlight into the existing bucket.
Hondaman do I put the high/low relays in the headlight bucket and connect onto the wires coming from the 3 pin plug
Thanks
Scott
« Reply #6 on: March 23, 2014, 09:42:52 PM »
Thanks
Scott
Yep, that's the place! They will fit usually toward the upper back of the bucket. That's where mine are.
Offline Raul CB750K1
« Reply #7 on: March 24, 2014, 04:57:17 AM »
If you no longer want the sealed beam I'm interested in buying. No matter if it is blown -actually better if so-, as I only need the front glass.
Please let me know, thanks
Offline sazaver
« Reply #8 on: March 24, 2014, 11:27:46 AM »
I bought a H4 hella lens with a DDM  3200k motocycle xenon kit. Highly recommended
« Reply #9 on: March 24, 2014, 09:58:24 PM »
I'll bet that one lights up the canyons of Wall Street! :D
Offline Scott
  • 72 CB750
« Reply #10 on: March 25, 2014, 10:14:48 AM »
G'day Raul
The headlight still works and at the moment I still need it as I haven't got the parts to fit a new one just yet.
Once I fit the new one I'll decide if I need to keep the old one or not. Although posting it from Australia may be a bit expensive.
Scott
Offline 74750k4
« Reply #11 on: March 25, 2014, 10:16:11 AM »
I have 3 of those Hella H4 conversion units. Apparently some are made for motorsicles and some are not. The ones that I have use an internal metal reflector that ALWAYS breaks off and falls inside the glass. Eventually I learned to crush it enough to pull it out of there. Works fine without it.
« Reply #12 on: March 28, 2014, 09:39:31 AM »
I buy often from overseas, I'm used to international post. If you decide you no longer need it please let me know.
Thanks!
