Author Topic: CB550 brake piston-what is this ??  (Read 2214 times)
Offline jasonpfm
« on: March 26, 2014, 05:20:02 PM »
I just took apart my brake caliper and pulled the piston. Is this mass inside the piston suppose to be there?
1975 CB550K
1972 CL350
1975 CL360
1982 CX500C
Offline LesterPiglet
  • 1977 CB550F2
Re: CB550 brake piston-what is this ??
« Reply #1 on: March 26, 2014, 05:27:22 PM »
No, the piston should be hollow. I never cease to be amazed.  ???
Was the piston inserted the correct way round?
Offline jasonpfm
« Reply #2 on: March 26, 2014, 05:32:08 PM »
Yep. I've never seen anything like it! It's solid as a rock!
1975 CB550K
1972 CL350
1975 CL360
1982 CX500C
Offline jasonpfm
« Reply #3 on: March 26, 2014, 05:36:14 PM »
I think a brainiac PO has struck again!
1975 CB550K
1972 CL350
1975 CL360
1982 CX500C
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #4 on: March 26, 2014, 06:36:49 PM »
Yes.  Some caliper pistons are "filled".  To convince yourself - just do some searches for NOS parts . . . . ;)
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
« Reply #5 on: March 26, 2014, 07:30:54 PM »
All the stock caliper pistons I've seen are hollow with a plate across the opening (puck side).   Yours appears to have had the anti-rust plating removed from the steel plug, allowing the steel to rust.   And, it has also been drilled for some unexplained reason.
Lots of shoddy mechanics out there.
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #6 on: March 26, 2014, 08:09:06 PM »
The JB Weld monster strikes again!!!  LOL
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
« Reply #7 on: March 27, 2014, 02:44:46 AM »
I should add that I would expect this rusting outcome when the caliper is rebuilt without the proper silicone lube to shed the water.
Offline jasonpfm
« Reply #8 on: March 27, 2014, 06:12:03 AM »
Needless to say, I should just replace the piston right?
1975 CB550K
1972 CL350
1975 CL360
1982 CX500C
  • 1977 CB550F2
« Reply #9 on: March 27, 2014, 06:32:47 AM »
I would, even without seeing the pitting on the side.   ;)
« Reply #10 on: March 27, 2014, 09:56:03 AM »
I would, if at all possible.  Although it is hidden from view in operation.  Who will see the use of shoddy parts?  And it may still work well enough to sell off in a few months.
Did I need to say that? ;D
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #11 on: March 28, 2014, 09:00:37 AM »
I should buy this myself but here you go:
http://www.ebay.com/itm/NEW-OEM-Honda-Brake-Caliper-Piston-Left-CB550-CB700-CX650-GL1100-GL1200-43107-MA-/261404675656?pt=Motorcycles_Parts_Accessories&hash=item3cdceece48&vxp=mtr
decent price for OEM + free shipping. Most used ones go for the same or more. Or the phenolic is the other good option.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Popwood
« Reply #12 on: March 28, 2014, 09:53:53 AM »
Hmmm,
I just did a disk brake job on my '75 550K and it sure as heck has a solid piston that doesn't look at all like a modification. The bike is in nearly pristine and original condition as far as I can tell.
There was a bit of pitting on the piston but not too serious. After finding no conclusive opinions about what to do about that I decided to fill them with JB Weld then lightly wet sand back to flush surface starting with 600 grit paper, then 1000 then 1500 grit. Figure the worst than can happen is the JB Weld could break down from brake fluid over time. Also rebuilt the master cylinder. Can't believe the crud that was in there.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
  • 1977 CB550F2
« Reply #13 on: March 28, 2014, 10:12:19 AM »
It depends how bad the pits are.
I did my old forks with Araldite and they lasted until I bought new ones 15 years later.  8)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #14 on: March 28, 2014, 10:54:02 AM »
Hmmm,
Unfortunately you're dealing with your brakes here. Take any risk you wnat but I don't think $35 -$40 for a new brake piston is worth my life.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
    • http://forums.sohc4.net/index.php?PHPSESSID=dmi35ugiq1sfnte21doanpfkc5&/topic,60973.0.html
« Reply #15 on: March 28, 2014, 11:00:01 AM »
breake fluid eats many types of jb weld..or super glue.
..why takes thances on high risk parts like breakes,, tires,, stering....it dangerus in trafik..so vhy make the odds worse...
Offline Popwood
« Reply #16 on: March 28, 2014, 12:10:48 PM »
I did my research here on piston pitting question before doing the JB Weld infill of the few flyspecks of pitting I had. Some respected members said the pitting, if not serious would be tolerated and only lead to a bit of brake drag and more frequent service on the piston seal. I'm not a big risk taker and this repair was nothing like holding mechanical parts under stress together. It will only prolong the service life of the seal. I have no doubt that simply getting on the bike and riding into traffic represents far greater risk. If I start getting premature brake drag, I'll know the JB Weld has failed and install a new piston and ring.
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
« Reply #17 on: March 28, 2014, 01:26:12 PM »
yes small pittings make it  not leak...or make fail funktion..it most the gluing idea i be a bit vorried abaut.
.if loose .jb.parts can stuck the piston..so it not move..free..
and you sell/give/barrow?? the bike and new ovner/freind,,,who not have same feeling for stuck/free pistons as you..get a hot blocking caliber..locking the fronthveel..
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #18 on: March 28, 2014, 01:30:37 PM »
Imperfections in the piston surface can allow air into your brake system, then your screwed when you need the brakes the most.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
